Lathe Macros
4 years 2 weeks ago - 4 years 2 weeks ago #254357 by Thompo
Replied by Thompo on topic Lathe Macros
thanks Andy i tried to get the dev version here
http.us.debian.org/debian/pool/main/l/linuxcnc/
but it comes up saying already installed.
I cant open any .ui files, i get the same error in glade
"The following required catalogs are unavailable: gladevcp"
Looking at the .ui file, im guessing line 5 is my problem?
Completely green to all this so im finding it tough going, would i be better creating a post elsewhere so as not to pollute this thread?
###EDIT!!!###
i just seen your bit about trying the sim/Axis options and they seem to work ok, but the gmocappy lathe_macro simulation, displays the tab in the main window but stays on the main screen when clicked.
Last edit: 4 years 2 weeks ago by Thompo.
4 years 2 weeks ago #254363 by andypugh
Replied by andypugh on topic Lathe Macros
You could try deleting that line from the .ui file. (It is commented out in the sample files)
The following user(s) said Thank You: Thompo
4 years 2 weeks ago #254374 by Thompo
Deleting the line <requires lib="gladeui" version="0.0"/>
Glade opens without error but im not sure it looks correct once inside? Im expecting to see a series of graphics that contain the textbox inputs that feed the macros? but im not sure if linuxcnc generates these when it runs?
Im sure this is something simple and most likely user error :side:
4 years 2 weeks ago #254375 by andypugh
Glade is not finding gladevcp.
(Nor is LinuxCNC)
It looks like you can add it to glade (but that might not help LinuxCNC)
4 years 2 weeks ago #254376 by andypugh
(But if you can find one under Python3, definitely use that one)
4 years 2 weeks ago - 4 years 2 weeks ago #254469 by Thompo
Success i think...
Removed and reinstalled linuxcnc got an error with ref to "gi.require_version('Rsvg', '2.0')"
Found this, while searching for help wth it  stackoverflow.com/questions/10393675/rsv...python-3-2-on-ubuntu
Ran this
[code]sudo apt-get install gir1.2-rsvg-2.0 python3-cairo python3-gi Which installed this gir1.2-rsvg-2.0:amd64 (2.52.5+dfsg-3)
90% sure that was installed previously but might have been on a previous attempt
And it worked :D
Now i just have to replicate the lathe_macro sim on my setup then move the PC back out the shed and see if the lathe runs.
Thanks for your assistance[/code]
Time to create page: 0.477 seconds
