Mesa modbus and pktUart
19 Jan 2025 12:33 - 19 Jan 2025 12:55 #319395 by PCW
Replied by PCW on topic Mesa modbus and pktUart
HAL_BIT type definitely works as this tested, working configuration:
static const hm2_modbus_chan_descriptor_t channels = {
/*  {TYPE,    FUNC, ADDR,   COUNT, pin_name} */
    {HAL_BIT, 1,  0x0000, 8,     "state"},
    {HAL_BIT, 2,  0x0000, 8,     "input"},
    {HAL_BIT, 5,  0x0000, 1,     "relay-0"},
    {HAL_BIT, 5,  0x0001, 1,     "relay-1"},
    {HAL_BIT, 5,  0x0002, 1,     "relay-2"},
    {HAL_BIT, 5,  0x0003, 1,     "relay-3"},
Can you post your .mod file?
The inverted enable pin may not be recognized by 2.9.3 but it
should still work.
Last edit: 19 Jan 2025 12:55 by PCW.
19 Jan 2025 20:19 - 19 Jan 2025 20:33 #319431 by vre
Replied by vre on topic Mesa modbus and pktUart
#define MAX_MSG_LEN 16 // may be increased if necessary to max 251
#define DEBUG 2
{HAL_BIT, 3, 130, 8, "in"},
{HAL_U32, 16, 1, 8, "out"},
compilation : sudo modcompile file.mod
this is a working mb2hal configuration for my modbus module
[TRANSACTION_00]
LINK_TYPE=serial
SERIAL_PORT=/dev/ttyS0
SERIAL_BAUD=9600
SERIAL_BITS=8
SERIAL_PARITY=none
SERIAL_STOP=1
SERIAL_DELAY_MS=5
MB_SLAVE_ID=1
FIRST_ELEMENT=129
PIN_NAMES=01,02,03,04,05,06,07,08,09,10,11,12,13,14,15,16
HAL_TX_NAME=in
MB_TX_CODE=fnct_03_read_holding_registers
[TRANSACTION_01]
MB_TX_CODE=fnct_16_write_multiple_registers
FIRST_ELEMENT=1
HAL_TX_NAME=out
MAX_UPDATE_RATE=0.0
Last edit: 19 Jan 2025 20:33 by vre.
19 Jan 2025 21:16 #319436 by PCW
I don't think:
makes logical sense
Because unlike function 2 which returns a
number of bits, function 3 returns a number
of bytes.
I think you need to use u32
19 Jan 2025 22:20 - 19 Jan 2025 22:34 #319438 by vre
I have used u32 and works but
SCFFIFO error remains
hm2: hm2_7i80.0.pktuart.0: SCFFIFO error
Modbus error response function 128 error Illegal Data Value
Last edit: 19 Jan 2025 22:34 by vre.
19 Jan 2025 23:00 - 19 Jan 2025 23:02 #319439 by PCW
The SCFFIFO error is just a warning so should be harmless.
Andy probably need to look at that.
What is you current .mod file?
I think the only valid byte count on the function 3 read is likely 2
(because holding registers are 16 bits)
Last edit: 19 Jan 2025 23:02 by PCW.
The following user(s) said Thank You: vre
20 Jan 2025 04:28 #319448 by vre
This config works but displays a ton of errors at startup of linuxcnc like these
task: main loop took 0.105362 seconds
task: main loop took 0.100015 seconds
task: main loop took 0.100069 seconds
#define DEBUG 1
static const hm2_modbus_chan_descriptor_t channels[] = {
    {HAL_U32, 3,  0x0080, 1,     "in-01"},
	{HAL_U32, 3,  0x0081, 1,     "in-02"},
    {HAL_U32, 3,  0x0082, 1,     "in-03"},
    {HAL_U32, 3,  0x0083, 1,     "in-04"},
    {HAL_U32, 3,  0x0084, 1,     "in-05"},
    {HAL_U32, 3,  0x0085, 1,     "in-06"},
    {HAL_U32, 3,  0x0086, 1,     "in-07"},
	{HAL_U32, 3,  0x0087, 1,     "in-08"},
    {HAL_U32, 3,  0x0088, 1,     "in-09"},
    {HAL_U32, 3,  0x0089, 1,     "in-10"},
    {HAL_U32, 3,  0x008A, 1,     "in-11"},
    {HAL_U32, 3,  0x008B, 1,     "in-12"},
	{HAL_U32, 3,  0x008C, 1,     "in-13"},
    {HAL_U32, 3,  0x008D, 1,     "in-14"},
    {HAL_U32, 3,  0x008E, 1,     "in-15"},
    {HAL_U32, 3,  0x008F, 1,     "in-16"},
    {HAL_U32, 3,  0x0090, 1,     "in-17"},
	{HAL_U32, 3,  0x0091, 1,     "in-18"},
    {HAL_U32, 3,  0x0092, 1,     "in-19"},
    {HAL_U32, 3,  0x0093, 1,     "in-20"},
    {HAL_U32, 3,  0x0094, 1,     "in-21"},
    {HAL_U32, 3,  0x0095, 1,     "in-22"},
    {HAL_U32, 3,  0x0096, 1,     "in-23"},
	{HAL_U32, 3,  0x0097, 1,     "in-24"},
    {HAL_U32, 3,  0x0098, 1,     "in-25"},
    {HAL_U32, 3,  0x0099, 1,     "in-26"},
    {HAL_U32, 3,  0x009A, 1,     "in-27"},
    {HAL_U32, 3,  0x009B, 1,     "in-28"},
	{HAL_U32, 3,  0x009C, 1,     "in-29"},
    {HAL_U32, 3,  0x009D, 1,     "in-30"},
    {HAL_U32, 3,  0x009E, 1,     "in-31"},
    {HAL_U32, 3,  0x009F, 1,     "in-32"},
    {HAL_U32, 16, 0x0000, 1,     "out-01"},
    {HAL_U32, 16, 0x0001, 1,     "out-02"},
    {HAL_U32, 16, 0x0002, 1,     "out-03"},
    {HAL_U32, 16, 0x0003, 1,     "out-04"},
    {HAL_U32, 16, 0x0004, 1,     "out-05"},
    {HAL_U32, 16, 0x0005, 1,     "out-06"},
    {HAL_U32, 16, 0x0006, 1,     "out-07"},
    {HAL_U32, 16, 0x0007, 1,     "out-08"},
    {HAL_U32, 16, 0x0008, 1,     "out-09"},
    {HAL_U32, 16, 0x0009, 1,     "out-10"},
    {HAL_U32, 16, 0x000A, 1,     "out-11"},
    {HAL_U32, 16, 0x000B, 1,     "out-12"},
    {HAL_U32, 16, 0x000C, 1,     "out-13"},
    {HAL_U32, 16, 0x000D, 1,     "out-14"},
    {HAL_U32, 16, 0x000E, 1,     "out-15"},
    {HAL_U32, 16, 0x000F, 1,     "out-16"},
    {HAL_U32, 16, 0x0010, 1,     "out-17"},
    {HAL_U32, 16, 0x0011, 1,     "out-18"},
    {HAL_U32, 16, 0x0012, 1,     "out-19"},
    {HAL_U32, 16, 0x0013, 1,     "out-20"},
    {HAL_U32, 16, 0x0014, 1,     "out-21"},
    {HAL_U32, 16, 0x0015, 1,     "out-22"},
    {HAL_U32, 16, 0x0016, 1,     "out-23"},
    {HAL_U32, 16, 0x0017, 1,     "out-24"},
    {HAL_U32, 16, 0x0018, 1,     "out-25"},
    {HAL_U32, 16, 0x0019, 1,     "out-26"},
    {HAL_U32, 16, 0x001A, 1,     "out-27"},
    {HAL_U32, 16, 0x001B, 1,     "out-28"},
    {HAL_U32, 16, 0x001C, 1,     "out-29"},
    {HAL_U32, 16, 0x001D, 1,     "out-30"},
    {HAL_U32, 16, 0x001E, 1,     "out-31"},
    {HAL_U32, 16, 0x001F, 1,     "out-32"},
20 Jan 2025 09:12 - 20 Jan 2025 10:52 #319465 by PCW
if this is a 16 input module, there should only be one function 3 read
(because that read reads 16 bits at once into a single U32)
Also it's a bit  strange to use function 3 to read bits
as function 2 would be the standard thing for this.
Last edit: 20 Jan 2025 10:52 by PCW.
20 Jan 2025 19:47 - 20 Jan 2025 19:54 #319514 by vre
This is a 32ch input 32ch output module ( 25IOC32_PNP )
485io.com/others-c-2_5/25ioc32-32di-32do...home-iot-p-1608.html
485io.com/eletechsup/25IOA08-25IOB16-25IOC32-1.rar
input1 is at 0x0080 address
input2 is at 0x0081 address
and so on..
The previous config reads all inputs correct
but displays many errors at startup after startup doesn't display errors
Last edit: 20 Jan 2025 19:54 by vre.
20 Jan 2025 20:45 #319518 by PCW
Looks like it supports function 2 which would be a more natural
way to do bit input
20 Jan 2025 23:03 #319521 by vre
Can the startup errors be due the pullup resistors that has 7i80hd
and all pins before starting linuxcnc are at 5V ?
Time to create page: 0.375 seconds
