Welche Tasten haben die Achsen?
2 years 2 weeks ago - 2 years 2 weeks ago #312397 by tommylight
From 2.7 to 2.9.2, using Axis GUI.
I always use USA standard keyboard keymap, i never ever change that, i had to learn every key on the keyboard as using several PC's and laptops daily with changed keymap was a horror ! :)
Edit:
Just tested on 2.10, also works moving A axis.
Last edit: 2 years 2 weeks ago by tommylight.
2 years 2 weeks ago #312404 by Muecke
Das funktioniert bei mir nicht :-( ich kann die C-Achse nicht mit der Tastatur bewegen :-(
2 years 2 weeks ago #312413 by tommylight
Did you try to add the standard USA keymap?
No idea how to do that so use google, please.
2 years 2 weeks ago #312416 by Aciera
Du kannst die Tasten auch selber zuordnen:
forum.linuxcnc.org/21-axis/46689-how-to-...on-keys-on-ui#250075
Hab ich aber auch noch nie gemacht, weil ich keine Tastatur Shortcuts nutze.
The following user(s) said Thank You: Tchefter
2 years 2 weeks ago #312424 by Tchefter
@tommylight
Do you have a Ascii Code for the Signs to move the C-Axis?
So, i think, it must be possible to search for the Signs on DE Keyboard.
2 years 2 weeks ago #312433 by tommylight
Menu>preferences>keyboard>Layouts tab, add
there add "English (US)" layout, a bit lower check if the "keyboard model" is "generic 105 key PC" and change if not, close.
Now there should be a little icon on the lower right side with US or DE in it, click on it and change to US, try jogging with []
@Tchefer,
No, and i can not find it now, will have ask google later and report back.
Moderators: Muecke
Time to create page: 0.428 seconds
