CamView for Wheesy and Jessie
9 years 6 months ago - 9 years 6 months ago #91567 by jrsphoto
Just an fyi, I think I found a bug between this module and the buildbot linuxcnc 2.8.0-pre1 with the latest gmoccapy. I've posted the error here:
forum.linuxcnc.org/gmoccapy/26314-gmocca...cnc?start=1300#91566
I've noticed that if I remove just hal_pythonplugin.py from /usr/lib/pymodules/python2.7/gladevcp, linuxcnc then starts but camview does not load.
Cheers
Last edit: 9 years 6 months ago by jrsphoto.
9 years 6 months ago #91751 by newbynobi
Hallo John,
during my discription and your install, the filed you mentioned has changed, that causes the error. Have you tried boggies install script?
Install Script for Campy
Norbert
9 years 6 months ago #91826 by jrsphoto
Awesome, thanks Norbert, I'll give the script a try tonight
9 years 5 months ago #92760 by bogie6040
Thanks, glad you found it useful, I wasn't sure if the subroutines for moving the machine would work for most however it seemed to work on my machine at work. I will try to finish the wiki page I started a while ago some time soon.
9 years 5 months ago #92769 by Tchefter
Works straight out of the Box, that means, Installation 1:1 from the perfect Read.me and it works.
Many thanks!!!!
9 years 2 months ago #97601 by blazini36
I'm working on a project that is based almost entirely around the camera which I made a glade GUI for. Since I know very little about programming and Gstreamer 1.0 seems to be incompatible with GTK2 I can't get anything other than this camview widget to work. Basically I just need a big videobox in my GUI. The V4l2 controls are great, but I'd rather have them in the mainwindow of my GUI
Right now I'm trying to pull the buttons, circles, and text out of it but any modifications I make to the python file make it angry.
Also the video stream is paused any time a "run" command is issued. I assume this is for performance but jog commands are not effected. Is there any way to have this not be the case?
Moderators: HansU
Time to create page: 0.093 seconds
