Gscreen - a GTK / Glade / Python based screen
12 years 9 months ago #43111 by newbynobi
Replied by newbynobi on topic Gscreen - a GTK / Glade / Python based screen
Halo Chris, halo Jim,
item 1.
could that help?
walk through cells with tab
may be in connection with:
glib connect bevore
item 2 and 3:
This seems to be gmoccapy issues, let me check on that
item 4:
I don't see the need for that at the moment. I have the idea to include in gmoccapy an toll edit dialog, what will also include small icons for the tool, information about cut length and no. of flutes and so on, as some of the information will be needed by shopfloorpro. When I really do that, I may include lathe tool diagrams.
item 5:
Jim: I do not understand what is wrong? All the information is visible and the columns are named accordingly?
item 6 and 7:
I would like that one too, no check boxes, only unique selection and a click on each cell will highlight the row.
Norbert
12 years 8 months ago #43537 by LAIR82
Hello Guys,
Our third Turning center is up and running now for about 3 weeks, all three using gscreen industrial,
The shop supervisor noticed something on this build that the up, down arrow keys do not work while in edit mode, making it a little interesting trying to make multiple edits to a long program.
Any Ideas? Maybe something on my end?
Thanks Rick
12 years 8 months ago #43539 by andypugh
Replied by andypugh on topic Gscreen - a GTK / Glade / Python based screen
LAIR82 wrote: The shop supervisor noticed something on this build that the up, down arrow keys do not work while in edit mode, making it a little interesting trying to make multiple edits to a long program.
Any Ideas?
It sounds like the arrows are being captured as jog commands by the GUI rather than being passed on to the system.
At a guess it is something in git.linuxcnc.org/gitweb?p=linuxcnc.git;a...33d76c802143;hb=HEAD
but possibly the generic GladeVCP key-forwarder: git.linuxcnc.org/gitweb?p=linuxcnc.git;a...f9fb95c95731;hb=HEAD
12 years 8 months ago #43829 by LAIR82
So if I went into this file,
[linuxcnc.git] / src / emc / usr_intf / gscreen / keybindings.py
and modified
45 self.Up = 'YPOS'
46 self.Down = 'YNEG'
47 self.Left = 'XPOS'
48 self.Right = 'XNEG'
to something along the lines of
45 self.Up = 'cursor up'
Would that change the outcome and make the cursor move up, down, left, and right?
Or am I out in left field? ( left field in a different ball diamond probably)
Rick
12 years 8 months ago #43842 by cmorley
Replied by cmorley on topic Gscreen - a GTK / Glade / Python based screen
LAIR82 wrote: So if I went into this file,
and modified
45 self.Up = 'YPOS'
Rick
No.
The self.Up = "YPOS" sets 'Up' (that's the key - the cursor up key) to a binding called YPOS and YPOS calls 'on_keycall_YPOS'
which is a function to move the Y axis in the positive direction.
It's not clear to me what you are trying to do. You want to move a cursor with the cursor keys ? Do you mean the mouse pointer?
Chris M
12 years 8 months ago - 12 years 8 months ago #43844 by cmorley
Sorry I missed the posts above your question.
Andy is right keyboard jogging is stealing the cursor keys.
in Gscreen look for
def on_key_event(self,widget, event,state): CNTRL = SHIFT = ALT = 0 keyname = gtk.gdk.keyval_name(event.keyval) print("Key %s (%d) was pressed state: %d last: %s" % (keyname, event.keyval,state, self.data.key_event_last)) if event.state & gtk.gdk.CONTROL_MASK: CNTRL = 1 self.verbosely_print("Control was being held down") if event.state & gtk.gdk.MOD1_MASK: ALT = 1 self.verbosely_print("Alt was being held down") if event.state & gtk.gdk.SHIFT_MASK: SHIFT = 1 self.verbosely_print("Shift was being held down") if keyname in( "Shift_L","Shift_R"): return True # ignore shift key press if self.data.key_event_last[0] == keyname and self.data.key_event_last[1] == state : return True self.data.key_event_last = keyname,state try: method = self.keylookup.convert(keyname) if method: try: self.handler_instance[method](state,SHIFT,CNTRL,ALT) return True except: self[method](state,SHIFT,CNTRL,ALT) return True except: self.show_try_errors()
Remove the 'True' after the 'return' (all of them) and test.
Do you use any of the keyboard controls?
Chris M
Last edit: 12 years 8 months ago by cmorley.
Time to create page: 0.278 seconds
