Latency-schlecht wg nvidia Quadro FX1700
10 years 1 month ago #80003 by Tchefter
ArcEye wrote: The cards I have used were both G550s.
One was AGP, the other PCI, both worked well and were less than £10 from ebay.
Hi ArcEye, today i orded one as PCI.
Must i install a driver, or is it "PnP"? If Install needed, can you tell me how?
Thanks for a reply.
Regards Fritz
10 years 1 month ago #80004 by ArcEye
The driver package is xserver-xorg-video-mga
The package firmware-linux-nonfree contains the firmware for the Matrox G550
( Matrox G400/G550 WARP engine microcode (matrox/g400_warp.fw) )
Just make sure both are installed, BIOS is set to use the external card, fit it and start up and it should be recognised.
The following user(s) said Thank You: Tchefter
10 years 1 month ago - 10 years 1 month ago #80024 by Tchefter
OK - thank you, I hope they get to the weekend.
Last edit: 10 years 1 month ago by Tchefter.
10 years 1 month ago #80207 by Tchefter
ArcEye wrote: The driver package is xserver-xorg-video-mga
Hi ArcEye,
i hope the question is not to stupid, but can you tell me the way to install after the download?
I'm not the Linux Specialist, sorry...
Regards Fritz
10 years 1 month ago #80229 by ArcEye
You just install the packages using Synaptic or `apt-get install` on the command line, same as any other package.
If the hardware is recognised, the correct driver and firmware will be selected at boot time.
10 years 1 month ago - 10 years 1 month ago #80239 by Tchefter
No eBay APP ID and/or Cert ID defined in Kunena configurationOK,the Packages where installed, when i try to install.
The Latency was at aorund 50000. With the Old Nvidia was the Latency at around 30000.
The reason why I bought the Matrox that was my camera, to locate x0 + Y0, is always frozen after a few seconds. Now that's better, works perfectly. But the machine sounds strange when one proceeds manually. Like in this Post here
This where the card i bought...
The PC is a Intel P4 / 3Ghz / 2GB RAM / 80GB HDD
Did anyone know this issue?
Regards Fritz
Moderators: Muecke
Time to create page: 0.345 seconds
