Labview UI project for Linuxcnc
4 years 9 months ago #231727 by auto-mation-assist
It is just a problem when messages get out of sync nothing more. NML expects certain number of bytes for each command. It is not happy when it gets more or less. My code is fine but improvements are always a possibility.
I'm interest in looking at your work but have no idea where I can find it.
4 years 9 months ago - 4 years 9 months ago #231730 by auto-mation-assist
I have been busy cleaning out my development computer. Its running on Linux mint  20.2 now and using the 5.10.0-9-RT-amd64 kernel. The latest Linuxcnc master is installed and compiled without problems.
I'm now working on installing Redis version 6.2.6 in my added depends folder in the source folder of Linuxcnc. The Redis Python module has also been placed in its own folder there. Once this is all done I  will migrate what is needed from my old code. I expect that this will take a while since Linuxcnc appears to have had many changes in the past year.
I ran into a minor issue while working on the makefiles for the addition or Redis and the Python module, when run "make clean" it deletes my nice "depends" folder and all its contents, kind of rude if you ask me. I need overcome this shortly and let Linuxcnc know that these are part of the team and not invaders so that I can get  Redis and the PY module compiled.
In reading back the history of Redis in Linuxcnc it was removed back in 2013 or so. Linuxcnc has been improved since 2013 and so has Redis. But it is has been used for years by Path Pilot with great success even with a much older version of Redis for handling Python transactions. Was removing it a mistake ?
Last edit: 4 years 9 months ago by auto-mation-assist.
4 years 9 months ago #231765 by Reinhard
Really? Well, my both project are right below yours in the same category "Other User Interfaces".
First I worked out the java UI to see, whether I could create an UI following my ideas and the current project is like porting the java UI to Qt and research what is possible with Qt and how to solve Qt's shortcomings.
Actually I'm reworking the linuxcnc-interface, so you could have a look at my project, but interface to linuxcnc will change. Anyway - might be worth a look ;)
4 years 9 months ago #231809 by auto-mation-assist
I have not spent much time in looking at the forum for a long time been very busy working on laying out printed circuit boards a those are now being manufactured.
I found the link in your project to the code and forked you project. Took me a while since it was incorporated in text and not as a separate item. I will look at your code after I get Redis working. Recent Linuxcnc master changes that I'm not familiar with yet are causing a bit of confusion.
4 years 9 months ago #232034 by auto-mation-assist
I have Redis 6.2.6 installed and complied as an addition of Linuxcnc on my develepment system which is running the current Linuxcnc master. I think it will be very useful for routing command, status and other data between Linuxcnc's various blocks of code internally and also externally, not only to Labview but also to other alternatives.
I installed Redis in linuxcnc 2.9 master and compiled it as part of it. After starting Linuxcnc  I opened up two terminal windows from within my Linuxcnc folder (CncMaster) in order to talk to Redis. The below are the results.
Opening the  Redis server :
Open terminal in linuxcnc folder
$ . ./scripts/rip-environment
$ redis-server configs/cnc1/redis_configure/cnc1.redis.conf
From terminal display:
cnc1@cnc1-OptiPlex-9020:~/CncMaster$ redis-server configs/cnc1/redis_configure/cnc1.redis.conf
8941:C 16 Jan 2022 07:03:15.562 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
8941:C 16 Jan 2022 07:03:15.562 # Redis version=6.2.6, bits=64, commit=00000000, modified=0, pid=8941, just started
8941:C 16 Jan 2022 07:03:15.562 # Configuration loaded
8941:M 16 Jan 2022 07:03:15.562 * Increased maximum number of open files to 10032 (it was originally set to 1024).
8941:M 16 Jan 2022 07:03:15.562 * monotonic clock: POSIX clock_gettime
                _._
           _.-``__ ''-._
      _.-``    `.  `_.  ''-._           Redis 6.2.6 (00000000/0) 64 bit
  .-`` .-```.  ```\/    _.,_ ''-._
 (    '      ,       .-`  | `,    )     Running in standalone mode
 |`-._`-...-` __...-.``-._|'` _.-'|     Port: 6379
 |    `-._   `._    /     _.-'    |     PID: 8941
  `-._    `-._  `-./  _.-'    _.-'
 |`-._`-._    `-.__.-'    _.-'_.-'|
 |    `-._`-._        _.-'_.-'    |           redis.io
  `-._    `-._`-.__.-'_.-'    _.-'
      `-._    `-.__.-'    _.-'
          `-._        _.-'
              `-.__.-'
8941:M 16 Jan 2022 07:03:15.563 # Server initialized
8941:M 16 Jan 2022 07:03:15.563 * Loading RDB produced by version 6.2.6
8941:M 16 Jan 2022 07:03:15.563 * RDB age 60 seconds
8941:M 16 Jan 2022 07:03:15.563 * RDB memory usage when created 0.77 Mb
8941:M 16 Jan 2022 07:03:15.563 # Done loading RDB, keys loaded: 0, keys expired: 0.
8941:M 16 Jan 2022 07:03:15.563 * DB loaded from disk: 0.000 seconds
8941:M 16 Jan 2022 07:03:15.563 * Ready to accept connections
Shutting down linuxcnc gives:
8941:signal-handler (1642349593) Received SIGTERM scheduling shutdown...
8941:M 16 Jan 2022 07:13:13.654 # User requested shutdown...
8941:M 16 Jan 2022 07:13:13.654 * Saving the final RDB snapshot before exiting.
8941:M 16 Jan 2022 07:13:13.716 * DB saved on disk
8941:M 16 Jan 2022 07:13:13.716 * Removing the pid file.
8941:M 16 Jan 2022 07:13:13.716 # Redis is now ready to exit, bye bye...
Redis has a command line interpreter (CLI) available.
Starting the Redis CLI, and getting server info and ability to program via the CLI:
Open a terminal in linuxcnc folder
$ redis-cli
$ info server
This is the display from terminal from the info server command:
cnc1@cnc1-OptiPlex-9020:~/CncMaster$ . ./scripts/rip-environment
cnc1@cnc1-OptiPlex-9020:~/CncMaster$ redis-cli
127.0.0.1:6379> info server
# Server
redis_version:6.2.6
redis_git_sha1:00000000
redis_git_dirty:0
redis_build_id:4dfbfc6a1caecbd5
redis_mode:standalone
os:Linux 5.10.0-9-rt-amd64 x86_64
arch_bits:64
multiplexing_api:epoll
atomicvar_api:c11-builtin
gcc_version:9.3.0
process_id:8941
process_supervised:no
run_id:ad17c2616987d8f3e3a3ab1c063db8ae7f4910d5
tcp_port:6379
server_time_usec:1642349330430826
uptime_in_seconds:335
uptime_in_days:0
hz:10
configured_hz:10
lru_clock:14959378
executable:/home/cnc1/CncMaster/redis-server
config_file:/home/cnc1/CncMaster/configs/cnc1/redis_configure/cnc1.redis.conf
io_threads_active:0
127.0.0.1:6379>
CLI does not shut down when linuxcnc terminates so programming work is able to proceed.
Typing help as in the first line below in the CLI gives back the second and following lines:
127.0.0.1:6379> help
redis-cli 6.2.6
To get help about Redis commands type:
      "help @<group>" to get a list of commands in <group>
      "help <command>" for help on <command>
      "help <tab>" to get a list of possible help topics
      "quit" to exit
To set redis-cli preferences:
      ":set hints" enable online hints
      ":set nohints" disable online hints
Set your preferences in ~/.redisclirc
127.0.0.1:6379>
A lot more to do but its running and thus a good start.
4 years 9 months ago #232089 by auto-mation-assist
Reinhard,
I had a brief look at you control code and I'm very impressed. Your code looks extremely well written and very clean. I have attached a basic diagram I generated to help me understand the routing between its various components.
Time to create page: 0.234 seconds
