- Thank you received: 81
You know the exact location after a call to status channel function, which returns the address. That function needs to be executed only once at runtime. Memory address may change at each start, but is stable during runtime.auto-mation-assist wrote: Knowing the exact location of each items value in the status data ...
No. At least if you want to follow common standards. Many of the status fields are numbers, which have different coding in memory. PC uses little endian and network is known to use big endian.... can make retrieving those values at the remote very efficient.
Then you didn't understand the command channel. It's quite different to status handling.auto-mation-assist wrote: I think that sending individual commands like this, if excepted from a remote would not be very efficient.
Well, I don't understand, why you should want to do such things. There's no need to.I don't yet understand how I can make a control list within LinuxCNC that links every available status item to a specific location in the raw status data.
