- Thank you received: 2181
Gscreen - a GTK / Glade / Python based screen
12 years 10 months ago #42144
Replied by cmorley on topic Gscreen - a GTK / Glade / Python based screen
Glad your figuring it out.
let me know of anything I can help with and don't forget to post a pic once in a while
Chris M
Chris M
12 years 10 months ago #42146
I see why the jog increments are not updating - I pushed a fix.
If you are using a custom glade file you will need to update it manually.
the labels for jogs are:
jog_increments
angular_jog_increments
jog_rate
angular_jog_rate
Chris M
jog_increments
jog_rate
angular_jog_rate
Chris M
- LAIR82
- Thank you received: 3
12 years 10 months ago - 12 years 10 months ago #42208
by LAIR82
Replied by LAIR82 on topic Gscreen - a GTK / Glade / Python based screen
I pulled that fix, now the increments work great. Thanks
But now I am back to trying to get the screen filled out again. I went into the glade file and clicked expand on all three boxes you mentioned and I keep getting a fault when trying to start up. I must have clicked/selected something else the other day when I actually got it to work. I will press on tomorrow and see if I can remember what I did.
Guess I need to start actually taking notes down on how I manage to stumble across making things work properly.
Rick
Rick
Last edit: 12 years 10 months ago by LAIR82.
- LAIR82
12 years 10 months ago #42249
by LAIR82
12 years 10 months ago #42251
The widget 'dro_x1' s missing from the glade file
dro_x1 is the HAL_DRO widget for displaying the absolute X axis
Maybe you deleted it?
- LAIR82
12 years 10 months ago #42253
by LAIR82
It only says that when I select expand in glade on the 3 items you said to click on to expand the left side to fill in the gap at the bottom where the onscreen keyboard would be.
I moved a fresh copy of the file into my config, tried again and it says the same thing.
Time to create page: 0.684 seconds
