Lathe Macros
10 years 4 months ago - 10 years 4 months ago #75512 by BigJohnT
Replied by BigJohnT on topic Lathe Macros
I have isolated digital potentiometer intended for spindle control at my store.
Jt
Last edit: 10 years 4 months ago by BigJohnT.
10 years 4 months ago #75542 by RotarySMP
Replied by RotarySMP on topic Lathe Macros
Thanks Andy and JT,
I have a spindle encoder already installed and working. I was just dry running the controller away from the machine, getting to know it.
Mark
10 years 2 months ago #78505 by oscarconde6
Replied by oscarconde6 on topic Lathe Macros
Hello everyone, I am new to the forum, I am Spanish and I have to translate to speak here, to thank the people who do these jobs are very good.
I read a lot of information these last weeks to motorize my around with linux cnc and it seems that I managed to move with a TB6560 and two step-step motors card, yet not I have encoder for the spindle but I'm starting. I linuxcc 2.7.0 and I installed lathemacros3 as I read in the download but when pressed the play and accept the tool lathe makes the first political movement and then stays in play but not continuous, took several days and do not get a solution my level of programming is very low, someone could help me, thank you very much, have if you understand me with this translation,
10 years 2 months ago #78509 by andypugh
Replied by andypugh on topic Lathe Macros
If you don't have a spindle encoder then you will need to edit the G-code routines to not use Constant Surface Speed or Feed-per-revolution G-codes. And you will not be able to thread.
But that's just G-code, and you need to learn that to do CNC
10 years 2 months ago - 10 years 2 months ago #78541 by Rick G
Replied by Rick G on topic Lathe Macros
Might want to look here...
forum.linuxcnc.org/forum/lathe-subroutines-library
Some of the subs such as
forum.linuxcnc.org/forum/lathe-subroutin...26977-odtaper-lathe3
Do not use constant surface speed so may run for you and serve as a starting point.
Rick G
Last edit: 10 years 2 months ago by Rick G.
10 years 2 months ago #78548 by oscarconde6
thanks for the quick reply, do what you tell me I will try to learn a little more and forums have mirare I can do. I'm one. little lost with the codes g. Thank you
Time to create page: 0.442 seconds
