On the Huanyang GT series, to turn the motor on, you write 0x01 to register 0x1000. To turn it off, you write 0x05 to register 0x1000.
The docs state "In addition to the pins configured in the definition file, each module will create the following pins for each instance of the driver:"
I find that those HAL pins are not created.
There's something it doesn't like about retval in the rtapi_app_main function.
I am not sure what you mean by that. All that it does is convert HAL pins to Modbus messages and Modbus messages into HAL pins.I'm beginning to think this mesa_modbus component is intended to run as a standalone modbus vfd driver?
