Gscreen - a GTK / Glade / Python based screen
- tjamscad
cmorley wrote: Yes! and I sent it to you.
Chris M
Chris,
I like it, I like it
On the System tab can you add unlocked or locked? I left the system tab but didnt know if it was unlocked.
<hint>tjamscad wrote: On the System tab can you add unlocked or locked? I left the system tab but didnt know if it was unlocked.
The point of GScreen is that it is meant to be an interface that is easily customisable by the end-user
</hint>
- Thank you received: 2181
It was exactly what was needed - I have a pretty good idea how to program Gscreen so it is very flexible.
The big changes of industrial seem to have started to die down and now it's starting to be personal choices rather then 'this is wayis tons better'
Between Industrial and Norbert's Gmoccapy we have some good functionality and infrastructure. I'm happy.
Soon it will get to the point where yes if you want _that_ change you'll have to do it on your copy.
But we are a long way from any 2.6 release so there is still plenty of room for changes.
Yes I agree a lock / unlock would be helpful
Chris M
Anyone using any of Gscreen's different skins please give feedback of what you like and don't like. or what you need that missing.
at the moment I know that tool setting to a common point is missing, I'm just not sure how best to do it.
AXIS uses touch-off and you pre-select whether its for origin setting or tool setting.
I would like something more obvious.
I could have the tool setting buttons show up when the tool table is showing ....
Chris M
- karlkec
I think having it on the tool table page would work well. Include the ability to change tools from there too (tool index button). Could even highlight the row in the tool table matrix for the currently-loaded tool. When a tool is touched off the values in the tool table matrix should update. My thinking is that the tool table page would have everything necessary to set up all the tools in the changer.cmorley wrote: at the moment I know that tool setting to a common point is missing, I'm just not sure how best to do it.
Chris M
Karl
