CamView for Wheesy and Jessie
7 years 11 months ago #120809 by Gene1934
I found a link , quite early in this thread, dated sometime in 2016, but I've not been able to access it as it appears to not exist at github any more. Is this the link that contains the 3 emb_* files I am missing?
Thanks Norbert
Cheers, gene1934
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page < geneslinuxbox.net:6309/gene >
7 years 11 months ago #120894 by newbynobi
Hallo gene1934,
if you go to the thread I mentioned, you will find a attachment.
If you do download that one, you have a zip file containing every file you need.
I also mailed the zip file to you.
Norbert
7 years 11 months ago #120908 by Gene1934
Norbert was kind enough to pm me the files, and a jpg showing where the download was at. But I don't click on unlabeled buttons. Can this lack of button labels be addressed?
FWIW, it works in the axis gui with fewer niggles, better than before, and I believe it will be usable. when my machine is 100% alive again. The bob attached to p2 on the 5i25 got blown by the failure of $2.50 buck regulator, and I'm hoping it didn't cascade back into the 5i25. But that guy Murphy is always looking over my shoulder. :(
Cheers all.
gene1934
7 years 11 months ago #120916 by Clive S
If you hover over the button (left side) you can see the file name
7 years 11 months ago #120918 by Gene1934
This is true, but to get that info it has to query the forum driver, which will then reply with anything including an attack vector, Just one of the habits that I use to keep me out of the black-hats cross hairs. Many times more likely I'd click on it if it was properly labeled.
Thanks Clive.
Cheers, gene1934
7 years 11 months ago #120980 by Nitram
Have just installed a cam and it works great following the guide laid out by Bogie.
Many thanks to you all, Norbert, Bogie and others!!
That said, I wonder what is necessary to make the camera hot pluggable, in other words, if I disconnect the camera from the laptop, it will not return after plugging back in unless the machine is rebooted.
Having a cable pulled out or bumped out of a USB port half way through a job is problematic at the next tool change (I am using this for a lathe to manually set tool tip offset at tool change) as one would have to reboot and loose positional accuracy in the process.
I see some benefits for hot pluggable ability but am unsure how to go about making the camera hot pluggable.
Does anyone have any thoughts?
Moderators: HansU
Time to create page: 0.480 seconds
