Mesa modbus and pktUart
- Thank you received: 5337
31 May 2025 22:17 #329488
Replied by PCW on topic Mesa modbus and pktUart
7i76eu_7i76x1_pktv2d.bin
Would be the correct firmware
You will also need to update LinuxCNC to the lastest version
sine the hm2_modbus driver is quite new.
- SebastianM
- Thank you received: 3
31 May 2025 22:23 #329489
by SebastianM
Replied by SebastianM on topic Mesa modbus and pktUart
Thx.
Just out of curiosity…
Is there an overview what all those firmwares do / are meant for?
Or how could I have found that out myself?
Regards
Regards
31 May 2025 22:42 - 31 May 2025 22:45 #329490
For configurations with specific daughtercards, the daughtercard
name is included in the file name and you can use the .pin file
to determine the content and pinout of the firmware, for example
the 7i76eu_7i76x1_pktv2d.pin file shows that the configuration
includes a V2 PktUART ( the TX and RX halves )
Last edit: 31 May 2025 22:45 by PCW.
The following user(s) said Thank You: SebastianM
- vre
- Thank you received: 17
15 Nov 2026 22:41 - 15 Nov 2026 22:45 #350736
by vre
Replied by vre on topic Mesa modbus and pktUart
Some example PIN file with pktuart version 3 ?
With old pktuart 25IOC32_PNP sometimes stops and needs to short reset pins on the board to work again.
This problem solved with v3?
Last edit: 15 Nov 2026 22:45 by vre.
Time to create page: 0.247 seconds
