- Thank you received: 15
ZincBoy wrote: So I got it mostly working. The start button still doesn't show up, but pressing where it should be starts the macro anyway.
andypugh wrote: The answer might be to open the UI in Glade, right-click on the button (not the icon, or the table, but the actual button) and select "Add parent". You need something with a "Window" and EventBox counts. If you look at the lathemacro.ui file witha text editor you will see that I had to wrap the other buttons in eventboxes to make them show in the GUI. (Look at line 896 for an example)
ZincBoy wrote: What program did you use for the SVG graphics?
newbynobi wrote: could you please publish the modified UI file.
So I do not have to do the same work as you
Norbert
