- Thank you received: 11
tome wrote: How does one use this in Imperial mode? I went through the .ngc files and change G21 to G20 but the DRO display is still in metric
It doesn't actually have an Imperial mode.
You _can_ type "in" after any number and it automatically converts the number to mm. But I suspect that isn't the solution you want.
I think that the most expedient way to change the DRO units is to open lathemacro.ui in a text editor and find/replace allwithCode:<property name="display_units_mm">True</property>Code:<property name="display_units_mm">False</property>
Yes, both turning and boring have optional taper and run-out radius.Davenc wrote: 1) Was wondering if the boring option also does internal taper and if the turning option does OD taper?
No, there is no rpm meter in the layouts. As the routines all run at constant surface speed there isn't much to be gained from one.2) Is there an RPM meter in the GUI? I haven't been able to locate screen shots of total GUI interface to be able to tell.
