Gscreen - a GTK / Glade / Python based screen
18 Feb 2013 22:44 #30282 by karlkec
Replied by karlkec on topic Gscreen - a GTK / Glade / Python based screen
The jogging mode problem, is really a mode switching problem.
This like origin shift, origin zero, tool index, coordinate shift are actual done with MDI commands.
it's reliably switching back to manual mode (jogging requires this) that is the problem.
I'm fairly stumped right now. Tool index is different from say origin shift.
Tool index needs to wait till a HAL pin changes and this waiting screws me up.
Hi Chris,
Is it a problem of knowing when to tell it to switch back to manual mode? Have you tried polling halui.program.is-idle? Or maybe you aren't using halui. Have you looked to see how touchy does this?
I'm full of questions but no answers. ;)
Karl
19 Feb 2013 00:09 - 19 Feb 2013 00:17 #30287 by tjamscad
Replied by tjamscad on topic Gscreen - a GTK / Glade / Python based screen
Sample of bottom buttons for industrial:
I like it, I like it :)
Chris,
I asume this is still concept at this point?
Last edit: 19 Feb 2013 00:17 by tjamscad.
19 Feb 2013 00:51 - 19 Feb 2013 00:52 #30290 by BigJohnT
Replied by BigJohnT on topic Gscreen - a GTK / Glade / Python based screen
I like that!
Is it in master?
Does it work with pyngcgui?
Last edit: 19 Feb 2013 00:52 by BigJohnT.
19 Feb 2013 03:41 #30294 by cmorley
Replied by cmorley on topic Gscreen - a GTK / Glade / Python based screen
I have not pushed this yet, I am removing the entry box. which involves a fair bit of code.
I hope it's not a mistake....
maybe I should push with the entry box still there first??
As pyngcgui is embedable, there is no reason it shouldn't work. The reason I haven't tried it is pyngcgui is in V2.5 and Gscreen in master. so it's a bit of work to try it. I have been busy with other things.
Chris M
19 Feb 2013 03:46 - 19 Feb 2013 03:47 #30295 by cmorley
Hi Chris,
Karl
I don't use halui but I use the same mechanism as halui uses.
The problem comes from waiting for tool change to finish blocks Gscreen from doing anything else.
Since manual tool change dialog needs Gscreen to function so it can pop up the dialog, you can see the catch 22
I could add the switch back to manual to the dialog finishing but then i have to add a bunch of logic to decide if the tool change started from manual,
or was from MDI or AUTO. Not very nice and easy to break.
Asking questions often leads to answers!
Chris M
Last edit: 19 Feb 2013 03:47 by cmorley.
19 Feb 2013 04:00 #30297 by BigJohnT
Chris M
No biggie, Just thought I'd ask. I'm good for now using Touchy-Gremlin-Pyngcgui.
19 Feb 2013 12:35 #30305 by karlkec
Chris M
How about a custom realtime component to monitor the tool change and tell gscreen when it's complete via a HAL pin.
I know it's kludgey, but would it work?
Karl
19 Feb 2013 12:51 #30307 by cmorley
This could work, it's really an extension of using the dialog finishing to signal being done.
And it has the same problem, I have to know what mode we were in before tool change was called.
It's really a fundamental problem with doing toolchanges in MDI.
Or it would be nice to have linuxcnc switch back to the mode it started in.
I'd rather have toolchanges in Manual mode.
19 Feb 2013 12:55 #30308 by cmorley
Chris M
I added Deweys patch to master to try integrating it in to Gscreen.
It seems Dewey doesn't use the 'standard' embedding technique, he patches TOUCHY to load pyngcgui
I don't really like this - so I sent an email to Dewey to discuss.
Chris M
20 Feb 2013 00:32 #30325 by newbynobi
Replied by newbynobi on topic Gscreen - a GTK / Glade / Python based screen
Hay Chris,
I do monitor the mode in gmoccapy code.
Please take a look at
def _set_spindle(self, widget, data=None):
around line 381, may be this could be helpfull.
Norbert
Time to create page: 0.975 seconds
