- Thank you received: 394
I wonder if this is because you are trying to use data.estopped before the periodic is turned on?
you could check the task state directly through
self.gscreen.emc_status.emcstat.poll()
estop = self.gscreen.emc_status.task_state == self.gscreen.emc_status..emc.STATE_ESTOP
Hope I got that code right...
There may be other ways - I just don't have time to check sorry.
Hallo Chris,
I found ot that it must be:
Code:self.gscreen.status.emcstat.poll() estop = self.gscreen.status.emcstat.task_state == self.gscreen.status.emc.STATE_ESTOP
to get the correct value.
But I am asking myself, when will periodic begin to run?
I checked the state of self.data.estopped now on_window1.realize() and do get the wrong value. If I get it directly with the code you gave me, I get the correct value.
Should this be corrected in the feature? By running the first periodic from gscreen bevor starting the gui?
Norbert
Norbert
