Résolu : Linuxcnc 2.9 avec Debian 10 probleme True Type Tracer manquant
3 years 9 months ago #263065 by rodw
Because 2.9 requires Python3, I never had any luck installing it on Debian 10. Its probably looking for packages that dont exist. Upgrading to Bullseye or Bookworm should work.
I prefer Bookworm so you can install linuxcnc and PREEMPT_RT with:
sudo apt install linuxcnc-uspace
sudo apt install linuxcnc-uspace-dev
The following user(s) said Thank You: benhurburg
3 years 9 months ago #263109 by benhurburg
I will upgrade tomorow , I hope , on the cloned disk.
I will use this how to :
phoenixnap.com/kb/upgrade-debian-10-to-11
3 years 9 months ago #263131 by rodw
The danger in upgrading is you will have python 2.7 and python3 on the PC so there are opportunities for confusion.
3 years 9 months ago #263157 by benhurburg
Is it possible to delete python 2.7 before upgrading or after?
3 years 9 months ago #263158 by rodw
I don't know. I had such a problem trying to get v 2.9 running on buster over a year ago, I have never used Buster or v 2.8 since.
I hsve been using Bookworm or sometimes Bullseye using this script  github.com/joco-nz/lcnc-bullseye-installer
3 years 9 months ago #263159 by phillc54
Interesting, I have noticed you mention this several times. I have run 2.9 on Buster in both VM's and on my plasma table config without any issues.
Time to create page: 0.189 seconds
