- Thank you received: 358
Lathe Macros
7 years 8 months ago #127268
by pl7i92
Replied by pl7i92 on topic Lathe Macros
is the First post Still the Uptodate Zip File to get it working on Stretch and 2.7.14
7 years 8 months ago #127270
For Axis, yes. Later on in the sequence there is a version without a run button intended for Touchy. (and possibly other user interfaces)
Replied by andypugh on topic Lathe Macros
pl7i92 wrote: is the First post Still the Uptodate Zip File to get it working on Stretch and 2.7.14
7 years 4 weeks ago #146936
by Scot
Replied by Scot on topic Lathe Macros
Very cool. I used to run a system that I put together that used a touch screen. They're awesome. One day, maybe.
6 years 9 months ago #155768
by mooser
Replied by mooser on topic Lathe Macros
Cool
I was hoping to find something like this (would have been handy earlier today when I had to bore a pulley out from .75" up to 1.765
I downloaded the zip file attached to the first post (as far as I can tell after reading through the thread that seems to be the latest update location) and installed on just a simulator (lathe.ini in the configs sim.axis folder there)
The tab shows and I can enter values etc but the run button isn't active (seems greyed out)
Is there some other bit that needs to be installed before the macro can actually run? (linux and linuxcnc newbie here)
Also, watched the video and re-looked at the screens and I can't see what would set the depth of cut for each pass... Maybe that will be obvious when I get the actual macro to run
Thanks in advance
M
Thanks in advance
M
6 years 9 months ago #155772
by mooser
OK, found what I think I was doing wrong, machine needs to be "homed", now at least the button lights.
Got that error
EOF in file:/usr/share/axis/images/axis-lathe.ngc seeking o-word: o<turning> from line: 0
I needed to add the subroutine path to the lathe.ini file
Seems like it's functioning now. Need to get it into imperial units and try it on the actual machine
Thanks for writing this and putting it out there
M
Got that error
M
6 years 2 months ago #178301
by Hodge
Replied by Hodge on topic Lathe Macros
These are fantastic!
Time to create page: 0.460 seconds
