Mesa modbus and pktUart
3 years 1 month ago - 3 years 1 month ago #280029 by PCW
Replied by PCW on topic Mesa modbus and pktUart
Unless you get RX data echoed from TX data if /RE is grounded
and DE is asserted this has nothing to do with the 7I92 and likely
a wiring or hardware issue.
Last edit: 3 years 1 month ago by PCW.
3 years 1 month ago #280057 by Donno
Replied by Donno on topic Mesa modbus and pktUart
I manage to Echo RX/TX only if TXena is active low
It does not look like the servo drive is replying any data.
3 years 1 month ago - 3 years 1 month ago #280102 by PCW
1. That's active high TXEN (high when transmitting as expected)
2. The middle picture ( A,B )  doesn't seem to show any data
( if its at the same time per division as the other plots )
in fact it looks like the TXEN signal
3 years 1 month ago #280104 by Donno
If i zoom time in to 10ms per grid line(I think) :
3 years 1 month ago - 3 years 1 month ago #280105 by Donno
I am using linuxCNC 2.9pre on raspberry i build latetest build and copied hostmot2.so and hm2_eth.so to make pktuart to work, could that cause problems ?
Last edit: 3 years 1 month ago by Donno.
3 years 1 month ago - 3 years 1 month ago #280109 by PCW
I would say there are still hardware issues
(idle line state is undefined)
 A must be high and B low when no one is driving the RS-485 bus
That's the reason for the 620 Ohm pullup on A and 620 Ohm pulldown on B
Time to create page: 0.391 seconds
