Gscreen - a GTK / Glade / Python based screen
- karlkec
14 Feb 2013 23:41 #30059
by karlkec
OK I'll bite.
There seems to be room around the spinbox (now at the bottom). Could there be a button to bring up the calculator entry number pad? Double-clicking with the touchpad is not easy, and for people with large fingers almost impossible.
One of the rules I've heard for panel layout, which I'm sure applies to touchscreen layout: if the panel is somewhere near eye level (which ours is), pushbuttons should be below it so one's arm doesn't cover the screen while pressing buttons. In a way I like having the buttons at the top, but I do have to look around my arm when pressing the buttons. I'm not saying I want the buttons back on the bottom, just throwing this out for discussion.
Karl
Replied by karlkec on topic Gscreen - a GTK / Glade / Python based screen
Any updates ?
I almost miss all the requests for changes
OK I'll bite.
Karl
- BigJohnT
- Thank you received: 994
15 Feb 2013 00:16 - 15 Feb 2013 00:18 #30060
by BigJohnT
Replied by BigJohnT on topic Gscreen - a GTK / Glade / Python based screen
I don't know why anyone would want touch screen buttons on top or left or right so you have to block your view and raise your arm up over your shoulder (bad) to press a button on the screen... but what the heck do I know? The human resource people would be all over you for bad ergonomics for sure.
Last edit: 15 Feb 2013 00:18 by BigJohnT.
- newbynobi
- Thank you received: 394
15 Feb 2013 00:36 #30062
by newbynobi
Replied by newbynobi on topic Gscreen - a GTK / Glade / Python based screen
As most off us are right handed,
the buttons should be on the right side and on the button and nowhere else!
I am missing on the preferences page the checkbox (reload tool on startup)
The password for accessing the settings should be stored in the hidden preferences file
and should be editable through preferences page.
Gremlin is still not update the tool path well,
To test just load a program, then jog around and set a new origin for G54, and start the cycle. look where the toolpath is drawn.
I would like an integrated keyboard, not the one floating around covering important thinks.
User can set in INI FILE in DISPLAY the Key:
EDITOR = gedit
Gscreen will ignore that! In My opinion it shouldn't do so.
Chris : I can go on that way;-) It is your fault, you asked for that!
I agree, that this thread should be separated in smaler more detailed ones:
Norbert
EDITOR = gedit
Norbert
- tjamscad
15 Feb 2013 01:35 #30064
by tjamscad
Replied by tjamscad on topic Gscreen - a GTK / Glade / Python based screen
Since this button thing is such a big deal. Why not ask Chris politley to filp the hole thing upside down. Tabs and buttons on the bottom. Can we agree that having the buttons and tabs together is a better way to go. on top on bottom all on the side doesnt really matter. Having them together is better
- karlkec
15 Feb 2013 02:44 #30066
by karlkec
YesSince this button thing is such a big deal. Why not ask Chris politley to filp the hole thing upside down. Tabs and buttons on the bottom. Can we agree that having the buttons and tabs together is a better way to go. on top on bottom all on the side doesnt really matter. Having them together is better
- Thank you received: 2173
15 Feb 2013 09:33 #30083
If you hide the pointer in the preference page then you don't need to double click, a single click will do.
I am probably going to get rid on the spinbutton, though probably a button to bring up the calculator would be handy.
For a right handed person buttons on the right should be fine. I never really liked the buttons on top, though the layout worked a little better.
I have not tried it with tabs and buttons on the bottom. It's a bit of work. In the end not everyone will be happy but then again one can always change it to what they like....
Hey we can add files again yaaa!
Replied by cmorley on topic Gscreen - a GTK / Glade / Python based screen
OK I'll bite.
Karl
15 Feb 2013 09:51 #30084
Norbert
What checkbox are you missing - I don't follow you.
The password is for industrial only. Gscreen doesn't know about it at all. so it is appropriate to be in the handler file ( I think anyways)
To be able to edit it in the preference file defeats the purpose of it.
Gremlin not plotting path correctly - I can't do much with that - file a bug report to the maillist please.
Gremlin not reloading after a new origin set, I can fix. how did you set the new origin?
An integrated keyboard is possible, but requires some more work and dependency that the linuxcnc project may not want ( at least to do it properly)
use TOOL_EDITOR = gedit and test in default gscreen with the button 'tool editor' but why do you wish to use gedit over the tooleditor widget?
Chris M
EDITOR = gedit
Norbert
Norbert
Chris M
15 Feb 2013 13:10 #30092
oh I see you want to edit _Gcode_ with gedit editor.....
I didn't notice the differennce.
Chris M
EDITOR = gedit
Norbert
Chris M
- tjamscad
15 Feb 2013 22:24 #30120
by tjamscad
Chris,
I just noticed the screen shot thread and on the indrustral screen shot it does not have the Machine on , machine off button Indicators.
16 Feb 2013 09:42 #30162
Ya I couldn't live with the two buttons.
When you go to add Gscreen to a production machine, you can add them back. It's not hard.
Chris M
Chris M
Time to create page: 0.620 seconds
