Lathe Macros
4 years 5 days ago #255176 by andypugh
Replied by andypugh on topic Lathe Macros
I would guess that /usr/lib/python3/dist-packages/gladevcp is the important one.
The question then is how it gets there on OPi but not on RPi.
What was the install method on each platform?
4 years 4 days ago #255365 by virencq
Replied by virencq on topic Lathe Macros
I used Elovalvo's 64-bit preinstalled Linuxcnc image in RPi.
I have a spare Rpi3B, I installed Raspbian Bullseye 64 bit then Install linuxcnc-uspace-dev_2.9.0~pre0_arm64.deb.
I checked my config with macros. all work straight out of the box.
Also /usr/lib/python3/dist-packages/gladevcp well intact.
3 years 11 months ago #256540 by Masiwood123
Replied by Masiwood123 on topic Lathe Macros
Hi Andy,why is the screen blank, I pasted as it was said in the readme(lathe macros-3.zip)..maybe I have to insert ini lathe mode=true?..otherwise my configuration is for 4 axis but everything exists on the lathe
3 years 11 months ago #256542 by andypugh
Start linuxcnc from the command-line (the command is just "linuxcnc" and see if there is any useful information about what is going wrong.
The following user(s) said Thank You: Masiwood123
3 years 11 months ago #256543 by Masiwood123
Thank you will try tomorrow
3 years 11 months ago #256568 by Masiwood123
if i load correctly, this is reported to me via the linuxcnc`` command. like some duplication of gladevcp.
Time to create page: 0.440 seconds
