CamView for Wheesy and Jessie
7 years 1 month ago #143913 by andypugh
FedX wrote: [dode]from camview import CamView
ImportError: No module named camview[/code]
It seems that you might have installed CamPy, but not camview.
I have found CamPy, but where did you find camview?
7 years 1 month ago - 7 years 1 month ago #143914 by FedX
Replied by FedX on topic CamView for Wheesy and Jessie
well you're right i din't installed camview. I installed the campy module on page 2 of this thread from Bogie. Thats exactly what i did the last time. I think its just called CamPy but is a updated camview to run under wheezy
Axis starts up but i get the same error message in the terminal "from camview import CamView
ImportError: No module named camview"
Last edit: 7 years 1 month ago by FedX.
7 years 1 month ago #143916 by andypugh
FedX wrote: well you're right i din't installed camview. I installed the campy module on page 2 of this thread from Bogie. Thats exactly what i did the last time. I think its just called CamPy but is a updated camview to run under wheezy
OK, I see that now. Nothing at all to do with this
Can you check that camview.py found its way to the right place? (from a previous post:)
copy
camview.py
hal_python.xml
hal_pythonplugin.py
to /usr/lib/pymodules/python2.7/gladevcp
and also to
/usr/share/pyshared/gladevcp
7 years 1 month ago #143922 by Gene1934
was already set.
Thanks.
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page < geneslinuxbox.net:6309/gene >
7 years 1 month ago #143924 by Gene1934
The hal_* modules do not exist.
Thanks Andy
7 years 1 month ago #143945 by FedX
Ok that seems to be the problem. The Files are in the right place but camview.py is marked with a red cross and is empty. But i cant just copy the files into the folder because i dont get root rights. I tried to copy the files as root via the terminal but that didnt worked. How can i copy these files ?
Moderators: HansU
Time to create page: 0.400 seconds
