Lathe Macros
4 years 1 month ago #253093 by virencq
Replied by virencq on topic Lathe Macros
Yes, it's working on PC.
I am using Raspberry PI 4 for my lathe here it's not working.
I have installed RSVG too.
4 years 1 month ago #253095 by andypugh
Replied by andypugh on topic Lathe Macros
What isn't working? What error messages do you see (you might have to start LinuxCNC from the command "linuxcnc" to see them)
4 years 1 month ago - 4 years 1 month ago #253102 by virencq
Macro Image not showing.
Below is the error message from the terminal.
File Name: Lathe_macro_error.txt
File Size:4.84 KB
Last edit: 4 years 1 month ago by virencq.
4 years 1 month ago #253106 by andypugh
**** GLADE VCP ERROR: With xml file: lathemacro.ui : could not create GladeXML object
Which version of libglade do you have installed? You could see if Synaptic has an update to offer.
4 years 4 weeks ago #253239 by virencq
Checked libglade is updated.
What else to check
4 years 4 weeks ago #253269 by andypugh
Can you open the .ui file directly in the Glade editor?
The following user(s) said Thank You: virencq
Time to create page: 0.195 seconds
