CamView for Wheesy and Jessie
9 years 8 months ago #87728 by bogie6040
Hallo Norbert,
I've attached a zip file with the install files. I would like for you to test this to make sure it is suitable for release as I have made quite a few changes. Also I have modified the camview.py file to have two buttons for moving the machine based on offsets in tool # 99 it seems to work ok in axis but it seems to act differently in gmoccapy. This was as good as I could get it, if there is a better way please let me know or go ahead and change it. I have started a wiki page for it but wanted to pass it by you first before I post it.
To test this copy the zip file to your configs directory and unzip it there. Open the new folder named CamPY and view the readme file for instructions.
File Name: campy.zip
File Size:12.04 KB
Thanks,
Bogie
The following user(s) said Thank You: nkp, Tchefter, ikkuh
9 years 7 months ago - 9 years 7 months ago #90288 by ikkuh
Wow Bogie, worked first time! The documentation in the readme file is excellent, it was a matter of seconds to set everything up.
Looks really nice in gmoccapy.
Thank you for all your troubles, it is much appreciated!
Last edit: 9 years 7 months ago by ikkuh.
9 years 7 months ago #90583 by mmt
I get this error on step 3 when I run sudo python CamPY_setup.py
I am running Wheezy with 2.7.8 installed
File "CamPY_setup.py", line 24, in <module>
cache = apt.Cache()
File "/usr/lib/python2.7/dist-packages/apt/cache.py", line 102, in __init__
self.open(progress)
File "/usr/lib/python2.7/dist-packages/apt/cache.py", line 149, in open
self._list.read_main_list()
SystemError: E:Malformed line 7 in source list /etc/apt/sources.list (dist parse)
9 years 7 months ago #90629 by ikkuh
mmt wrote: SystemError: E:Malformed line 7 in source list /etc/apt/sources.list (dist parse)
This is not a clue to you?
9 years 7 months ago #90651 by mmt
No I'm sorry but it is not.
9 years 7 months ago #90713 by newbynobi
Please post you sources.list, there will be a strange line in it.
Norbert
Moderators: HansU
Time to create page: 0.252 seconds
