Parallel port treiber instalieren
19 Sep 2021 17:06 - 19 Sep 2021 17:08 #221120 by spicer
Replied by spicer on topic Parallel port treiber instalieren
Du musst eine Adresse vom LPT haben. 0 und 1 sind keine Adressen.
Bsp:
b400
bc00
a800
Irgend sowas. Schau, was ich Dir geschrieben habe. Schau auch die Links!
Last edit: 19 Sep 2021 17:08 by spicer.
19 Sep 2021 17:16 #221122 by tommylight
Replied by tommylight on topic Parallel port treiber instalieren
Die Karte hat er gefunden
00:01.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 1 (rev 12)
Das ist nicht die karte, das ist die X58 chipsatz PCI-E erste port, hat nichts mit pararallel port zu tun.
Bitte die text von
sudo lspci -v
hochladen im forum.
20 Sep 2021 17:57 #221213 by Bernd1365
Replied by Bernd1365 on topic Parallel port treiber instalieren
Host bridge: Intel Corporation 5520/5500/X58 I/O Hub to ESI Port (rev 12)
    Subsystem: Intel Corporation 5520/5500/X58 I/O Hub to ESI Port
    Flags: fast devsel
    Capabilities: [60] MSI: Enable- Count=1/2 Maskable+ 64bit-
    Capabilities: [90] Express Root Port (Slot-), MSI 00
    Capabilities: [e0] Power Management version 3
    Capabilities: [100] Advanced Error Reporting
    Capabilities: [150] Access Control Services
    Capabilities: [160] Vendor Specific Information: ID=0002 Rev=0 Len=00c <?>
00:01.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 1 (rev 12) (prog-if 00 [Normal decode])
    Flags: bus master, fast devsel, latency 0
    Bus: primary=00, secondary=07, subordinate=07, sec-latency=0
    Capabilities: [40] Subsystem: Pegatron 5520/5500/X58 I/O Hub PCI Express Root Port 1
    Capabilities: [90] Express Root Port (Slot+), MSI 00
    Kernel driver in use: pcieport
00:03.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 3 (rev 12) (prog-if 00 [Normal decode])
    Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
    I/O behind bridge: 0000e000-0000efff
    Memory behind bridge: f8000000-fbefffff
    Prefetchable memory behind bridge: 00000000d0000000-00000000dfffffff
    Capabilities: [40] Subsystem: Pegatron 5520/5500/X58 I/O Hub PCI Express Root Port 3
00:07.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 7 (rev 12) (prog-if 00 [Normal decode])
    Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
    Capabilities: [40] Subsystem: Pegatron 5520/5500/X58 I/O Hub PCI Express Root Port 7
00:10.0 PIC: Intel Corporation 7500/5520/5500/X58 Physical and Link Layer Registers Port 0 (rev 12) (prog-if 00 [8259])
    Flags: fast devsel
    Capabilities: [50] Vendor Specific Information: Len=ff <?>
00:10.1 PIC: Intel Corporation 7500/5520/5500/X58 Routing and Protocol Layer Registers Port 0 (rev 12) (prog-if 00 [8259])
    Flags: fast devsel
00:13.0 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub I/OxAPIC Interrupt Controller (rev 12) (prog-if 20 [IO(X)-APIC])
    Memory at fec8a000 (32-bit, non-prefetchable) [size=4K]
    Capabilities: [6c] Power Management version 3
00:14.0 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub System Management Registers (rev 12) (prog-if 00 [8259])
    Flags: fast devsel
    Capabilities: [40] Express Root Complex Integrated Endpoint, MSI 00
    Kernel driver in use: i7core_edac
    Kernel modules: i7core_edac
00:14.1 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers (rev 12) (prog-if 00 [8259])
    Flags: fast devsel
00:14.2 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub Control Status and RAS Registers (rev 12) (prog-if 00 [8259])
    Flags: fast devsel
00:14.3 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub Throttle Registers (rev 12) (prog-if 00 [8259])
    Flags: fast devsel
    Kernel modules: i5500_temp
00:19.0 Ethernet controller: Intel Corporation 82567V-2 Gigabit Network Connection
    Subsystem: Pegatron 82567V-2 Gigabit Network Connection
    Flags: bus master, fast devsel, latency 0, IRQ 24
    Memory at f7dc0000 (32-bit, non-prefetchable) [size=128K]
    Memory at f7df2000 (32-bit, non-prefetchable) [size=4K]
    I/O ports at a080
    Capabilities: [c8] Power Management version 2
    Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
    Capabilities: [e0] PCI Advanced Features
    Kernel driver in use: e1000e
    Kernel modules: e1000e
00:1a.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #4 (prog-if 00 [UHCI])
    Subsystem: Pegatron 82801JI (ICH10 Family) USB UHCI Controller
    Flags: bus master, medium devsel, latency 0, IRQ 16
    I/O ports at a400
    Capabilities: [50] PCI Advanced Features
    Kernel driver in use: uhci_hcd
    Kernel modules: uhci_hcd
00:1a.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #5 (prog-if 00 [UHCI])
    Flags: bus master, medium devsel, latency 0, IRQ 21
    I/O ports at a480
00:1a.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #6 (prog-if 00 [UHCI])
    Flags: bus master, medium devsel, latency 0, IRQ 19
    I/O ports at a800
00:1a.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #2 (prog-if 20 [EHCI])
    Subsystem: Pegatron 82801JI (ICH10 Family) USB2 EHCI Controller
    Flags: bus master, medium devsel, latency 0, IRQ 18
    Memory at f7df8000 (32-bit, non-prefetchable) [size=1K]
    Capabilities: [50] Power Management version 2
    Capabilities: [58] Debug port: BAR=1 offset=00a0
    Capabilities: [98] PCI Advanced Features
    Kernel driver in use: ehci-pci
    Kernel modules: ehci_pci
00:1b.0 Audio device: Intel Corporation 82801JI (ICH10 Family) HD Audio Controller
    Subsystem: Pegatron 82801JI (ICH10 Family) HD Audio Controller
    Flags: bus master, fast devsel, latency 0, IRQ 28
    Memory at f7df4000 (64-bit, non-prefetchable) [size=16K]
    Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
    Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
    Capabilities: [100] Virtual Channel
    Capabilities: [130] Root Complex Link
    Kernel driver in use: snd_hda_intel
    Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 1 (prog-if 00 [Normal decode])
    Flags: bus master, fast devsel, latency 0, IRQ 17
    Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
    I/O behind bridge: 00001000-00001fff
    Memory behind bridge: f0000000-f01fffff
    Prefetchable memory behind bridge: 00000000f0200000-00000000f03fffff
    Capabilities: [40] Express Root Port (Slot+), MSI 00
    Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
    Capabilities: [90] Subsystem: Pegatron 82801JI (ICH10 Family) PCI Express Root Port 1
    Capabilities: [a0] Power Management version 2
    Capabilities: [180] Root Complex Link
00:1c.1 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Port 2 (prog-if 00 [Normal decode])
    Flags: bus master, fast devsel, latency 0, IRQ 16
    Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
    I/O behind bridge: 0000d000-0000dfff
    Memory behind bridge: f7f00000-f7ffffff
    Prefetchable memory behind bridge: 00000000f0400000-00000000f05fffff
    Capabilities: [90] Subsystem: Pegatron 82801JI (ICH10 Family) PCI Express Port 2
00:1c.2 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 3 (prog-if 00 [Normal decode])
    Flags: bus master, fast devsel, latency 0, IRQ 18
    Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
    I/O behind bridge: 0000c000-0000cfff
    Memory behind bridge: f7e00000-f7efffff
    Prefetchable memory behind bridge: 00000000f0600000-00000000f07fffff
    Capabilities: [90] Subsystem: Pegatron 82801JI (ICH10 Family) PCI Express Root Port 3
00:1d.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #1 (prog-if 00 [UHCI])
    Flags: bus master, medium devsel, latency 0, IRQ 23
    I/O ports at a880
00:1d.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #2 (prog-if 00 [UHCI])
    I/O ports at ac00
00:1d.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #3 (prog-if 00 [UHCI])
    I/O ports at b000
00:1d.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #1 (prog-if 20 [EHCI])
    Memory at f7dfa000 (32-bit, non-prefetchable) [size=1K]
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 90) (prog-if 01 [Subtractive decode])
    Bus: primary=00, secondary=01, subordinate=01, sec-latency=32
    Capabilities: [50] Subsystem: Pegatron 82801 PCI Bridge
00:1f.0 ISA bridge: Intel Corporation 82801JIR (ICH10R) LPC Interface Controller
    Subsystem: Pegatron 82801JIR (ICH10R) LPC Interface Controller
    Capabilities: [e0] Vendor Specific Information: Len=0c <?>
    Kernel driver in use: lpc_ich
    Kernel modules: lpc_ich
00:1f.2 SATA controller: Intel Corporation 82801JI (ICH10 Family) SATA AHCI Controller (prog-if 01 [AHCI 1.0])
    Subsystem: Pegatron 82801JI (ICH10 Family) SATA AHCI Controller
    Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 25
    I/O ports at b880
    I/O ports at b800
    I/O ports at b480
    I/O ports at b400
    I/O ports at b080
    Memory at f7dfc000 (32-bit, non-prefetchable) [size=2K]
    Capabilities: [80] MSI: Enable+ Count=1/16 Maskable- 64bit-
    Capabilities: [70] Power Management version 3
    Capabilities: [a8] SATA HBA v1.0
    Capabilities: [b0] PCI Advanced Features
    Kernel driver in use: ahci
    Kernel modules: ahci
00:1f.3 SMBus: Intel Corporation 82801JI (ICH10 Family) SMBus Controller
    Subsystem: Pegatron 82801JI (ICH10 Family) SMBus Controller
    Flags: medium devsel, IRQ 18
    Memory at f7dfe000 (64-bit, non-prefetchable)
    I/O ports at 0400
    Kernel driver in use: i801_smbus
    Kernel modules: i2c_i801
02:00.0 FireWire (IEEE 1394): VIA Technologies, Inc. VT6315 Series Firewire Controller (prog-if 10 [OHCI])
    Subsystem: Pegatron VT6315 Series Firewire Controller
    Memory at f7eff800 (64-bit, non-prefetchable) [size=2K]
    I/O ports at c800
    Capabilities: [50] Power Management version 3
    Capabilities: [80] MSI: Enable- Count=1/1 Maskable+ 64bit+
    Capabilities: [98] Express Endpoint, MSI 00
    Capabilities: [130] Device Serial Number 00-1e-8c-ff-ff-df-4b-65
    Kernel driver in use: firewire_ohci
    Kernel modules: firewire_ohci
03:00.0 Serial controller: Asix Electronics Corporation Device 9105 (prog-if 02 [16550])
    Subsystem: Device a000:1000
    Flags: fast devsel, IRQ 17
    I/O ports at d800
    Memory at f7ffd000 (32-bit, non-prefetchable) [size=4K]
    Memory at f7ffc000 (32-bit, non-prefetchable) [size=4K]
    Capabilities: [50] MSI: Enable- Count=1/8 Maskable- 64bit+
    Capabilities: [78] Power Management version 3
    Capabilities: [80] Express Legacy Endpoint, MSI 00
    Capabilities: [800] Advanced Error Reporting
03:00.2 Parallel controller: Asix Electronics Corporation Device 9100 (prog-if 03 [IEEE1284])
    Subsystem: Device a000:2000
    Flags: bus master, fast devsel, latency 0, IRQ 15
    I/O ports at dc00
    I/O ports at d880
    Memory at f7fff000 (32-bit, non-prefetchable) [size=4K]
    Memory at f7ffe000 (32-bit, non-prefetchable) [size=4K]
06:00.0 VGA compatible controller: NVIDIA Corporation G94 [GeForce GT 140] (rev a1) (prog-if 00 [VGA controller])
    Subsystem: Micro-Star International Co., Ltd. [MSI] G94 [GeForce GT 140]
    Flags: bus master, fast devsel, latency 0, IRQ 27
    Memory at fa000000 (32-bit, non-prefetchable) [size=16M]
    Memory at d0000000 (64-bit, prefetchable) [size=256M]
    Memory at f8000000 (64-bit, non-prefetchable) [size=32M]
    I/O ports at ec00
    Expansion ROM at 000c0000 [disabled] [size=128K]
    Capabilities: [60] Power Management version 3
    Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
    Capabilities: [78] Express Endpoint, MSI 00
    Capabilities: [b4] Vendor Specific Information: Len=14 <?>
    Capabilities: [128] Power Budgeting <?>
    Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
    Kernel driver in use: nouveau
    Kernel modules: nouveau
ff:00.0 Host bridge: Intel Corporation Xeon 5500/Core i7 QuickPath Architecture Generic Non-Core Registers (rev 04)
    Subsystem: Intel Corporation Xeon 5500/Core i7 QuickPath Architecture Generic Non-Core Registers
ff:00.1 Host bridge: Intel Corporation Xeon 5500/Core i7 QuickPath Architecture System Address Decoder (rev 04)
    Subsystem: Intel Corporation Xeon 5500/Core i7 QuickPath Architecture System Address Decoder
ff:02.0 Host bridge: Intel Corporation Xeon 5500/Core i7 QPI Link 0 (rev 04)
    Subsystem: Intel Corporation Xeon 5500/Core i7 QPI Link 0
ff:02.1 Host bridge: Intel Corporation Xeon 5500/Core i7 QPI Physical 0 (rev 04)
    Subsystem: Intel Corporation Xeon 5500/Core i7 QPI Physical 0
ff:03.0 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller (rev 04)
    Subsystem: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller
ff:03.1 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Target Address Decoder (rev 04)
    Subsystem: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Target Address Decoder
ff:03.4 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Test Registers (rev 04)
    Subsystem: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Test Registers
ff:04.0 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 0 Control Registers (rev 04)
    Subsystem: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 0 Control Registers
ff:04.1 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 0 Address Registers (rev 04)
    Subsystem: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 0 Address Registers
ff:04.2 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 0 Rank Registers (rev 04)
    Subsystem: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 0 Rank Registers
ff:04.3 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 0 Thermal Control Registers (rev 04)
    Subsystem: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 0 Thermal Control Registers
ff:05.0 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 1 Control Registers (rev 04)
    Subsystem: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 1 Control Registers
ff:05.1 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 1 Address Registers (rev 04)
    Subsystem: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 1 Address Registers
ff:05.2 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 1 Rank Registers (rev 04)
    Subsystem: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 1 Rank Registers
ff:05.3 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 1 Thermal Control Registers (rev 04)
    Subsystem: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 1 Thermal Control Registers
ff:06.0 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 2 Control Registers (rev 04)
    Subsystem: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 2 Control Registers
ff:06.1 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 2 Address Registers (rev 04)
    Subsystem: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 2 Address Registers
ff:06.2 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 2 Rank Registers (rev 04)
    Subsystem: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 2 Rank Registers
ff:06.3 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 2 Thermal Control Registers (rev 04)
    Subsystem: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 2 Thermal Control Registers
Danke für euere Hilfe
20 Sep 2021 18:23 #221215 by spicer
Nach mir ist es dieser:
I/O ports at dc00
I/O ports at d880
20 Sep 2021 18:52 #221218 by Bernd1365
also ändere ich in der Hal
loadrt hal_parport cfg="0x378 0xd800 in
wäre das so richtig ?
20 Sep 2021 18:54 #221219 by spicer
Ich denke
0xdc00
oder
0xd880
The following user(s) said Thank You: Bernd1365
20 Sep 2021 18:58 #221221 by Bernd1365
die lasse ich auf 0
ich habe ja nur eine karte oder liege ich da falsch ß
20 Sep 2021 19:01 - 20 Sep 2021 19:09 #221222 by spicer
Bin nicht 100% sicher. Aber eine von den beiden Adressen müsste eigentlich Deine Karte sein.
Probier es doch einfach mal aus. Schau, ob der Notaus erkannt wird.
In
ist ja keine Adresse hinterlegt. Du bringst da was durcheinander.
Gib doch mal nacheinander diese Adressen im Stepconf Wizard ein.
Last edit: 20 Sep 2021 19:09 by spicer.
20 Sep 2021 19:29 #221223 by Bernd1365
Maschine läuft :-)))) Dankeschön
Die erste wars gleich loadrt hal_parport cfg="0xdc00"
The following user(s) said Thank You: spicer
20 Sep 2021 19:43 #221225 by spicer
Freut mich zu hören :D
Moderators: Muecke
Time to create page: 0.156 seconds
