Mesa modbus and pktUart
3 years 2 months ago - 3 years 2 months ago #279484 by PCW
Replied by PCW on topic Mesa modbus and pktUart
There is a known bug where if you set the update-hz to 0 it cannot be set again
can you try setting it to a high value in your hal file?
Also can you post your .mod file?
Also a plot of the commanded position and feedback position might help isolate the issue
Last edit: 3 years 2 months ago by PCW.
3 years 2 months ago #279616 by Donno
Replied by Donno on topic Mesa modbus and pktUart
I am trying to compile .mod file using modcompile but keep getting error
[color=#5454ff]~/linuxcnc-dev/bin[/color][color=#000000]$ sudo ./modcompile mesa_modbus_A5_Driver.mod [/color] /tmp/tmpwmbs48kd/mesa_modbus.c make: *** No rule to make target 'mesa_modbus.c', needed by 'mesa_modbus.o'.  Stop.
I build linuxcnc on kubuntu 22.04 using the following commands
git clone git://github.com/linuxcnc/linuxcnc.git linuxcnc-devcd linuxcnc-dev/debian ./configure uspace no-docs cd .. dpkg-buildpackage -b -uc
I then copied modcompile from linuxcnc-dev/bin/ to linuxcnc else i get following error because of wrong path :
[color=#000000]mesa_modbus.c:21:10:[/color][color=#000000] [/color][color=#ff5454]fatal error: [/color][color=#000000]rtapi.h: No such file or directory [/color]   21 | #include [color=#ff5454]"rtapi.h"[/color][color=#000000] [/color]      |          [color=#ff5454]^~~~~~~~~[/color]
If i try and compile it now i get the following :
[color=#000000]sudo ./modcompile mesa_modbus_A5_Driver.mod [/color] /tmp/tmp31lc1kki/mesa_modbus.c make: *** No rule to make target 'mesa_modbus.c', needed by 'mesa_modbus.o'.  Stop.
Here is my driver file :
// Lichuan A5 AC Servo Drive Driver #define MAX_MSG_LEN 16   // may be increased if necessary to max 251 #define DEBUG 1 static const hm2_modbus_chan_descriptor_t channels[] = { /*  {TYPE,     FUNC, ADDR,   COUNT, pin_name} */     {HAL_U32,   3,   0x9C8, 1,     "speed-actual"},     {HAL_U32,   3,   0x9C9, 1,     "speed-instruction"},     {HAL_U32,   3,   0x9CA, 1,     "torque-instruction"},     {HAL_U32,   3,   0x9D4, 1,     "avg-load-rate"},     {HAL_U32,   3,   0x9E0, 1,     "phase-current"},     {HAL_U32,   3,   0x9E2, 1,     "bus-voltage"},     {HAL_U32,   6,   0x9E3, 1,     "tempreture"}, };
Any help please ? image missing /media/kunena/emoticons/unsure.png
3 years 2 months ago #279618 by PCW
Have you tried building LinuxCNC from source the normal RIP way?
That works for me with master and the modbus component
3 years 1 month ago #279619 by Donno
Can you maybe give instructions please ?
3 years 1 month ago #279621 by PCW
Just the standard build from source instructions:
linuxcnc.org/docs/devel/html/code/building-linuxcnc.html
3 years 1 month ago - 3 years 1 month ago #279629 by Donno
That manage to do the trickimage missing /media/kunena/emoticons/cool.png
I deleted ~/linuxcnc-dev and did the following command:
git clone https://github.com/LinuxCNC/linuxcnc.git linuxcnc-dev cd linuxcnc-dev/src ./autogen.sh ./configure --with-realtime=uspace make sudo make setuid source ../scripts/rip-environment cd ~/linuxcnc-dev/bin ./modcompile mesa_modbus_A5_Driver.mod
Last edit: 3 years 1 month ago by Donno. Reason: code tag breaks when copying
Time to create page: 0.433 seconds
