auto-mation-assist wrote: Its really not my issue alone its more of a issue belonging to LinuxCNC because of extremely limited use and testing of its remote use potential. Some things are just going to require more thought so minor changes can be made to allow every mode of operation and control to work well.
Hm, afaik NML is not a standard, but a well known layer created for linuxcnc, that is part of linuxcnc. That layer uses CMS as interface, which is part of linuxcnc too.rodw wrote: The same goes for Linuxcnc. If its using a documented standard (NML), it needs to stick faithfully to the standard. After all thats what standards are for.
Hm, all UI applications access linuxcnc shared memory - but treat them (I hope so) as readonly.rodw wrote: I totally agree that external programs should not be accessing Linuxcnc's shared memory.
Hm, please help me - where is closed source related to NML?rodw wrote: There is definitely a license problem mixing closed source software with GPL2 code like Linuxcnc.
Reinhard wrote: Hm, please help me - where is closed source related to NML?
If that would be closed source, I wouldn't be able to write my application.
NML isfreely available
NML Availability
– developed by U. S. Government employees as part of their official duties, and not subject to copyright
– source code can be used for any purpose • understanding and debug
• porting to new platforms
• modification for commercialization
– Links to all NML documentation at
www.isd.mel.nist.gov/projects/rcslib/
