- Thank you received: 28
Zur Signalverarbeitung kam eine 7i85s dazu und die 7i96s wurde mit der entsprechenden Firmware geflasht.
Nach etwas testen und Jumper setzen, erhalte ich nun auf allen 3 Achsen saubere Signale über die ersten 3 Encoder-Eingänge der 7i85s.
Are the encoders wired to Mesa 7i85S?
Or are the encoders wired to JMC ?
Or, i really hope not, did you remove the encoders from JMC and wired to Mesa? This will not work without changing the drive config so the JMC are set to work with no encoders.
I assume this is the case as you mention the motor moves slowly when enabled, and this is exactly what will happen when encoders are detached from JMC.
Thanks tommy,The link i posted, explicitly mentions making the machine work without encoder feedback to LinuxCNC first, so enable the stepgen feedback in the hal file and omit the encoder feedback, test the machine, set the scaling correctly, and only after getting this done activate the encoder feedback and omit the stepgen feedback.
Closed loop stepers when loop is closed on the drives are viewed as normal open loop steppers from LinuxCNC.
So yes, it should work with your drives, just make sure they work properly in open loop mode to LinuxCNC.
