Gscreen - a GTK / Glade / Python based screen
07 Feb 2013 03:06 #29728 by tjamscad
Replied by tjamscad on topic Gscreen - a GTK / Glade / Python based screen
Wed, 06 Feb 2013 13:04:55 -E word with no G76, M66, M67 or M68 to use it
N33G00G90G40M01E01
07 Feb 2013 03:15 #29729 by newbynobi
Replied by newbynobi on topic Gscreen - a GTK / Glade / Python based screen
I understand now. thanks
I had not seen a toolchanger like that on a mill.
Is that you in the background?
No its a friend of mine.
My other changer the turent is working similar, the tool s are fixt in spring clamps from the side.
07 Feb 2013 03:18 #29730 by newbynobi
@tjamcad
N33G00G90G40M01E01
linuxcnc does not like the E01
You can not just copy a fadal program to linuxcnc!
Nearly every machine control has its own language, many are based on Gcode, but have cycles programmed with special dialects.
You will have to translate them to pure gcode.
Norbert
07 Feb 2013 03:32 #29731 by tjamscad
@tjamcad
N33G00G90G40M01E01
Norbert
Yes, I agree language and dialects. LinuxCNC should be able to translate and function so I dont have to change programs everytime i need to load a program.
07 Feb 2013 05:11 #29734 by BigJohnT
Replied by BigJohnT on topic Gscreen - a GTK / Glade / Python based screen
Sounds like a good job for you to write translators for other G code to LinucCNC.
07 Feb 2013 05:29 #29736 by andypugh
Replied by andypugh on topic Gscreen - a GTK / Glade / Python based screen
That would be nice, but may be harder than it sounds.
The problem is how LinuxCNC is meant to work out what particular G-code dialect is being used, purely from the G-code.
There is work under-way to allow pluggable interpreters, so it should be possible in the future to swap the RS274NGC interpreter for a Fadal interpreter.
But that will still not work if you feed it Fanuc G-code.
G40 in RS274NGC is "cancel cutter radius compensation" and M01 is "optional pause."
What is that E01 expected to do in that line of G-code on a Fadal machine? I don't see a G-code to use it.
07 Feb 2013 06:15 #29741 by tjamscad
The programer of the file said in this case E01 can be replaced by G54. How ever this is silly in my opinion. Maybe this can be added to the LinuxCNC3 list? If I want to run a program on a Haas, Toyoda, Fadal, Cincitti, Viper, or LinuxCNC converted machine I should be able to. Currently I can't but LinuxCNC would be more apealing if it could decide between them.
07 Feb 2013 06:19 #29742 by tjamscad
Was that directed at me?
07 Feb 2013 07:48 #29746 by BigJohnT
Aye.
07 Feb 2013 09:52 #29748 by cmorley
Replied by cmorley on topic Gscreen - a GTK / Glade / Python based screen
That is a common problem in shops that uses many different controls and use the special features of them.
Things you could do:
You stick to the generic-between-controls Gcodes
It you use CAD/CAM you build a post processor for each machine.
If it's simple substitution - Linxcnc can run a filter program before running the Gcode. (Someone would need to write this)
use linuxcnc's 'remap' capability to change linuxcnc to understand different dialects ( at the moment you can't change arbitrary Gcode -only a small subset)
Chris M
Time to create page: 0.198 seconds
