Mesa modbus and pktUart
11 Jan 2025 07:26 #318686 by vre
Replied by vre on topic Mesa modbus and pktUart
No i have 16 I/O as seen in mb2hal config
but in c code have 7 just for test only
Correct is 16 but i dont know if must write it in hex or dec base..
What is correct 0x0f or 16?
From these 2 modules which will work?
grobotronics.com/ttl-to-rs485-module.html?sl=en
or this
www.devobox.com/en/usb-to-serial/1264-ma...o-rs-485-module.html
How to wire pins with 7i80hd?
11 Jan 2025 15:07 #318692 by PCW
Replied by PCW on topic Mesa modbus and pktUart
The RS-485 adapter should work, wiring would be:
PktURDataPin  <= RO
PktUTDataPin   => DI
PktUTNDrvEnPin => DE
GND => RE
Note the N in PktUTNDrvEnPin
(the firmware must be built with this pin in the pinout file to have the
proper drive enable polarity)
Did you look at the relayboard.mod example?
Its probably closer, not for addresses but for bit I/O:
(look an the input definition)
/* Modbus definition file for a 4-channel relay board found on eBay */
The format of the channel descriptors is:
{TYPE, FUNC, ADDR, COUNT, pin_name}
TYPE is one of HAL_BIT, HAL_FLOAT, HAL_S32, HAL_U32
FUNC = 1, 2, 3, 4, 5, 6, 15, 16 - Modbus commands
COUNT = number of coils/registers to read
#define MAX_MSG_LEN 16   // may be increased if necessary to max 251
static const hm2_modbus_chan_descriptor_t channels[] = {
/*  {TYPE,    FUNC, ADDR,   COUNT, pin_name} */
    {HAL_BIT, 1,  0x0000, 8,     "state"},
    {HAL_BIT, 2,  0x0000, 8,     "input"},
    {HAL_BIT, 5,  0x0000, 1,     "relay-0"},
    {HAL_BIT, 5,  0x0001, 1,     "relay-1"},
    {HAL_BIT, 5,  0x0002, 1,     "relay-2"},
    {HAL_BIT, 5,  0x0003, 1,     "relay-3"},
/* Optionally #define DEBUG to aid with troubleshooting.
   Use 3 to see a lot of information about the modbus
   internal workings. 1 is default (errors only)                    */
The following user(s) said Thank You: vre
13 Jan 2025 04:41 #318853 by vre
What is SCFFIFO error ?
13 Jan 2025 15:49 - 13 Jan 2025 16:00 #318871 by PCW
A SCFFIFO error means too many (>16) transmit frames are queued
Perhaps triggered by a xxxx.mod or hal error
It might also be this bug:
 Current Mesa Modbus issues:
    BUGS:
    At startup there can be "call/response function number missmatch"
    error popups or sig11 (segv)s due to the fact that the PKTUART is
    not cleared at startup, so random numbers of garbage characters
    may be present in the RX FIFOs, leftover from the last LinuxCNC run.
    A temporary workaround is to run this before launching linuxcnc:
    mesaflash --device cardname --addr ipaddr --wpo 0x6800=0x00010000
    (writing 0x10000 to 0x6800=pktuartr_mode_reg clears the RX FIFOs)
    If you ever set the update rate to 0 (maximum), changing to a
    non-zero rate will not work (communication stops)
    There is a check for TX overflow in the PKTUART code that's
    in the wrong location (TX section) so will print bogus error
    messages with particular outgoing messages.
Last edit: 13 Jan 2025 16:00 by PCW.
16 Jan 2025 02:23 - 16 Jan 2025 02:24 #319079 by vre
modname.update-hz is 0 by default i have not changed so this not the reason for error
Last edit: 16 Jan 2025 02:24 by vre.
17 Jan 2025 19:09 #319210 by andypugh
Replied by andypugh on topic Mesa modbus and pktUart
That error (and others I have seen) seem to be a bug in the mesa-modbus code
Can you add these to an issue on the issue tracker?
Just so I don't immediately forget.
17 Jan 2025 20:47 #319218 by PCW
I updated the older issues with the latest bug list:
github.com/LinuxCNC/linuxcnc/issues/2506
19 Jan 2025 02:38 #319339 by vre
Why shows unknown pin?
hm2/hm2_7i80.0:     IO Pin 065 (P3-35): PktUART Receive Channel #0, pin RX Data (Input)
hm2/hm2_7i80.0:     IO Pin 066 (P3-37): PktUART Transmit Channel #0, pin TX Data (Output)
hm2/hm2_7i80.0:     IO Pin 067 (P3-39): PktUART Transmit Channel #0, pin unknown-pin-3 (Output)
hm2/hm2_7i80.0:     IO Pin 068 (P3-41): IOPort
hm2/hm2_7i80.0:     IO Pin 069 (P3-43): IOPort
hm2/hm2_7i80.0:     IO Pin 070 (P3-45): IOPort
hm2/hm2_7i80.0:     IO Pin 071 (P3-47): IOPort
hm2/hm2_7i80.0: registered
Found file(REL): ./custom.hal
hm2: hm2_7i80.0.pktuart.0: SCFFIFO error
[QTvcp.QTVCP.QT_ISTAT][WARNING]  INI Parsing Error, No USE_PROBE Entry in PROBE, Using: none (qt_istat.py:532)
19 Jan 2025 03:06 #319344 by PCW
LinuxCNC version?
19 Jan 2025 18:28 - 19 Jan 2025 18:29 #319394 by vre
2.9.3 version
I have tried many config combinations nothing works
HAL_BIT type not supported by linuxcnc
Unsupported HAL pin type (1) in mesa_modbus definition file
Last edit: 19 Jan 2025 18:29 by vre.
Time to create page: 0.146 seconds
