Screen shots of gui designs
- JohnnyCNC
- Thank you received: 115
14 Feb 2021 18:50 #198825
by JohnnyCNC
Replied by JohnnyCNC on topic Screen shots of gui designs
I'm using QTDragon Dark and I love it. I modified it to handle Inch/MM everywhere based on the ini setting. I'm using a 1920x1080 touch screen. I lowered the resolution so that the current version fills the screen. I'll be looking forward to trying this.
- persei8
- Thank you received: 133
14 Feb 2021 20:25 #198836
by persei8
Replied by persei8 on topic Screen shots of gui designs
This version correctly displays units according to machine units and changes them dynamically when g20 or g21 is used. Feedback on any bugs is appreciated.
- JohnnyCNC
14 Feb 2021 22:05 #198860
by JohnnyCNC
Thanks Jim.
- Thank you received: 7488
14 Feb 2021 22:22 #198868
Replied by tommylight on topic Screen shots of gui designs
+1Thanks Jim.
- APaulsen
21 Feb 2021 16:04 #199633
by APaulsen
Replied by APaulsen on topic Screen shots of gui designs
What about cool softwares for it. I found this one called MD Python(labdeck.com/python/) and it's essentially an advanced VisualTk. A drag and drop Designer but with lots more components and doesn't have glitches like VisualTK.It's free but its got a limited amount of use. The unlimited version MD Python Designer is £15(labdeck.com/python-designer/) and if it interests you, I suggest you check out the GUI Designer( labdeck.com/python/python-gui-designer/) before anything.
- mkose
09 Mar 2021 17:48 #201573
by mkose
Replied by mkose on topic Screen shots of gui designs
Hello, I am interested in gmoccapy, if I ask, can you help me to write the articles in English on the button in my language? I also want to add another button or something. I could easily do this while working with Mach3, but after I switched to Linuxcnc, I was surprised because it was a topic I did not know ... Thanks in advance ..
09 Mar 2021 19:36 #201588
What is your language?
I think that you just need to make a copy of one of these files:
github.com/LinuxCNC/linuxcnc/tree/master/src/po/gmoccapy
named after your own language, and then change the second string in each section.
Replied by andypugh on topic Screen shots of gui designs
- newbynobi
- Thank you received: 394
09 Mar 2021 21:40 #201604
by newbynobi
Replied by newbynobi on topic Screen shots of gui designs
Gmoccapy is translated to German, English, Hungarian, French, spanisch, Serbian and Chinese
I woul be glad if you translate to an additional language. Just tell me witch language an will prepare the translation file for you. After translating, just send it back to me and I will integrate that one in LinuxCNC so it will be available for all users.
Norbert
Norbert
The following user(s) said Thank You: mkose
- mkose
10 Mar 2021 20:21 #201699
by mkose
Hi newbynobi, I would be grateful to you for this, I also recommend Gmoccapy in all cnc installations I go to, but they urge me to install Mach3 due to the TURKISH interface I prepared for Mach3, especially since it is not in TURKISH ... Therefore, I need to convert the interface to our language, TURKISH. Thank you in advance for your help.
- mkose
10 Mar 2021 20:24 #201701
by mkose
TURKISH
TURKISH
The following user(s) said Thank You: newbynobi
Time to create page: 0.206 seconds
