Fusion360 Postprozessor für LinuxCNC 5 Achsen
- pl7i92
- Thank you received: 358
25 Jun 2019 18:05 #137819
by pl7i92
Replied by pl7i92 on topic Fusion360 Postprozessor für LinuxCNC 5 Achsen
are you relay gone build this system
Whow that woudt be a big chellenge if you do not ot precise machineng
25 Jun 2019 18:14 #137822
I thought about building it, but decided not to bother.
It was actually designed to be relatively easy to machine, as the working part is mainly a circle of plain drilled holes and off-the-shelf ground pins.
Replied by andypugh on topic Fusion360 Postprozessor für LinuxCNC 5 Achsen
- Hakan
- Thank you received: 454
25 Jun 2019 22:46 #137831
by Hakan
Replied by Hakan on topic Fusion360 Postprozessor für LinuxCNC 5 Achsen
Same working principle as harmonic drive, but pins instead of gears.
Harmonic drives have that cross-roller bearing that make them stiff, yet easy to rotate. A compact DIY should have that as well. SHG-type hd are on ebay for 300-400 usd/eur. To make it really compact one has to work with the motor, that's the big benefit of FHA I guess. It is already done.
- pl7i92
27 Jun 2019 10:41 #137985
by pl7i92
ones more i woudt like to ask
if somone got a Col part for 5Axis sync at around 120mm Diameter
as for education lessons
my parts arent that good most only plane axis milldrill
a turbo vent isent available in a good CAD
- plopes9000
- Thank you received: 18
27 Jun 2019 12:22 - 01 Jul 2019 18:21 #137993
by plopes9000
Replied by plopes9000 on topic Fusion360 Postprozessor für LinuxCNC 5 Achsen
not sure I understood your request - but here is an impeller I had quickly modeled a360.co/2KQoKdU
Last edit: 01 Jul 2019 18:21 by plopes9000.
- pl7i92
01 Jul 2019 18:06 #138321
by pl7i92
thank you for the part
sorry it is a BAD Request on Autodesk you may be part of there system to get it shown
- plopes9000
01 Jul 2019 18:43 #138327
by plopes9000
I joined teams in Fusion 360, maybe that caused the link to fail. I've updated the link now, please try again.
- 3D-Master
- Thank you received: 5
01 Jul 2019 20:37 - 01 Jul 2019 20:37 #138332
by 3D-Master
Replied by 3D-Master on topic Fusion360 Postprozessor für LinuxCNC 5 Achsen
if someone has interest, here is the link to a Hypocycloid gear calculator. The only downside is you need visual Studio for it to run:
github.com/dsuarezv/GearSolver
It outputs DXF files
Last edit: 01 Jul 2019 20:37 by 3D-Master.
- Stud54
21 Jul 2019 17:29 #140088
by Stud54
Hast du die Teile gegossen Andy, hab ich das richtig verstanden?
Gruß Sven
Replied by Stud54 on topic Fusion360 Postprozessor für LinuxCNC 5 Achsen
Nice. I can see myself offering-up my spare harmonic drive mounting casting to my existing A axis tonight, and seeing if there are any more FHA drives on eBay.
Gruß Sven
25 Jul 2019 23:05 #140585
No, I had them cast for me by a commercial foundry.
Moderators: Muecke
Time to create page: 0.138 seconds
