qtvcp issues
11 Jul 2018 08:12 #114001
by Ilya
qtvcp issues was created by Ilya
Hello,
I want to gradually move from mach3 to linuxcnc.
I often have to change the interface for different clients.
I am interested in using qtvcp which develops ChrisMorley because it suits me perfectly
I'm new to programming and using linuxcnc, so I often have questions.
I had previously asked my questions in this topic , but Chris asked me to create a separate one.
Thanks,
Ilya
Thanks,
Ilya
11 Jul 2018 08:16 #114002
by Ilya
Replied by Ilya on topic qtvcp issues
At the moment, after the transition to branch qt5_vcp_cleanup I was faced with the problem:
Before that, everything worked well. But now FileDialog does not open the control program.
The terminal displays:I could not solve this problem on my own. So I hope for help
File "/home/ilya/qt5-linuxcnc/lib/python/qtvcp/widgets/dialog_widget.py", line 245, in <lambda>
STATUS.connect('load-file-request', lambda w: self.load_dialog())
File "/home/ilya/qt5-linuxcnc/lib/python/qtvcp/widgets/dialog_widget.py", line 272, in load_dialog
self.PREFS_.putpref('last_file_path', path, str, 'BOOK_KEEPING')
AttributeError: 'NoneType' object has no attribute 'putpref'
11 Jul 2018 12:21 #114007
Replied by cmorley on topic qtvcp issues
Is this with the demo screen or a screen you designed?
If it is your design than please check there is a screenoptions widget added.
Screen options sets up the preference file and other things - it will add nothing visually.
I should add code to not crash if there is no preference file. It uses it to remember what folder you were in last.
Please let me know if that helped
Chris M
Chris M
The following user(s) said Thank You: Ilya
11 Jul 2018 14:12 #114009
by Ilya
Yes, it helped
This was my screen and I didn't add the screen option.
The demo screen worked at this time.
I want to ask about slots and signals, to run small python scripts.
Thank you for helping me, I am very grateful to you!
12 Jul 2018 02:29 #114038
You can use signals and slots to connect widgets to python code.
The sample qt_800x600 uses signals and slot for some of it's widget controls.
( though I see it is sorta broken - i forgot to change the [DISPLAY] entry in the INI file to reflect the name change from qtscreen to qtvcp)
Have you added a handler file in your config folder?
You need to connect signals to the MainWindow and add the function names you would like, then add those functions to your handler file.
I can give more details if you like - I'll try to add some detail about it in the docs.
Chris M
Chris M
12 Jul 2018 13:58 #114059
by Ilya
That would be wonderful!
12 Jul 2018 21:00 #114086
it would help to know what linux distribution you are using -
I'll assume debian stretch but there are only little differences.
When you have loaded your screen into designer add a plain button to the screen.
You could change the name of the button to something interesting like 'test_button'
There are two ways to edit connections - I will show the 'graphical' way
There is a button on the top for editing signals.
After pushing it, if you click-and-hold on the button it will show a arrow (looks like a ground signal from electrical schematic)
Slide this arrow to a part of the main window that does not have widgets on it.
A 'Configure Connections' dialog will pop up.
The list on the left are the available signals from the widget.
The list on the right is the available slots on the main window and you can add to it.
Pick a signal, say 'clicked()' - this makes the slots side available.
click 'edit' on the slots list.
A 'Slots/Signals of MainWindow' dialog will pop up.
On the slots list at the top there is a plus icon - click it.
you can now edit a new slot name.
Erase the default name 'slot()' and change it to say test_button()
press the ok button.
You'll be back to the 'Configure Connections' dialog.
now you can select your new slot in the slot list.
then press ok and save the file.
Now you must add the function to the handler file.
The function signature is 'def slotname(self):'
We will add some code to print the widget name.
So from our example:
in you handler file (if you copied it) there is a section named:
In fact it doesn't matter where you put the commands but by convention this is where to put it.
add the code and save it.
If all went well, after you run your screen now, when you push your new button it will print the button name in the terminal.
Chris M
def test_button(self):
name = self.w.sender().text()
print name
# callbacks from form #
Chris M
17 Jul 2018 07:40 #114354
Have you had success?
Any feedback on the project?
Chris M
Chris M
17 Jul 2018 12:02 - 17 Jul 2018 12:03 #114367
by Ilya
I was temporarily going back to using Axis, to adjust the angular axes.
Your tutorial on signals and slots helped me. Thank you!
I need three buttons for fixed moves: the First to move X and Y to zero. The second to move Z to"N". The third is to move X to" N", Y to" N "and Z to"N".
The sketch
I'm not happy with my implementation yet, but it's working. Maybe it could have been done in a more correct way
I took your header file as a basis - tester_handler.py
Thanks,
Ilya
* The text on the button "Парковка"[Parkovka] - translated as Parking
The sketch
# **** instantiate functions section **** #
X = Y = Z = Z_only = 0
def validation_qle(define): #delete invalid chars
b = 0
edited_text = ''
chars = ['1','2','3','4','5','6','7','8','9','0','.']
text = define.w.sender().text()
if text != '':
if text[0] == '.':
text = '0.'
define.w.sender().setText(text)
for i in text:
if i == '.':
b += 1
if i == '.' and b > 1:
print 'more than one dot'
elif i not in chars:
print 'invalid simbol'
else:
edited_text += i
define.w.sender().setText(edited_text)
def validation_qle_finished(define): #put zero in an empty line
axis = define.w.sender().text()
if axis == '':
define.w.sender().setText('0')
axis = 0
axis = float(axis)
return axis
def ok_for_mdi(define):
define.stat.poll()
return not define.stat.estop and define.stat.enabled and define.stat.homed and (define.stat.interp_state == linuxcnc.INTERP_IDLE)
# **** HANDLER CLASS SECTION **** #
class HandlerClass:
# **** INITIALIZE **** #
# widgets allows access to widgets from the qtvcp files
# at this point the widgets and hal pins are not instantiated
def __init__(self, halcomp,widgets,paths):
self.hal = halcomp
self.lineEdit = QtWidgets.QLineEdit()
self.w = widgets
self.stat = linuxcnc.stat()
self.cmnd = linuxcnc.command()
self.error = linuxcnc.error_channel()
self.PATH = paths.CONFIGPATH
self.IMAGE_PATH = paths.IMAGEDIR
self.STYLE = Styles(widgets, paths)
# Special Functions called from QTSCREEN
# at this point:
# the widgets are instantiated.
# the HAL pins are built but HAL is not set ready
def initialized__(self):
# Give notify library a reference to the statusbar
STATUS.forced_update()
# set custom theme
#self.STYLE.dark_style()
#self.STYLE.bright_style()
self.STYLE.gorelovskiy_style()
KEYBIND.add_call('Key_F3','on_keycall_F3')
KEYBIND.add_call('Key_F4','on_keycall_F4')
KEYBIND.add_call('Key_F5','on_keycall_F5')
def processed_key_event__(self,receiver,event,is_pressed,key,code,shift,cntrl):
# when typing in MDI, we don't want keybinding to call functions
# so we catch and process the events directly.
# We do want ESC, F1 and F2 to call keybinding functions though
if code not in(QtCore.Qt.Key_Escape,QtCore.Qt.Key_F1 ,QtCore.Qt.Key_F2,
QtCore.Qt.Key_F3,QtCore.Qt.Key_F5,QtCore.Qt.Key_F5):
if isinstance(receiver, OFFVIEW_WIDGET) or isinstance(receiver, MDI_WIDGET):
if is_pressed:
receiver.keyPressEvent(event)
event.accept()
return True
if isinstance(receiver,QtWidgets.QDialog):
print 'dialog'
return True
try:
KEYBIND.call(self,event,is_pressed,shift,cntrl)
return True
except Exception as e:
#log.debug('Exception loading Macros:', exc_info=e)
print 'Error in, or no function for: %s in handler file for-%s'%(KEYBIND.convert(event),key)
if e:
print e
#print 'from %s'% receiver
return False
# callbacks from STATUS #
def edited_z_only(self):
validation_qle(self)
def edited_x(self):
def edited_y(self):
def edited_z(self):
def editingFinished_Z_only(self):
global Z_only
Z_only = validation_qle_finished(self)
def editingFinished_X(self):
global X
X = validation_qle_finished(self)
def editingFinished_Y(self):
global Y
Y = validation_qle_finished(self)
def editingFinished_Z(self):
global Z
Z = validation_qle_finished(self)
def mdi_parking(self):
if ok_for_mdi(self):
self.cmnd.mode(linuxcnc.MODE_MDI)
self.cmnd.wait_complete() # wait until mode switch executed
self.cmnd.mdi("G0 Z%f" % Z)
self.cmnd.mdi("G0 X%f Y%f" % (X, Y))
def parking_Z_Button(self):
self.cmnd.mdi("G0 Z%f" % Z_only)
Thanks,
Ilya
Last edit: 17 Jul 2018 12:03 by Ilya.
17 Jul 2018 12:55 - 17 Jul 2018 12:56 #114376
by Ilya
Now I have a problem with the jogincrements widget.
First, if i specify 1mm in the INI file, the axis shifts by 0.001 mm.
The axis is shifted by 1 mm only if the ini file specifies just 1 (without mm).
for example: "INCREMENTS = 1 2 5" or "INCREMENTS = 1mm 2mm 5mm"
Secondly, to go all the way to hold the button on the keyboard until the axis will pass the desired distance.
If you release the button, the axis stops before the specified distance passes.
And also, the manual movements themselves are very slow compared to the Axis interface
I hope I wrote understandably..
Thanks,
Ilya
Thanks,
Ilya
Last edit: 17 Jul 2018 12:56 by Ilya.
Time to create page: 0.240 seconds
