Lathe Macros
4 years 4 months ago #245179
Replied by andypugh on topic Lathe Macros
The macros are going to need reworking for GTK3, so I will try to look at keeping the popup on top at the same time.
I will probably re-visit the box positioning method at the same time. Currently they are in a transparent, and largely empty, table. Which is a lazy way to handle resizing but does cause problems at smaller sizes.
The following user(s) said Thank You: Muzzer
4 years 4 months ago #245289
by Muzzer
Replied by Muzzer on topic Lathe Macros
Does anyone have any idea why the attempt to add the probe tab didn't work - and in fact even killed off the macros tab?
4 years 3 months ago - 3 years 11 months ago #247195
[EDIT 13/11/22 The files are now published on my Github:
github.com/andypugh/LatheMacros/releases
I have re-vamped the lathe macros for use with GTK3.It now uses features only usable in Python 3.7 , so Buster is fine, but nothing much before that.
Rather than attach a zip file, I think it makes sense to grab the up-to-date version from the repository.
You will need these files:
boring.ngc
chamfer.ngc
drilling.ngc
facing.ngc
grooving.ngc
lathehandler.py
LatheMacro.svg
lathemacro.ui
radius.ngc
threading.ngc
turning.ngc
Then add a line to the INI something like:
From the README:
The "lathemacro" config offers a number of simple macros to perform the most common lathe operations. The GUI that controls the macros can be viewed by clicking the "Cycles"tab top left of the graphical preview window.
There are two load-time options to control the tab behaviour:
1) norun will hide the action button, use this if you want to use only a physical button (connected to gladevcp.cycle-start) to start the macros (Strongly recommended, especially with Touchy)
2) notouch will allow keyboard editing of the spinboxes. Otherwise the custom numeric keyboard will be shown. An example loadrt line, as used here in the Gmoccapy demo is:
[code][DISPLAY]
EMBED_TAB_COMMAND = halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -U notouch=1 -U norun=0 -u lathehandler.py -x {XID} lathemacro.ui
The window will resize slowly if you grab the corner and move the mouse inside the window. It's not as bad as it was, but still needs work. You may need to click the unmaximise button in the toolbar to get a window border to be able to use the resize handles. If this is troublesome then you can replace alloc.height and alloc.width in line 53 of lathehander.py with a fixed size
Notes on the keyboard:
As well as the obvious functions and unit conversions, it can be used to enter fractions. For example if you type 1.1/2 it will automatically update to display 1.5000 and 16.17/64 will show 16.2656. This can be used in a limited way to halve the onscreen value eg for entering radius instead of diameter. However it only works for whole numbers: 100/2 will become 50 but 3.14149/2 is interpreted as 3 and 14 thousand halves so won't work.
Notes on adding your own cycles:
Create a new G-code subroutine in the same format as the existing ones.
In Glade add a new tab to the 'tabs1' notebook and give it a name matching the new cycle.
Edit the action button (inside an eventbox) to call the new G-code sub.
Rename the action button to match the tab name and append '.action' eg MyCycle.action
Create new artwork. I used Fusion360, the models are here:
a360.co/3uFPZNv
and the drawings are here:
a360.co/3uFPZNv
Export the drawing page as PDF and import into the lathemacro.svg file in Inkscape. You will need to resize. Add your own arrows and annotations. Save the new layer in a layer named "layerN" (lower case) where N is the tab number, starting at zero. You will need to invoke the XML editor for this (Shift-Cmd-X on Mac) The entry boxes are positioned relative to a 1500 x 1000 image; the original size of the SVG. So you can hover your mouse over the image in Inkscape to determine the coordinates. In the case of on-drawing controls the coordinates are entered as an XML comment in the Tooltip for the control in x,y format (The surface speed, tool and coolant do not need this, they are in a fixed table) An example:[code]<!--300,711-->Peck distance Make sure the comment has "use markup" selected for the tooltip. Also ensure that the control has the "show_keyb" function allocated for the Widget -> button_press event. If you copy-paste a tab and copy-pasteextra controls this should be automatic. _All_ your new spinboxes will need their own new Adjustment, or they will change value when you alter the original spinbox that they are a copy of.
boring.ngc
chamfer.ngc
drilling.ngc
facing.ngc
grooving.ngc
lathehandler.py
LatheMacro.svg
lathemacro.ui
radius.ngc
threading.ngc
turning.ngc
[DISPLAY]EMBED_TAB_COMMAND = halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -U notouch=1 -U norun=0 -u lathehandler.py -x {XID} lathemacro.ui
From the README:
[code][DISPLAY]
a360.co/3uFPZNv
a360.co/3uFPZNv
Last edit: 3 years 11 months ago by andypugh.
4 years 3 months ago #247196
4 years 3 months ago #247200
by arvidb
So "1.1/2" would become 0.55 and "1+1/2" would become 1.5.
Anyway, great work with the macros! Looks very useful!
Replied by arvidb on topic Lathe Macros
Now that's a weird and surprising behaviour! Is there a rationale for it? If I'm not mistaken the imperial system normally uses a minus sign to denote addition: e.g. 1-1/2" means one plus a half inch? If the keyboard input supports equations I understand that the minus sign cannot be used that way. But why redefine the decimal point to mean plus? That makes no sense. Why not simply use a plus sign?Notes on the keyboard:
4 years 3 months ago #247218
Yes, it doesn't mean finding somewhere on the keyboard for an extra button that only means "fraction follows"
I thought about using / twice, so that 1/1/2 would be 1.5 and maybe that could work. I initially thought that it might be ambiguous under some circumstances but maybe not, as the denominator is always even and the numerator is almost always odd. You almost never use 2 - 2/8, though it isn't actually wrong as such.
Time to create page: 0.341 seconds
