Gscreen - a GTK / Glade / Python based screen
27 Feb 2013 16:13 #30646 by cmorley
Replied by cmorley on topic Gscreen - a GTK / Glade / Python based screen
Hallo Chris,
changing a tool, from tooledit widget, brings an error:
"Tooledit widget float error"
Does this happen, because I use German settings for the decimal separator. "," instead of "."
Norbert
maybe.
tempararily remove the try: exception: and print statements around line 169
then the true error message will show
Chris M
Norbert:
This is fixed and pushed. the tool editor was parsing the comments trying to convert them to floats :)
Thanks for pointing it out.
I tried your tool change button on the tooleditor page - very slick!
( I thought you might do it if I didn't get to it - good work!)
I'm almost ready to add Gmoccapy to master - I sent some questions to you, in a PM
Chris M
27 Feb 2013 22:19 #30650 by karlkec
Replied by karlkec on topic Gscreen - a GTK / Glade / Python based screen
1) I wonder if having Gscreen look for 'continuous' in the INI file, under INCREMENT=. Then you could put it anywhere you want....
Chris M
That would work fine. Thanks.
Karl
28 Feb 2013 05:04 #30662 by newbynobi
Replied by newbynobi on topic Gscreen - a GTK / Glade / Python based screen
2. If an axis moves such that another digit is needed in the DRO display, it seems the width of the axis select buttons and width of the <Absolute> and <Relative> columns change to balance things horizontally. This works nicely unless the axis is sitting at a transition point. For instance, if it's at 10.0000, servo and encoder uncertainty can make it jump back and forth between 9.9999 and 10.0000. The constant changing in width of the axis select buttons and the <Relative> and <Absolute> columns is a bit annoying. Could these columns be made fixed width yet allow room for the largest expected DRO values?
Chris,
just make the frame a fixed size, than it will not jump any more, may be you take a look on gmoccapy, I realized it that way.
Norbert
28 Feb 2013 22:22 - 01 Mar 2013 02:50 #30684 by tjamscad
Replied by tjamscad on topic Gscreen - a GTK / Glade / Python based screen
Chris,
On the restart at line I would prefer to just enter a line number. the UP and Down button works but If I want to start at line 1000 that is alot of button taps.
I noticed the updated screen shot of the DTG and Homing marks. Is that still being worked on or has it been pushed?
Last edit: 01 Mar 2013 02:50 by tjamscad.
01 Mar 2013 10:42 #30706 by cmorley
It is a sample and has not been pushed - is that all right looking?
I am working on the restart entry widget - I just noticed you can't enter a line number.
i will have it pop up with the last run line.
Chris M
01 Mar 2013 21:11 #30716 by tjamscad
Chris M
Yes that looks fine. I wonder how messy it gets with more than three axis's? The most our mills are running is 5 but I know we have a 8 or 9 axis tool grinder that stuarts want to put LinuxCNC on.
02 Mar 2013 17:54 #30755 by ditechcnc
Replied by ditechcnc on topic Gscreen - a GTK / Glade / Python based screen
hello all
i am using gscreen lathe config.
its perfect
but
tooloffset error
i am adding z axis value
the popup error msg come
BAD CHARACTER Y USED
what can i do
02 Mar 2013 18:27 #30756 by newbynobi
Hallo,
I just checked the behavior with the newest push.
I can not reproduce the error you mentioned.
Do you have the latest version?
Can you explain exactly what you are doing?
Norbert
02 Mar 2013 19:35 #30758 by ditechcnc
i am using
LINUXCNC - 2.6.0-pre0-3876-g3bf98ee
i am still facing a z axis tool offset problem
02 Mar 2013 19:47 #30760 by newbynobi
Please descripe exactly the way to reproduce the error, step by step.
Time to create page: 0.287 seconds
