Gscreen - a GTK / Glade / Python based screen
13 years 6 months ago - 13 years 6 months ago #32303 by newbynobi
Halo Chris,
I just took a short look on the code. Wouldn't it be better to include:
initialize_keybindings(self):
in
def initialize_preferences(self):
instead of having it "stand alone" ?
So we are more flexible and a user is able to overide with it's own handler file.
As far as I can see from now, it will be necessary for nearly every future custom GUI based on gscreen, because the widgets will mostly have there own names.
I do hope, I don't insult you, if I say I am very unhappy with the internal names of the gscreen widgets, because they mostly don't represent the funktion to execute. button_0_1 is not so easy to understand as btn_enable_jog. This is the reason I renamed 99% of the widgets.
I hope to get a little time this evening to test, but I first have to actualize the DOKU of gmoccapy.
Norbert
Last edit: 13 years 6 months ago by newbynobi.
13 years 6 months ago #32305 by tjamscad
cmorley wrote: Tjamscad
No I haven't pushed it yet.
Is having the keyboard on that side ok? or should the regular vertical gscreen buttons be on the right of the keyboard?
Chris M
Yes that side is ok. It is a great idea to make it selectable in the prefferences ar Rick has asked for. Maybe even better than that would be a prefferences for position as well as shown or not shown.
13 years 6 months ago #32310 by LAIR82
How would you go about unlinking the cycle start button on the screen and making it an output signal? I'm sure something in the handler file, which for me currently is like trying to get an infant to fly the space shuttle.
With a little direction on this I would like to dabble with this one. I think its not specific to our requirements but I need to learn this stuff sooner than later so why not start now.
Reason I ask is we have our other machine setup with some inhibit signals. I have a python screen as part of my AXIS interface, with cycle start, feed hold, and cycle stop buttons, all just having a hal output bit going to my ladder so I can control start permissions. We did it this way so if something is not proper you cannot start an NC program, and if you are already in the middle of running a program, it will let the program finish and not be able to be restarted. This way your not making unnecessary E-Stops, and ruining parts for no reason.
Rick
13 years 6 months ago #32334 by cmorley
newbynobi wrote: Halo Chris,
in
Yes that's why I said it was experimental :) I was in a hurray. I need to think about how to handle an INI selection process, but wanted to be sure the keybindings actually work.
Norbert
I'm not insulted.
Yes button_v0_1 was the original idea of defining buttons by position rather then function.
afterwards it became apparent by function was better.
slowly I am changing.
Gscreen is still in development just as Gmoccapy And I really didn't have a detailed plan.
Chris M
13 years 6 months ago #32335 by cmorley
Chris M
Well what I think is reasonable to support is a good default position and a way to disable Onboard.
To move it's position is always possible using a modified GLADE file.
Chris M
13 years 6 months ago #32337 by cmorley
LAIR82 wrote: How would you go about unlinking the cycle start button on the screen and making it an output signal? I'm sure something in the handler file, which for me currently is like trying to get an infant to fly the space shuttle.
Rick
This is not too hard - I think :)
It requires you to modify the GLADE file.
One consequence of that is anytime Gscreen is updated, you need to update the glade file again (assuming it changed in the update)
If I add a couple HAL pins to Gscreen then you won't need a handler file.
I assume you want the Start button to stay on screen and work but go through your ladder program.
You need to change the start button from the existing toggle button to a HAL regular button.
This means it will have a HAL pin that toggles as it's pressed.
connect this to your ladder.
Then you need a HAL pin to send the start command.
While you can do this in the handler file, what I can do is add the pins to Gscreen so you only have to connect to them.
Hopefully that's all it will take...
I'm sure you will need more detail...
Chris M
Time to create page: 0.355 seconds
