- Thank you received: 7491
Umrüstung einer Sinumerik 3T 3-Achs Drehmaschine
9 years 6 months ago #91004
Replied by tommylight on topic Umrüstung einer Sinumerik 3T 3-Achs Drehmaschine
I can not help with the scales, but that is for sure a +-10V controlled servo drive, so 7i77 will do nicely.
Do not disconnect the tachos or anything from the drives. Only disconnect the +-10V and the enable so you can wire them to the 7i77. Chances are the velocity loop is all good if the drives are ok, and that you can easily check with an empty batery.
- Leow91
9 years 6 months ago #91874
by Leow91
Replied by Leow91 on topic Umrüstung einer Sinumerik 3T 3-Achs Drehmaschine
9 years 6 months ago #91881
Read carefully and follow step by step.
- Leow91
9 years 6 months ago #91885
by Leow91
Thank you Very much!
Hope i Could try this tonight !
- Leow91
7 years 2 months ago - 7 years 2 months ago #142371
by Leow91
Hi everybody
Long Time no Info - sorry!
The machine is actually working and Everything is Running!
But one thing dont my c-axis is Not getting stiff enough ! And i can Even move the spindle by Hand 5 degrees in each direction!
The rotation for turning is quite Good and works!
Anybody a Plan how to Control the Motor in the attachment ?
New Picture
1gg5116-0gh40-6hu3-z
Thank you and best regards !
New Picture
Last edit: 7 years 2 months ago by Leow91.
- pl7i92
- Thank you received: 358
7 years 2 months ago #142603
by pl7i92
Replied by pl7i92 on topic Umrüstung einer Sinumerik 3T 3-Achs Drehmaschine
war da noch die alte 802d drauf
die hatte die doppelsicherung der Achskarten
erst wenn beide hauptachsne stages angelaufen sind bekommt jede karte eine freigabe
Moderators: Muecke
Time to create page: 2.653 seconds
