Thanks very much for the reply, made a tiny bit of progress and managed to clear one of the path errors by creating a macros folder in the config for the test_lathe.
Still not getting anywhere and im suspecting it could be an issue with glade? i have 3.38 ive found 3.40.0 but cant figure out how to install it as its a .tar.xz that i think is just an archive? i followed the readme install examples "apt get install" just gets 3.38 again and the manual option fails due to
Checking for function [code] "_gtk_widget_class_template_unset_only_for_glade" with dependency gtk+-3.0: NO
Couple of things i notice in the terminal dump, but dont really know what they mean.
[code](gmoccapy:185966): Gtk-CRITICAL **: 22:38:06.676: gtk_entry_set_text: assertion 'text != NULL' failed
0 = /usr/bin/gmoccapy
1 = -ini
2 = /home/neil/linuxcnc/configs/lathe_test/lathe_test.ini
[code].....g-file-error-quark: Failed to open file “lathemacro.ui”: No such file or directory (4)
**** GLADE VCP ERROR: With xml file: lathemacro.ui : 'gi.repository.Gtk' object has no attribute 'glade'
<commandline>:0: gladevcp exited without becoming ready
[/code][/code][/code]
