- Thank you received: 7491
Umrüstung einer Sinumerik 3T 3-Achs Drehmaschine
7 years 2 months ago #143292
I never had to set anything lower than 30, so that is usually my starting point.
Thank you.
Replied by tommylight on topic Umrüstung einer Sinumerik 3T 3-Achs Drehmaschine
Yes of course, that is a good advice.HueyHQ wrote:
Can I just suggest, if retrofitting, start with P=1 - coming from personal experience, I had to reduce to P=0.6, but some further refinement might get it back up to 1.tommylight wrote: set P to 30
Thank you.
- pl7i92
- Thank you received: 358
7 years 2 months ago #143664
by pl7i92
Replied by pl7i92 on topic Umrüstung einer Sinumerik 3T 3-Achs Drehmaschine
P below 10 is very wear
Die Servo endstufen haben eine interne divisor der ist bestimmt zu hart eingestellt
du solltest den mal mitteln DIP switch auf 64
dann sollte das viel schneller und zarter laufen
Moderators: Muecke
Time to create page: 2.676 seconds
