- Thank you received: 4153
You might be closer to the development than I am so can time things better. But I had been running my plasma on Mint 17.3 for about 4-5 years as RIP, way before plasmac even started. Eventually, python versions rendered it obsolete and impossible to upgrade. After flirting with MX linux you suggested, it did not support some of my hardware. Mint at the time did not support the correct version of Python 3 so it was not an option. Also the ethernet card on the Odroid H2+ I use in a mill needed kernel 5.9 or higher so Buster was out on it. I went to Buster on my plasma and not long later making a higher version of Python 3 as a prerequisite for 2.9 prevented upgrading at the time.
I don't know. I had such a problem trying to get v 2.9 running on buster over a year ago
Interesting, I have noticed you mention this several times. I have run 2.9 on Buster in both VM's and on my plasma table config without any issues.
I don't know. I had such a problem trying to get v 2.9 running on buster over a year ago, I have never used Buster or v 2.8 since.
I hsve been using Bookworm or sometimes Bullseye using this script github.com/joco-nz/lcnc-bullseye-installer
I try to make the complete installation , I come back asap to inform you.
