CamView for Wheesy and Jessie
7 years 1 month ago #143955 by Gene1934
What are you using to do the copy?
If you've sudo rights, and user 1000 normally does, sudo mc will copy/move anything. You'll likely have to sudo apt install mc mc-data first though. Be carefull with it, it has more sharp edges than a swiss army knife.
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page < geneslinuxbox.net:6309/gene >
7 years 1 month ago #143956 by andypugh
You probably meed to just run
sudo ./CamPY_setup.py
7 years 1 month ago #143960 by FedX
Replied by FedX on topic CamView for Wheesy and Jessie
Nothing worked so i re installed Linux and did evereything from the beginning now it works..
Thank you even If i really dont know where the Problem was..
6 years 8 months ago #158020 by mmt
Replied by mmt on topic CamView for Wheesy and Jessie
I am trying to camview to run in a tab in axis. I have followed the instruction in the readme file and it run great as a standalone but i just get a blank tab in axis. I think i may need to run CamPY_setup.py but I get the following message when i try.
I am running Deb 9 Stretch Linuxcnc 2.7.14
Thank you
6 years 8 months ago #158381 by Arro
Replied by Arro on topic CamView for Wheesy and Jessie
hallo
it is working also for Debian 9 stretch
6 years 5 months ago #166661 by Joko85
Hello together.
I want to use gmoccapy with auto tool measurement and camview. gmoccapy with auto tool measurement works well. Now I have a problem with CamView. The installation worked and I also get a picture from the camera.
My problem now is that when I want to change a tool, the window opens asking me to change the tool manually. Then linuxcnc hangs and I can only end it, so linuxcnc crashes and I get the following debug output.
Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.5 LINUXCNC - 2.7.15 Machine configuration directory is '/home/jbergmann/linuxcnc/configs/Test' Machine configuration file is 'Test.ini' INIFILE=/home/jbergmann/linuxcnc/configs/Test/Test.ini PARAMETER_FILE=linuxcnc.var TASK=milltask HALUI= DISPLAY=gmoccapy Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io Found file(REL): ./Test.hal Found file(REL): ./custom.hal Starting TASK program: milltask Starting DISPLAY program: gmoccapy task: main loop took 0.103591 seconds Shutting down and cleaning up LinuxCNC... task: 12541 cycles, min=0.000020, max=0.103591, avg=0.010007, 1 latency excursions (> 10x expected cycle time of 0.010000s) Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: . /home/jbergmann/linuxcnc/configs/Test/Test.ini:63: executing 'import sys sys.path.insert(0,"python")' PythonPlugin: Python '2.7.3 (default, Nov 24 2017, 16:38:25) [GCC 4.7.2]' /home/jbergmann/linuxcnc/configs/Test/Test.ini:63: executing 'import sys sys.path.insert(0,"python")' PythonPlugin: Python '2.7.3 (default, Nov 24 2017, 16:38:25) [GCC 4.7.2]' is_callable(__init__) = FALSE is_callable(oword.on_abort) = FALSE (gmoccapy:7918): GtkSourceView-CRITICAL **: gtk_source_language_manager_set_search_path: assertion `lm->priv->ids == NULL' failed is_callable(oword.on_abort) = FALSE is_callable(oword.change) = FALSE /usr/bin/linuxcnc: Zeile 864: 7918 Getötet $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS 7858 7915 is_callable(__delete__) = FALSE Stopping realtime threads Unloading hal components Kernel message information: [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc [ 0.000000] BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f400 (usable) [ 0.000000] BIOS-e820: 000000000009f400 - 00000000000a0000 (reserved) [ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved) [ 0.000000] BIOS-e820: 0000000000100000 - 00000000dfff0000 (usable) [ 0.000000] BIOS-e820: 00000000dfff0000 - 00000000dfff3000 (ACPI NVS) [ 0.000000] BIOS-e820: 00000000dfff3000 - 00000000e0000000 (ACPI data) [ 0.000000] BIOS-e820: 00000000f0000000 - 00000000f4000000 (reserved) [ 0.000000] BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved) [ 0.000000] BIOS-e820: 0000000100000000 - 0000000120000000 (usable) [ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel! [ 0.000000] SMBIOS 2.3 present. [ 0.000000] DMI: Acer Aspire T180/EM61SM/EM61PM , BIOS R01-B1 12/29/2006 [ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved) [ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable) [ 0.000000] last_pfn = 0xdfff0 max_arch_pfn = 0x100000 [ 0.000000] MTRR default type: uncachable [ 0.000000] MTRR fixed ranges enabled: [ 0.000000] 00000-9FFFF write-back [ 0.000000] A0000-BFFFF uncachable [ 0.000000] C0000-C7FFF write-protect [ 0.000000] C8000-FFFFF uncachable [ 0.000000] MTRR variable ranges enabled: [ 0.000000] 0 base 0000000000 mask FF80000000 write-back [ 0.000000] 1 base 0080000000 mask FFC0000000 write-back [ 0.000000] 2 base 00C0000000 mask FFE0000000 write-back [ 0.000000] 3 base 0100000000 mask FFE0000000 write-back [ 0.000000] 4 disabled [ 0.000000] 5 disabled [ 0.000000] 6 disabled [ 0.000000] 7 disabled [ 0.000000] TOM2: 0000000120000000 aka 4608M [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106 [ 0.000000] e820 update range: 00000000e0000000 - 0000000100000000 (usable) ==> (reserved) [ 0.000000] found SMP MP-table at [c00f3c90] f3c90 [ 0.000000] initial memory mapped : 0 - 01800000 [ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384 [ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000 [ 0.000000] 0000000000 - 0000400000 page 4k [ 0.000000] 0000400000 - 0037400000 page 2M [ 0.000000] 0037400000 - 00377fe000 page 4k [ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff] [ 0.000000] RAMDISK: 362d8000 - 37164000 [ 0.000000] ACPI: RSDP 000f8370 00014 (v00 ACRSYS) [ 0.000000] ACPI: RSDT dfff3040 0003C (v01 ACRSYS ACRPRDCT 42302E31 AWRD 00000000) [ 0.000000] ACPI: FACP dfff30c0 00074 (v01 ACRSYS ACRPRDCT 42302E31 AWRD 00000000) [ 0.000000] ACPI: DSDT dfff3180 0631A (v01 ACRSYS AWRDACPI 00001000 MSFT 0100000E) [ 0.000000] ACPI: FACS dfff0000 00040 [ 0.000000] ACPI: SSDT dfff95c0 00206 (v01 PTLTD POWERNOW 00000001 LTP 00000001) [ 0.000000] ACPI: HPET dfff9840 00038 (v01 ACRSYS ACRPRDCT 42302E31 AWRD 00000098) [ 0.000000] ACPI: SLIC dfff98c0 00176 (v01 ACRSYS ACRPRDCT 42302E31 AWRD 00000001) [ 0.000000] ACPI: MCFG dfff9a80 0003C (v01 ACRSYS ACRPRDCT 42302E31 AWRD 00000000) [ 0.000000] ACPI: APIC dfff9500 0007C (v01 ACRSYS ACRPRDCT 42302E31 AWRD 00000000) [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] 2695MB HIGHMEM available. [ 0.000000] 887MB LOWMEM available. [ 0.000000] mapped low ram: 0 - 377fe000 [ 0.000000] low ram: 0 - 377fe000 [ 0.000000] Zone PFN ranges: [ 0.000000] DMA 0x00000010 -> 0x00001000 [ 0.000000] Normal 0x00001000 -> 0x000377fe [ 0.000000] HighMem 0x000377fe -> 0x000dfff0 [ 0.000000] Movable zone start PFN for each node [ 0.000000] Early memory PFN ranges [ 0.000000] 0: 0x00000010 -> 0x0000009f [ 0.000000] 0: 0x00000100 -> 0x000dfff0 [ 0.000000] On node 0 totalpages: 917375 [ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f46d8200 [ 0.000000] DMA zone: 32 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 3951 pages, LIFO batch:0 [ 0.000000] Normal zone: 1744 pages used for memmap [ 0.000000] Normal zone: 221486 pages, LIFO batch:31 [ 0.000000] HighMem zone: 5392 pages used for memmap [ 0.000000] HighMem zone: 684770 pages, LIFO batch:31 [ 0.000000] Using APIC driver default [ 0.000000] Detected use of extended apic ids on hypertransport bus [ 0.000000] ACPI: PM-Timer IO Port: 0x1008 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled) [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1]) [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1]) [ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0]) [ 0.000000] IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23 [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge) [ 0.000000] ACPI: IRQ0 used by override. [ 0.000000] ACPI: IRQ2 used by override. [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] ACPI: IRQ14 used by override. [ 0.000000] ACPI: IRQ15 used by override. [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] ACPI: HPET id: 0x10de8201 base: 0xfeff0000 [ 0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs [ 0.000000] nr_irqs_gsi: 40 [ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000 [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000 [ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000 [ 0.000000] Allocating PCI resources starting at e0000000 (gap: e0000000:10000000) [ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:2 nr_node_ids:1 [ 0.000000] PERCPU: Embedded 17 pages/cpu @f77c9000 s48384 r0 d21248 u69632 [ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 910207 [ 0.000000] Kernel command line: BOOT_IMAGE=/vmlinuz-3.4-9-rtai-686-pae root=/dev/mapper/RS--CNC-root ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Initializing CPU#0 [ 0.000000] allocated 7339776 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Initializing HighMem for node 0 (000377fe:000dfff0) [ 0.000000] Memory: 3611892k/3669952k available (3495k kernel code, 57608k reserved, 1237k data, 416k init, 2760648k highmem) [ 0.000000] virtual kernel memory layout: [ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB) [ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB) [ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB) [ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB) [ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB) [ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB) [ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok. [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:2304 nr_irqs:512 16 [ 0.000000] CPU 0 irqstacks, hard=f3806000 soft=f3808000 [ 0.000000] Interrupt pipeline (release #3) [ 0.000000] spurious 8259A interrupt: IRQ7. [ 0.000000] Console: colour VGA+ 80x25 [ 0.000000] console [tty0] enabled [ 0.000000] hpet clockevent registered [ 0.000000] Fast TSC calibration using PIT [ 0.000000] Detected 2209.691 MHz processor. [ 0.000000] Marking TSC unstable due to TSCs unsynchronized [ 0.004004] Calibrating delay loop (skipped), value calculated using timer frequency.. 4419.38 BogoMIPS (lpj=8838764) [ 0.004009] pid_max: default: 32768 minimum: 301 [ 0.004060] Security Framework initialized [ 0.004066] AppArmor: AppArmor disabled by boot time parameter [ 0.004086] Mount-cache hash table entries: 512 [ 0.004290] Initializing cgroup subsys cpuacct [ 0.004293] Initializing cgroup subsys memory [ 0.004302] Initializing cgroup subsys devices [ 0.004304] Initializing cgroup subsys freezer [ 0.004307] Initializing cgroup subsys net_cls [ 0.004309] Initializing cgroup subsys blkio [ 0.004316] Initializing cgroup subsys perf_event [ 0.004343] CPU: Physical Processor ID: 0 [ 0.004345] CPU: Processor Core ID: 0 [ 0.004348] mce: CPU supports 5 MCE banks [ 0.004356] LVT offset 0 assigned for vector 0xf9 [ 0.004360] using AMD E400 aware idle routine [ 0.004409] ACPI: Core revision 20120320 [ 0.011561] Enabling APIC mode: Flat. Using 1 I/O APICs [ 0.012000] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1 [ 0.051793] CPU0: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+ stepping 02 [ 0.052002] Performance Events: AMD PMU driver. [ 0.052002] ... version: 0 [ 0.052002] ... bit width: 48 [ 0.052002] ... generic registers: 4 [ 0.052002] ... value mask: 0000ffffffffffff [ 0.052002] ... max period: 00007fffffffffff [ 0.052002] ... fixed-purpose events: 0 [ 0.052002] ... event mask: 000000000000000f [ 0.060027] NMI watchdog: enabled, takes one hw-pmu counter. [ 0.072021] CPU 1 irqstacks, hard=f3894000 soft=f3896000 [ 0.072024] Booting Node 0, Processors #1 Ok. [ 0.008000] Initializing CPU#1 [ 0.160107] NMI watchdog: enabled, takes one hw-pmu counter. [ 0.160137] Brought up 2 CPUs [ 0.160140] Total of 2 processors activated (8839.16 BogoMIPS). [ 0.160611] devtmpfs: initialized [ 0.160611] PM: Registering ACPI NVS region [mem 0xdfff0000-0xdfff2fff] (12288 bytes) [ 0.160611] dummy: [ 0.160611] NET: Registered protocol family 16 [ 0.160611] node 0 link 0: io port [9000, ffff] [ 0.160611] TOM: 00000000e0000000 aka 3584M [ 0.160611] node 0 link 0: mmio [a0000, bffff] [ 0.160611] node 0 link 0: mmio [e0000000, efffffff] [ 0.160611] node 0 link 0: mmio [f4000000, fe02ffff] [ 0.160611] node 0 link 0: mmio [f0000000, f03fffff] [ 0.160611] TOM2: 0000000120000000 aka 4608M [ 0.160611] bus: [00, 04] on node 0 link 0 [ 0.160611] bus: 00 index 0 [io 0x0000-0xffff] [ 0.160611] bus: 00 index 1 [mem 0x000a0000-0x000bffff] [ 0.160611] bus: 00 index 2 [mem 0xe0000000-0xf3ffffff] [ 0.160611] bus: 00 index 3 [mem 0xf4000000-0xffffffff] [ 0.160611] ACPI: bus type pci registered [ 0.160611] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf0000000-0xf3ffffff] (base 0xf0000000) [ 0.160611] PCI: MMCONFIG at [mem 0xf0000000-0xf3ffffff] reserved in E820 [ 0.160611] PCI: Using MMCONFIG for extended config space [ 0.160611] PCI: Using configuration type 1 for base access [ 0.161073] bio: create slab <bio-0> at 0 [ 0.161073] ACPI: Added _OSI(Module Device) [ 0.161073] ACPI: Added _OSI(Processor Device) [ 0.161073] ACPI: Added _OSI(3.0 _SCP Extensions) [ 0.161073] ACPI: Added _OSI(Processor Aggregator Device) [ 0.164151] ACPI: EC: Look up EC in DSDT [ 0.169488] ACPI: Interpreter enabled [ 0.169494] ACPI: (supports S0 S3 S4 S5) [ 0.169519] ACPI: Using IOAPIC for interrupt routing [ 0.177104] ACPI: No dock devices found. [ 0.177111] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug [ 0.177760] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-04]) [ 0.178983] pci_root PNP0A08:00: host bridge window [io 0x0000-0x03af] (ignored) [ 0.178987] pci_root PNP0A08:00: host bridge window [io 0x03e0-0x0cf7] (ignored) [ 0.178990] pci_root PNP0A08:00: host bridge window [io 0x9000-0xffff] (ignored) [ 0.178993] pci_root PNP0A08:00: host bridge window [io 0x03b0-0x03df] (ignored) [ 0.178996] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored) [ 0.178999] pci_root PNP0A08:00: host bridge window [mem 0xe0000000-0xefffffff] (ignored) [ 0.179003] pci_root PNP0A08:00: host bridge window [mem 0xf4000000-0xfe02ffff] (ignored) [ 0.179006] pci_root PNP0A08:00: host bridge window [mem 0xfed40000-0xfed44fff] (ignored) [ 0.179009] pci_root PNP0A08:00: host bridge window [io 0x4700-0x470b] (ignored) [ 0.179012] pci_root PNP0A08:00: host bridge window [io 0x1c00-0x1c80] (ignored) [ 0.179015] pci_root PNP0A08:00: host bridge window [mem 0xfec80000-0xfecbffff] (ignored) [ 0.179018] PCI: root bus 00: hardware-probed resources [ 0.179057] PCI host bridge to bus 0000:00 [ 0.179060] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] [ 0.179064] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff] [ 0.179067] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xf3ffffff] [ 0.179070] pci_bus 0000:00: root bus resource [mem 0xf4000000-0xffffffff] [ 0.179097] pci 0000:00:00.0: [10de:03ea] type 00 class 0x050000 [ 0.179259] pci 0000:00:01.0: [10de:03e0] type 00 class 0x060100 [ 0.179305] pci 0000:00:01.1: [10de:03eb] type 00 class 0x0c0500 [ 0.179318] pci 0000:00:01.1: reg 10: [io 0xfc00-0xfc3f] [ 0.179336] pci 0000:00:01.1: reg 20: [io 0x1c00-0x1c3f] [ 0.179342] pci 0000:00:01.1: reg 24: [io 0xf400-0xf43f] [ 0.179365] pci 0000:00:01.1: PME# supported from D3hot D3cold [ 0.179382] pci 0000:00:01.2: [10de:03f5] type 00 class 0x050000 [ 0.179429] pci 0000:00:02.0: [10de:03f1] type 00 class 0x0c0310 [ 0.179440] pci 0000:00:02.0: reg 10: [mem 0xfe02f000-0xfe02ffff] [ 0.179474] pci 0000:00:02.0: supports D1 D2 [ 0.179476] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.179491] pci 0000:00:02.1: [10de:03f2] type 00 class 0x0c0320 [ 0.179503] pci 0000:00:02.1: reg 10: [mem 0xfe02e000-0xfe02e0ff] [ 0.179542] pci 0000:00:02.1: supports D1 D2 [ 0.179544] pci 0000:00:02.1: PME# supported from D0 D1 D2 D3hot D3cold [ 0.179568] pci 0000:00:04.0: [10de:03f3] type 01 class 0x060401 [ 0.179609] pci 0000:00:05.0: [10de:03f0] type 00 class 0x040300 [ 0.179622] pci 0000:00:05.0: reg 10: [mem 0xfe028000-0xfe02bfff] [ 0.179661] pci 0000:00:05.0: PME# supported from D3hot D3cold [ 0.179684] pci 0000:00:06.0: [10de:03ec] type 00 class 0x01018a [ 0.179708] pci 0000:00:06.0: reg 20: [io 0xf000-0xf00f] [ 0.179739] pci 0000:00:08.0: [10de:03f6] type 00 class 0x010185 [ 0.179750] pci 0000:00:08.0: reg 10: [io 0x09f0-0x09f7] [ 0.179755] pci 0000:00:08.0: reg 14: [io 0x0bf0-0x0bf3] [ 0.179761] pci 0000:00:08.0: reg 18: [io 0x0970-0x0977] [ 0.179766] pci 0000:00:08.0: reg 1c: [io 0x0b70-0x0b73] [ 0.179772] pci 0000:00:08.0: reg 20: [io 0xdc00-0xdc0f] [ 0.179778] pci 0000:00:08.0: reg 24: [mem 0xfe02d000-0xfe02dfff] [ 0.179813] pci 0000:00:09.0: [10de:03e8] type 01 class 0x060400 [ 0.179840] pci 0000:00:09.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.179859] pci 0000:00:0b.0: [10de:03e9] type 01 class 0x060400 [ 0.179884] pci 0000:00:0b.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.179902] pci 0000:00:0c.0: [10de:03e9] type 01 class 0x060400 [ 0.179926] pci 0000:00:0c.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.179950] pci 0000:00:18.0: [1022:1100] type 00 class 0x060000 [ 0.179973] pci 0000:00:18.1: [1022:1101] type 00 class 0x060000 [ 0.179992] pci 0000:00:18.2: [1022:1102] type 00 class 0x060000 [ 0.180023] pci 0000:00:18.3: [1022:1103] type 00 class 0x060000 [ 0.180085] pci 0000:01:09.0: [104c:8024] type 00 class 0x0c0010 [ 0.180100] pci 0000:01:09.0: reg 10: [mem 0xfdeff000-0xfdeff7ff] [ 0.180109] pci 0000:01:09.0: reg 14: [mem 0xfdef8000-0xfdefbfff] [ 0.180156] pci 0000:01:09.0: supports D1 D2 [ 0.180158] pci 0000:01:09.0: PME# supported from D0 D1 D2 D3hot [ 0.180188] pci 0000:00:04.0: PCI bridge to [bus 01-01] (subtractive decode) [ 0.180192] pci 0000:00:04.0: bridge window [io 0xc000-0xcfff] [ 0.180196] pci 0000:00:04.0: bridge window [mem 0xfde00000-0xfdefffff] [ 0.180201] pci 0000:00:04.0: bridge window [mem 0xfdd00000-0xfddfffff pref] [ 0.180204] pci 0000:00:04.0: bridge window [io 0x0000-0xffff] (subtractive decode) [ 0.180207] pci 0000:00:04.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode) [ 0.180210] pci 0000:00:04.0: bridge window [mem 0xe0000000-0xf3ffffff] (subtractive decode) [ 0.180214] pci 0000:00:04.0: bridge window [mem 0xf4000000-0xffffffff] (subtractive decode) [ 0.180250] pci 0000:02:00.0: [10de:0644] type 00 class 0x030000 [ 0.180260] pci 0000:02:00.0: reg 10: [mem 0xfa000000-0xfaffffff] [ 0.180271] pci 0000:02:00.0: reg 14: [mem 0xe0000000-0xefffffff 64bit pref] [ 0.180281] pci 0000:02:00.0: reg 1c: [mem 0xf8000000-0xf9ffffff 64bit] [ 0.180289] pci 0000:02:00.0: reg 24: [io 0xbc00-0xbc7f] [ 0.180297] pci 0000:02:00.0: reg 30: [mem 0x00000000-0x0007ffff pref] [ 0.188025] pci 0000:00:09.0: PCI bridge to [bus 02-02] [ 0.188029] pci 0000:00:09.0: bridge window [io 0xb000-0xbfff] [ 0.188033] pci 0000:00:09.0: bridge window [mem 0xf8000000-0xfbffffff] [ 0.188037] pci 0000:00:09.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref] [ 0.188078] pci 0000:03:00.0: [11ab:4364] type 00 class 0x020000 [ 0.188095] pci 0000:03:00.0: reg 10: [mem 0xfdcfc000-0xfdcfffff 64bit] [ 0.188105] pci 0000:03:00.0: reg 18: [io 0xac00-0xacff] [ 0.188134] pci 0000:03:00.0: reg 30: [mem 0x00000000-0x0001ffff pref] [ 0.188162] pci 0000:03:00.0: supports D1 D2 [ 0.188164] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.196022] pci 0000:00:0b.0: PCI bridge to [bus 03-03] [ 0.196026] pci 0000:00:0b.0: bridge window [io 0xa000-0xafff] [ 0.196030] pci 0000:00:0b.0: bridge window [mem 0xfdc00000-0xfdcfffff] [ 0.196034] pci 0000:00:0b.0: bridge window [mem 0xfdb00000-0xfdbfffff 64bit pref] [ 0.196076] pci 0000:04:00.0: [10ec:8178] type 00 class 0x028000 [ 0.196091] pci 0000:04:00.0: reg 10: [io 0x9c00-0x9cff] [ 0.196115] pci 0000:04:00.0: reg 18: [mem 0xfdafc000-0xfdafffff 64bit] [ 0.196166] pci 0000:04:00.0: supports D1 D2 [ 0.196169] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.204023] pci 0000:00:0c.0: PCI bridge to [bus 04-04] [ 0.204027] pci 0000:00:0c.0: bridge window [io 0x9000-0x9fff] [ 0.204031] pci 0000:00:0c.0: bridge window [mem 0xfda00000-0xfdafffff] [ 0.204035] pci 0000:00:0c.0: bridge window [mem 0xfd900000-0xfd9fffff 64bit pref] [ 0.204045] pci_bus 0000:00: on NUMA node 0 [ 0.204050] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT] [ 0.204242] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT] [ 0.204410] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f) [ 0.244092] ACPI: PCI Interrupt Link [LNK1] (IRQs 5 7 9 10 11 14 15) *0, disabled. [ 0.244152] ACPI: PCI Interrupt Link [LNK2] (IRQs 5 7 9 10 11 14 15) *0, disabled. [ 0.244209] ACPI: PCI Interrupt Link [LNK3] (IRQs 5 7 9 10 11 14 15) *0, disabled. [ 0.244267] ACPI: PCI Interrupt Link [LNK4] (IRQs 5 7 9 10 *11 14 15) [ 0.244323] ACPI: PCI Interrupt Link [LNK5] (IRQs *5 7 9 10 11 14 15) [ 0.244378] ACPI: PCI Interrupt Link [LNK6] (IRQs 5 7 9 *10 11 14 15) [ 0.244433] ACPI: PCI Interrupt Link [LNK7] (IRQs 5 7 9 10 11 14 15) *0, disabled. [ 0.244490] ACPI: PCI Interrupt Link [LNK8] (IRQs 5 7 9 10 *11 14 15) [ 0.244544] ACPI: PCI Interrupt Link [LIGP] (IRQs 5 7 9 10 11 14 15) *0, disabled. [ 0.244599] ACPI: PCI Interrupt Link [LP2P] (IRQs 5 7 9 10 11 14 15) *0, disabled. [ 0.244656] ACPI: PCI Interrupt Link [LUBA] (IRQs *5 7 9 10 11 14 15) [ 0.244710] ACPI: PCI Interrupt Link [LMAC] (IRQs 5 7 9 10 11 14 15) *0, disabled. [ 0.244767] ACPI: PCI Interrupt Link [LAZA] (IRQs 5 7 9 *10 11 14 15) [ 0.244822] ACPI: PCI Interrupt Link [LPMU] (IRQs *5 7 9 10 11 14 15) [ 0.244878] ACPI: PCI Interrupt Link [LSMB] (IRQs 5 7 9 10 *11 14 15) [ 0.244933] ACPI: PCI Interrupt Link [LUB2] (IRQs 5 7 9 *10 11 14 15) [ 0.244988] ACPI: PCI Interrupt Link [LIDE] (IRQs 5 7 9 10 11 14 15) *0, disabled. [ 0.245044] ACPI: PCI Interrupt Link [LSID] (IRQs 5 7 9 10 *11 14 15) [ 0.245098] ACPI: PCI Interrupt Link [LFID] (IRQs 5 7 9 10 11 14 15) *0, disabled. [ 0.245200] ACPI: PCI Interrupt Link [APC1] (IRQs 16) *0, disabled. [ 0.245295] ACPI: PCI Interrupt Link [APC2] (IRQs 17) *0, disabled. [ 0.245389] ACPI: PCI Interrupt Link [APC3] (IRQs 18) *0, disabled. [ 0.245482] ACPI: PCI Interrupt Link [APC4] (IRQs 19) *0 [ 0.245575] ACPI: PCI Interrupt Link [APC5] (IRQs 16) *0 [ 0.245668] ACPI: PCI Interrupt Link [APC6] (IRQs 16) *0 [ 0.245761] ACPI: PCI Interrupt Link [APC7] (IRQs 16) *0, disabled. [ 0.245855] ACPI: PCI Interrupt Link [APC8] (IRQs 16) *0 [ 0.245949] ACPI: PCI Interrupt Link [AIGP] (IRQs 20 21 22 23) *0, disabled. [ 0.246045] ACPI: PCI Interrupt Link [APCF] (IRQs 20 21 22 23) *0 [ 0.246140] ACPI: PCI Interrupt Link [APCH] (IRQs 20 21 22 23) *0, disabled. [ 0.246236] ACPI: PCI Interrupt Link [APMU] (IRQs 20 21 22 23) *0 [ 0.246332] ACPI: PCI Interrupt Link [AAZA] (IRQs 20 21 22 23) *0 [ 0.246429] ACPI: PCI Interrupt Link [APCS] (IRQs 20 21 22 23) *0 [ 0.246524] ACPI: PCI Interrupt Link [APCL] (IRQs 20 21 22 23) *0 [ 0.246619] ACPI: PCI Interrupt Link [APCM] (IRQs 20 21 22 23) *0, disabled. [ 0.246714] ACPI: PCI Interrupt Link [APCZ] (IRQs 20 21 22 23) *0, disabled. [ 0.246809] ACPI: PCI Interrupt Link [APSI] (IRQs 20 21 22 23) *0 [ 0.246905] ACPI: PCI Interrupt Link [APSJ] (IRQs 20 21 22 23) *0, disabled. [ 0.246974] vgaarb: device added: PCI:0000:02:00.0,decodes=io+mem,owns=io+mem,locks=none [ 0.246974] vgaarb: loaded [ 0.246974] vgaarb: bridge control possible 0000:02:00.0 [ 0.246974] PCI: Using ACPI for IRQ routing [ 0.248590] PCI: pci_cache_line_size set to 64 bytes [ 0.248655] reserve RAM buffer: 000000000009f400 - 000000000009ffff [ 0.248658] reserve RAM buffer: 00000000dfff0000 - 00000000dfffffff [ 0.248823] hpet0: at MMIO 0xfeff0000, IRQs 2, 8, 31 [ 0.248829] hpet0: 3 comparators, 32-bit 25.000000 MHz counter [ 0.250874] Switching to clocksource hpet [ 0.250965] pnp: PnP ACPI init [ 0.250977] ACPI: bus type pnp registered [ 0.251676] pnp 00:00: [bus 00-04] [ 0.251680] pnp 00:00: [io 0x0cf8-0x0cff] [ 0.251684] pnp 00:00: [io 0x0000-0x03af window] [ 0.251687] pnp 00:00: [io 0x03e0-0x0cf7 window] [ 0.251690] pnp 00:00: [io 0x9000-0xffff window] [ 0.251693] pnp 00:00: [io 0x03b0-0x03df window] [ 0.251697] pnp 00:00: [mem 0x000a0000-0x000bffff window] [ 0.251700] pnp 00:00: [mem 0xe0000000-0xefffffff window] [ 0.251703] pnp 00:00: [mem 0xf4000000-0xfe02ffff window] [ 0.251706] pnp 00:00: [mem 0xfed40000-0xfed44fff window] [ 0.251709] pnp 00:00: [io 0x4700-0x470b window] [ 0.251713] pnp 00:00: [io 0x1c00-0x1c80 window] [ 0.251716] pnp 00:00: [mem 0xfec80000-0xfecbffff window] [ 0.251786] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active) [ 0.251845] pnp 00:01: [io 0x1000-0x107f] [ 0.251848] pnp 00:01: [io 0x1080-0x10ff] [ 0.251851] pnp 00:01: [io 0x1400-0x147f] [ 0.251853] pnp 00:01: [io 0x1480-0x14ff] [ 0.251856] pnp 00:01: [io 0x1800-0x187f] [ 0.251859] pnp 00:01: [io 0x1880-0x18ff] [ 0.251862] pnp 00:01: [mem 0xfefe0000-0xfefe01ff] [ 0.251864] pnp 00:01: [mem 0xfefe1000-0xfefe10ff] [ 0.251867] pnp 00:01: [mem 0x00000000-0xffffffff disabled] [ 0.251922] system 00:01: [io 0x1000-0x107f] has been reserved [ 0.251925] system 00:01: [io 0x1080-0x10ff] has been reserved [ 0.251929] system 00:01: [io 0x1400-0x147f] has been reserved [ 0.251932] system 00:01: [io 0x1480-0x14ff] has been reserved [ 0.251936] system 00:01: [io 0x1800-0x187f] has been reserved [ 0.251940] system 00:01: [io 0x1880-0x18ff] has been reserved [ 0.251943] system 00:01: [mem 0xfefe0000-0xfefe01ff] has been reserved [ 0.251947] system 00:01: [mem 0xfefe1000-0xfefe10ff] has been reserved [ 0.251951] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.251951] pnp 00:02: [io 0x0010-0x001f] [ 0.251951] pnp 00:02: [io 0x0022-0x003f] [ 0.251951] pnp 00:02: [io 0x0044-0x004d] [ 0.251951] pnp 00:02: [io 0x0050-0x005e] [ 0.251951] pnp 00:02: [io 0x0062-0x0063] [ 0.251951] pnp 00:02: [io 0x0065-0x006f] [ 0.251951] pnp 00:02: [io 0x0074-0x007f] [ 0.251951] pnp 00:02: [io 0x0091-0x0093] [ 0.251951] pnp 00:02: [io 0x00a2-0x00bf] [ 0.251951] pnp 00:02: [io 0x00e0-0x00ef] [ 0.251951] pnp 00:02: [io 0x04d0-0x04d1] [ 0.251951] pnp 00:02: [io 0x0800-0x087f] [ 0.251951] pnp 00:02: [io 0x0290-0x0297] [ 0.251951] system 00:02: [io 0x04d0-0x04d1] has been reserved [ 0.251951] system 00:02: [io 0x0800-0x087f] has been reserved [ 0.251951] system 00:02: [io 0x0290-0x0297] has been reserved [ 0.251951] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.251951] pnp 00:03: [dma 4] [ 0.251951] pnp 00:03: [io 0x0000-0x000f] [ 0.251951] pnp 00:03: [io 0x0080-0x0090] [ 0.251951] pnp 00:03: [io 0x0094-0x009f] [ 0.251951] pnp 00:03: [io 0x00c0-0x00df] [ 0.251951] pnp 00:03: Plug and Play ACPI device, IDs PNP0200 (active) [ 0.251951] pnp 00:04: [irq 0 disabled] [ 0.251951] pnp 00:04: [irq 8] [ 0.251951] pnp 00:04: [mem 0xfeff0000-0xfeff03ff] [ 0.251951] pnp 00:04: Plug and Play ACPI device, IDs PNP0103 (active) [ 0.251951] pnp 00:05: [io 0x0070-0x0073] [ 0.251951] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active) [ 0.251951] pnp 00:06: [io 0x0061] [ 0.251951] pnp 00:06: Plug and Play ACPI device, IDs PNP0800 (active) [ 0.251951] pnp 00:07: [io 0x00f0-0x00ff] [ 0.251951] pnp 00:07: [irq 13] [ 0.251951] pnp 00:07: Plug and Play ACPI device, IDs PNP0c04 (active) [ 0.251951] pnp 00:08: [io 0x03f8-0x03ff] [ 0.251951] pnp 00:08: [irq 4] [ 0.251951] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active) [ 0.251951] pnp 00:09: [io 0x02f8-0x02ff] [ 0.251951] pnp 00:09: [irq 3] [ 0.251951] pnp 00:09: Plug and Play ACPI device, IDs PNP0501 (active) [ 0.251951] pnp 00:0a: [io 0x0378-0x037f] [ 0.251951] pnp 00:0a: [irq 7] [ 0.251951] pnp 00:0a: Plug and Play ACPI device, IDs PNP0400 (active) [ 0.251951] pnp 00:0b: [io 0x0060] [ 0.251951] pnp 00:0b: [io 0x0064] [ 0.251951] pnp 00:0b: [irq 1] [ 0.251951] pnp 00:0b: Plug and Play ACPI device, IDs PNP0303 PNP030b (active) [ 0.251951] pnp 00:0c: [mem 0xf0000000-0xf3ffffff] [ 0.251951] system 00:0c: [mem 0xf0000000-0xf3ffffff] has been reserved [ 0.251951] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.252064] pnp 00:0d: [mem 0x000d0000-0x000d3fff] [ 0.252067] pnp 00:0d: [mem 0x000f0000-0x000f7fff] [ 0.252070] pnp 00:0d: [mem 0x000f8000-0x000fbfff] [ 0.252073] pnp 00:0d: [mem 0x000fc000-0x000fffff] [ 0.252076] pnp 00:0d: [mem 0xfeff0000-0xfeff00ff] [ 0.252079] pnp 00:0d: [mem 0xdfff0000-0xdfffffff] [ 0.252082] pnp 00:0d: [mem 0xffff0000-0xffffffff] [ 0.252085] pnp 00:0d: [mem 0x00000000-0x0009ffff] [ 0.252088] pnp 00:0d: [mem 0x00100000-0xdffeffff] [ 0.252091] pnp 00:0d: [mem 0x00000000-0xffffffff disabled] [ 0.252094] pnp 00:0d: [mem 0xfec00000-0xfec00fff] [ 0.252097] pnp 00:0d: [mem 0xfee00000-0xfeefffff] [ 0.252101] pnp 00:0d: [mem 0xfefff000-0xfeffffff] [ 0.252104] pnp 00:0d: [mem 0xfff80000-0xfff80fff] [ 0.252107] pnp 00:0d: [mem 0xfff90000-0xfffbffff] [ 0.252110] pnp 00:0d: [mem 0xfffed000-0xfffeffff] [ 0.252200] system 00:0d: [mem 0x000d0000-0x000d3fff] has been reserved [ 0.252204] system 00:0d: [mem 0x000f0000-0x000f7fff] could not be reserved [ 0.252208] system 00:0d: [mem 0x000f8000-0x000fbfff] could not be reserved [ 0.252212] system 00:0d: [mem 0x000fc000-0x000fffff] could not be reserved [ 0.252215] system 00:0d: [mem 0xfeff0000-0xfeff00ff] has been reserved [ 0.252219] system 00:0d: [mem 0xdfff0000-0xdfffffff] could not be reserved [ 0.252223] system 00:0d: [mem 0xffff0000-0xffffffff] has been reserved [ 0.252227] system 00:0d: [mem 0x00000000-0x0009ffff] could not be reserved [ 0.252230] system 00:0d: [mem 0x00100000-0xdffeffff] could not be reserved [ 0.252234] system 00:0d: [mem 0xfec00000-0xfec00fff] could not be reserved [ 0.252238] system 00:0d: [mem 0xfee00000-0xfeefffff] has been reserved [ 0.252243] system 00:0d: [mem 0xfefff000-0xfeffffff] has been reserved [ 0.252247] system 00:0d: [mem 0xfff80000-0xfff80fff] has been reserved [ 0.252251] system 00:0d: [mem 0xfff90000-0xfffbffff] has been reserved [ 0.252254] system 00:0d: [mem 0xfffed000-0xfffeffff] has been reserved [ 0.252258] system 00:0d: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.252284] pnp: PnP ACPI: found 14 devices [ 0.252286] ACPI: ACPI bus type pnp unregistered [ 0.252290] PnPBIOS: Disabled by ACPI PNP [ 0.289891] pci 0000:00:04.0: PCI bridge to [bus 01-01] [ 0.289896] pci 0000:00:04.0: bridge window [io 0xc000-0xcfff] [ 0.289900] pci 0000:00:04.0: bridge window [mem 0xfde00000-0xfdefffff] [ 0.289904] pci 0000:00:04.0: bridge window [mem 0xfdd00000-0xfddfffff pref] [ 0.289913] pci 0000:02:00.0: BAR 6: assigned [mem 0xfb000000-0xfb07ffff pref] [ 0.289917] pci 0000:00:09.0: PCI bridge to [bus 02-02] [ 0.289920] pci 0000:00:09.0: bridge window [io 0xb000-0xbfff] [ 0.289924] pci 0000:00:09.0: bridge window [mem 0xf8000000-0xfbffffff] [ 0.289928] pci 0000:00:09.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref] [ 0.289933] pci 0000:03:00.0: BAR 6: assigned [mem 0xfdb00000-0xfdb1ffff pref] [ 0.289937] pci 0000:00:0b.0: PCI bridge to [bus 03-03] [ 0.289940] pci 0000:00:0b.0: bridge window [io 0xa000-0xafff] [ 0.289944] pci 0000:00:0b.0: bridge window [mem 0xfdc00000-0xfdcfffff] [ 0.289948] pci 0000:00:0b.0: bridge window [mem 0xfdb00000-0xfdbfffff 64bit pref] [ 0.289952] pci 0000:00:0c.0: PCI bridge to [bus 04-04] [ 0.289955] pci 0000:00:0c.0: bridge window [io 0x9000-0x9fff] [ 0.289959] pci 0000:00:0c.0: bridge window [mem 0xfda00000-0xfdafffff] [ 0.289963] pci 0000:00:0c.0: bridge window [mem 0xfd900000-0xfd9fffff 64bit pref] [ 0.289974] pci 0000:00:04.0: setting latency timer to 64 [ 0.289986] pci_bus 0000:00: resource 4 [io 0x0000-0xffff] [ 0.289989] pci_bus 0000:00: resource 5 [mem 0x000a0000-0x000bffff] [ 0.289992] pci_bus 0000:00: resource 6 [mem 0xe0000000-0xf3ffffff] [ 0.289995] pci_bus 0000:00: resource 7 [mem 0xf4000000-0xffffffff] [ 0.289998] pci_bus 0000:01: resource 0 [io 0xc000-0xcfff] [ 0.290001] pci_bus 0000:01: resource 1 [mem 0xfde00000-0xfdefffff] [ 0.290004] pci_bus 0000:01: resource 2 [mem 0xfdd00000-0xfddfffff pref] [ 0.290007] pci_bus 0000:01: resource 4 [io 0x0000-0xffff] [ 0.290010] pci_bus 0000:01: resource 5 [mem 0x000a0000-0x000bffff] [ 0.290013] pci_bus 0000:01: resource 6 [mem 0xe0000000-0xf3ffffff] [ 0.290016] pci_bus 0000:01: resource 7 [mem 0xf4000000-0xffffffff] [ 0.290019] pci_bus 0000:02: resource 0 [io 0xb000-0xbfff] [ 0.290023] pci_bus 0000:02: resource 1 [mem 0xf8000000-0xfbffffff] [ 0.290026] pci_bus 0000:02: resource 2 [mem 0xe0000000-0xefffffff 64bit pref] [ 0.290029] pci_bus 0000:03: resource 0 [io 0xa000-0xafff] [ 0.290032] pci_bus 0000:03: resource 1 [mem 0xfdc00000-0xfdcfffff] [ 0.290035] pci_bus 0000:03: resource 2 [mem 0xfdb00000-0xfdbfffff 64bit pref] [ 0.290038] pci_bus 0000:04: resource 0 [io 0x9000-0x9fff] [ 0.290041] pci_bus 0000:04: resource 1 [mem 0xfda00000-0xfdafffff] [ 0.290044] pci_bus 0000:04: resource 2 [mem 0xfd900000-0xfd9fffff 64bit pref] [ 0.290149] NET: Registered protocol family 2 [ 0.290223] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.290484] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.291119] TCP bind hash table entries: 65536 (order: 7, 524288 bytes) [ 0.291439] TCP: Hash tables configured (established 131072 bind 65536) [ 0.291442] TCP: reno registered [ 0.291445] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.291457] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.291577] NET: Registered protocol family 1 [ 0.291822] ACPI: PCI Interrupt Link [APCF] enabled at IRQ 23 [ 0.360191] ACPI: PCI Interrupt Link [APCL] enabled at IRQ 22 [ 0.360239] pci 0000:02:00.0: Boot video device [ 0.360248] PCI: CLS 64 bytes, default 64 [ 0.360308] Unpacking initramfs... [ 0.721084] Freeing initrd memory: 14896k freed [ 0.730101] audit: initializing netlink socket (disabled) [ 0.730119] type=2000 audit(1587840438.724:1): initialized [ 0.743590] highmem bounce pool size: 64 pages [ 0.743596] HugeTLB registered 4 MB page size, pre-allocated 0 pages [ 0.743862] VFS: Disk quotas dquot_6.5.2 [ 0.743896] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.743980] msgmni has been set to 1691 [ 0.744218] alg: No test for stdrng (krng) [ 0.744258] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 0.744263] io scheduler noop registered [ 0.744265] io scheduler deadline registered [ 0.744292] io scheduler cfq registered (default) [ 0.744504] pci_hotplug: PCI Hot Plug PCI Core version: 0.5 [ 0.744529] pciehp: PCI Express Hot Plug Controller Driver version: 0.4 [ 0.744532] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5 [ 0.745167] GHES: HEST is not enabled! [ 0.745180] isapnp: Scanning for PnP cards... [ 1.097929] isapnp: No Plug & Play device found [ 1.097992] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 1.118322] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 1.138675] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A [ 1.159262] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 1.179669] 00:09: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A [ 1.179943] Linux agpgart interface v0.103 [ 1.180317] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1 [ 1.180320] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp [ 1.180484] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 1.180615] mousedev: PS/2 mouse device common for all mice [ 1.180670] rtc_cmos 00:05: RTC can wake from S4 [ 1.180842] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0 [ 1.180883] rtc0: alarms up to one year, y3k, 242 bytes nvram, hpet irqs [ 1.181029] TCP: cubic registered [ 1.181098] NET: Registered protocol family 10 [ 1.181334] Mobile IPv6 [ 1.181338] NET: Registered protocol family 17 [ 1.181343] Registering the dns_resolver key type [ 1.181399] Using IPI No-Shortcut mode [ 1.181523] PM: Hibernation image not present or could not be loaded. [ 1.181538] registered taskstats version 1 [ 1.181920] rtc_cmos 00:05: setting system clock to 2020-04-25 18:47:20 UTC (1587840440) [ 1.182048] Freeing unused kernel memory: 416k freed [ 1.182362] Write protecting the kernel text: 3496k [ 1.182389] Write protecting the kernel read-only data: 984k [ 1.196386] udevd[49]: starting version 175 [ 1.198620] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0 [ 1.223940] usbcore: registered new interface driver usbfs [ 1.223974] usbcore: registered new interface driver hub [ 1.226909] SCSI subsystem initialized [ 1.228110] usbcore: registered new device driver usb [ 1.228688] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.228758] ehci_hcd 0000:00:02.1: setting latency timer to 64 [ 1.228763] ehci_hcd 0000:00:02.1: EHCI Host Controller [ 1.228800] ehci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 1 [ 1.228831] ehci_hcd 0000:00:02.1: debug port 1 [ 1.228841] ehci_hcd 0000:00:02.1: cache line size of 64 is not supported [ 1.228870] ehci_hcd 0000:00:02.1: irq 22, io mem 0xfe02e000 [ 1.230986] libata version 3.00 loaded. [ 1.240053] ehci_hcd 0000:00:02.1: USB 2.0 started, EHCI 1.00 [ 1.240116] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.240120] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.240123] usb usb1: Product: EHCI Host Controller [ 1.240126] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd [ 1.240129] usb usb1: SerialNumber: 0000:00:02.1 [ 1.240300] hub 1-0:1.0: USB hub found [ 1.240307] hub 1-0:1.0: 8 ports detected [ 1.240654] pata_amd 0000:00:06.0: version 0.4.1 [ 1.240719] pata_amd 0000:00:06.0: setting latency timer to 64 [ 1.241642] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.241689] scsi0 : pata_amd [ 1.241980] scsi1 : pata_amd [ 1.242562] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xf000 irq 14 [ 1.242566] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xf008 irq 15 [ 1.242742] sata_nv 0000:00:08.0: version 3.5 [ 1.242929] ACPI: PCI Interrupt Link [APSI] enabled at IRQ 21 [ 1.243012] sata_nv 0000:00:08.0: setting latency timer to 64 [ 1.243299] scsi2 : sata_nv [ 1.243371] scsi3 : sata_nv [ 1.243509] ata3: SATA max UDMA/133 cmd 0x9f0 ctl 0xbf0 bmdma 0xdc00 irq 21 [ 1.243513] ata4: SATA max UDMA/133 cmd 0x970 ctl 0xb70 bmdma 0xdc08 irq 21 [ 1.243559] ohci_hcd 0000:00:02.0: setting latency timer to 64 [ 1.243564] ohci_hcd 0000:00:02.0: OHCI Host Controller [ 1.243584] ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 2 [ 1.243611] ohci_hcd 0000:00:02.0: irq 23, io mem 0xfe02f000 [ 1.262824] sky2: driver version 1.30 [ 1.263091] ACPI: PCI Interrupt Link [APC6] enabled at IRQ 16 [ 1.263166] sky2 0000:03:00.0: Yukon-2 EC Ultra chip revision 2 [ 1.271169] microcode: AMD CPU family 0xf not supported [ 1.286998] sky2 0000:03:00.0: eth0: addr 00:19:21:59:af:8d [ 1.298077] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.298083] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.298087] usb usb2: Product: OHCI Host Controller [ 1.298090] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ohci_hcd [ 1.298094] usb usb2: SerialNumber: 0000:00:02.0 [ 1.298261] hub 2-0:1.0: USB hub found [ 1.298270] hub 2-0:1.0: 8 ports detected [ 1.439176] ata1.00: ATA-7: ST3802110A, 2AAA, max UDMA/100 [ 1.439182] ata1.00: 156301488 sectors, multi 16: LBA48 [ 1.439193] ata1: nv_mode_filter: 0x3f39f&0x3f39f->0x3f39f, BIOS=0x3f000 (0xc6000000) ACPI=0x3f01f (20:600:0x13) [ 1.505774] ata1.00: configured for UDMA/100 [ 1.505963] scsi 0:0:0:0: Direct-Access ATA ST3802110A 2AAA PQ: 0 ANSI: 5 [ 1.506207] ata2: port disabled--ignoring [ 1.562282] ata3: SATA link down (SStatus 0 SControl 300) [ 1.612021] usb 1-2: new high-speed USB device number 3 using ehci_hcd [ 1.744650] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101 [ 1.744654] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 1.744657] usb 1-2: Product: USB 2.0 Hub [ 1.744961] hub 1-2:1.0: USB hub found [ 1.745026] hub 1-2:1.0: 4 ports detected [ 2.028038] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300) [ 2.036127] ata4.00: ATAPI: ATAPI iHAS122 8, 3L03, max UDMA/100 [ 2.052117] ata4.00: configured for UDMA/100 [ 2.054440] scsi 3:0:0:0: CD-ROM ATAPI iHAS122 8 3L03 PQ: 0 ANSI: 5 [ 2.055023] ACPI: Fan [FAN] (on) [ 2.056973] ACPI: PCI Interrupt Link [APC4] enabled at IRQ 19 [ 2.057001] firewire_ohci 0000:01:09.0: setting latency timer to 64 [ 2.062787] sd 0:0:0:0: [sda] 156301488 512-byte logical blocks: (80.0 GB/74.5 GiB) [ 2.062846] sd 0:0:0:0: [sda] Write Protect is off [ 2.062850] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 2.062874] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 2.096772] sda: sda1 sda2 < sda5 > [ 2.097227] sd 0:0:0:0: [sda] Attached SCSI disk [ 2.099397] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 2.099451] sr 3:0:0:0: Attached scsi generic sg1 type 5 [ 2.102903] sr0: scsi3-mmc drive: 48x/12x writer dvd-ram cd/rw xa/form2 cdda tray [ 2.102910] cdrom: Uniform CD-ROM driver Revision: 3.20 [ 2.104263] sr 3:0:0:0: Attached scsi CD-ROM sr0 [ 2.112128] firewire_ohci 0000:01:09.0: added OHCI v1.10 device as card 0, 4 IR + 8 IT contexts, quirks 0x2 [ 2.160030] usb 2-1: new low-speed USB device number 2 using ohci_hcd [ 2.369082] usb 2-1: New USB device found, idVendor=093a, idProduct=2521 [ 2.369087] usb 2-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0 [ 2.369091] usb 2-1: Product: USB OPTICAL MOUSE [ 2.612128] firewire_core 0000:01:09.0: created device fw0: GUID 00001921ff14f360, S400 [ 2.676019] usb 2-6: new full-speed USB device number 3 using ohci_hcd [ 2.891074] usb 2-6: New USB device found, idVendor=058f, idProduct=9360 [ 2.891077] usb 2-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 2.891080] usb 2-6: Product: USB Reader [ 2.891083] usb 2-6: Manufacturer: [ 2.891085] usb 2-6: SerialNumber: 2004888 [ 2.899707] Initializing USB Mass Storage driver... [ 2.900055] scsi4 : usb-storage 2-6:1.0 [ 2.900157] usbcore: registered new interface driver usb-storage [ 2.900161] USB Mass Storage support registered. [ 2.904657] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:02.0/usb2/2-1/2-1:1.0/input/input1 [ 2.904762] generic-usb 0003:093A:2521.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE] on usb-0000:00:02.0-1/input0 [ 2.904796] usbcore: registered new interface driver usbhid [ 2.904799] usbhid: USB HID core driver [ 2.964169] usb 1-2.4: new high-speed USB device number 5 using ehci_hcd [ 3.060401] usb 1-2.4: New USB device found, idVendor=f007, idProduct=a999 [ 3.060405] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 3.060408] usb 1-2.4: Product: Teslong Camera [ 3.060410] usb 1-2.4: Manufacturer: Teslong Camera [ 3.908108] scsi 4:0:0:0: Direct-Access Generic USB SD Reader 1.00 PQ: 0 ANSI: 0 [ 3.915097] scsi 4:0:0:1: Direct-Access Generic USB CF Reader 1.01 PQ: 0 ANSI: 0 [ 3.922095] scsi 4:0:0:2: Direct-Access Generic USB SM Reader 1.02 PQ: 0 ANSI: 0 [ 3.929096] scsi 4:0:0:3: Direct-Access Generic USB MS Reader 1.03 PQ: 0 ANSI: 0 [ 3.929774] sd 4:0:0:0: Attached scsi generic sg2 type 0 [ 3.929951] sd 4:0:0:1: Attached scsi generic sg3 type 0 [ 3.930101] sd 4:0:0:2: Attached scsi generic sg4 type 0 [ 3.930273] sd 4:0:0:3: Attached scsi generic sg5 type 0 [ 4.204091] sd 4:0:0:0: [sdb] Attached SCSI removable disk [ 4.215085] sd 4:0:0:1: [sdc] Attached SCSI removable disk [ 4.226084] sd 4:0:0:2: [sdd] Attached SCSI removable disk [ 4.237089] sd 4:0:0:3: [sde] Attached SCSI removable disk [ 7.927563] microcode: AMD CPU family 0xf not supported [ 7.930210] microcode: AMD CPU family 0xf not supported [ 7.943489] device-mapper: uevent: version 1.0.3 [ 7.943583] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com [ 8.434088] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null) [ 10.972520] udevd[442]: starting version 175 [ 11.237534] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2 [ 11.237543] ACPI: Power Button [PWRB] [ 11.237660] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3 [ 11.237664] ACPI: Power Button [PWRF] [ 11.770649] k8temp 0000:00:18.3: Temperature readouts might be wrong - check erratum #141 [ 11.801126] i2c i2c-0: nForce2 SMBus adapter at 0x1c00 [ 11.801157] i2c i2c-1: nForce2 SMBus adapter at 0xf400 [ 11.930339] microcode: AMD CPU family 0xf not supported [ 11.935707] parport_pc 00:0a: reported by Plug and Play ACPI [ 11.935756] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE] [ 12.135820] Linux media interface: v0.10 [ 12.288505] cfg80211: Calling CRDA to update world regulatory domain [ 12.345983] [drm] Initialized drm 1.1.0 20060810 [ 12.383877] ACPI: PCI Interrupt Link [APC5] enabled at IRQ 16 [ 12.391981] wmi: Mapper loaded [ 12.393975] rtl8192ce: Using firmware rtlwifi/rtl8192cfw.bin [ 12.429654] ACPI: PCI Interrupt Link [APC8] enabled at IRQ 16 [ 12.430270] [drm] nouveau 0000:02:00.0: Detected an NV50 generation card (0x096200a1) [ 12.434222] [drm] nouveau 0000:02:00.0: Checking PRAMIN for VBIOS [ 12.487284] [drm] nouveau 0000:02:00.0: ... appears to be valid [ 12.487290] [drm] nouveau 0000:02:00.0: Using VBIOS from PRAMIN [ 12.487294] [drm] nouveau 0000:02:00.0: BIT BIOS found [ 12.487298] [drm] nouveau 0000:02:00.0: Bios version 62.94.32.00 [ 12.487303] [drm] nouveau 0000:02:00.0: TMDS table version 2.0 [ 12.487568] [drm] nouveau 0000:02:00.0: MXM: no VBIOS data, nothing to do [ 12.487572] [drm] nouveau 0000:02:00.0: DCB version 4.0 [ 12.487576] [drm] nouveau 0000:02:00.0: DCB outp 00: 04000310 00000028 [ 12.487580] [drm] nouveau 0000:02:00.0: DCB outp 01: 01011302 00000030 [ 12.487583] [drm] nouveau 0000:02:00.0: DCB outp 02: 02011300 00000028 [ 12.487586] [drm] nouveau 0000:02:00.0: DCB outp 03: 02022332 00020010 [ 12.487589] [drm] nouveau 0000:02:00.0: DCB conn 00: 00000000 [ 12.487592] [drm] nouveau 0000:02:00.0: DCB conn 01: 00001130 [ 12.487596] [drm] nouveau 0000:02:00.0: DCB conn 02: 00002261 [ 12.487602] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 0 at offset 0xD0CE [ 12.500462] Linux video capture interface: v2.00 [ 12.512720] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 1 at offset 0xD4E3 [ 12.515798] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 2 at offset 0xE503 [ 12.515807] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 3 at offset 0xE64C [ 12.516879] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 4 at offset 0xE888 [ 12.516983] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table at offset 0xE8ED [ 12.536831] [drm] nouveau 0000:02:00.0: 0xE8ED: Condition still not met after 20ms, skipping following opcodes [ 12.538918] [TTM] Zone kernel: Available graphics memory: 433278 kiB [ 12.538922] [TTM] Zone highmem: Available graphics memory: 1813602 kiB [ 12.538925] [TTM] Initializing pool allocator [ 12.538941] [drm] nouveau 0000:02:00.0: Detected 512MiB VRAM (DDR2) [ 12.539224] [drm] nouveau 0000:02:00.0: 512 MiB GART (aperture) [ 12.545054] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010). [ 12.545057] [drm] No driver support for vblank timestamp query. [ 12.550587] [drm] nouveau 0000:02:00.0: 1 available performance level(s) [ 12.550593] [drm] nouveau 0000:02:00.0: 3: core 550MHz shader 1375MHz memory 510MHz fanspeed 100% [ 12.550597] [drm] nouveau 0000:02:00.0: c: core 400MHz shader 800MHz memory 499MHz fanspeed 100% [ 12.656376] [drm] nouveau 0000:02:00.0: allocated 1280x1024 fb: 0x330000, bo f6c9c600 [ 12.656473] fbcon: nouveaufb (fb0) is primary device [ 12.676308] Console: switching to colour frame buffer device 160x64 [ 12.677946] fb0: nouveaufb frame buffer device [ 12.677949] drm: registered panic notifier [ 12.677955] [drm] Initialized nouveau 1.0.0 20120316 for 0000:02:00.0 on minor 0 [ 12.736531] ACPI: PCI Interrupt Link [AAZA] enabled at IRQ 20 [ 12.736554] hda_intel: Disabling MSI [ 12.736606] snd_hda_intel 0000:00:05.0: setting latency timer to 64 [ 12.775791] ieee80211 phy0: Selected rate control algorithm 'rtl_rc' [ 12.776073] rtlwifi: wireless switch is on [ 12.796304] uvcvideo: Found UVC 1.00 device Teslong Camera (f007:a999) [ 12.832319] input: Teslong Camera as /devices/pci0000:00/0000:00:02.1/usb1/1-2/1-2.4/1-2.4:1.0/input/input4 [ 12.832415] usbcore: registered new interface driver uvcvideo [ 12.832417] USB Video Class driver (1.1.1) [ 13.488564] cfg80211: World regulatory domain updated: [ 13.488570] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 13.488574] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm) [ 13.488577] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm) [ 13.488580] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm) [ 13.488583] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 13.488585] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 13.488588] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm) [ 13.488591] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 13.488594] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm) [ 13.488610] cfg80211: Calling CRDA for country: EC [ 13.562024] cfg80211: Regulatory domain changed to country: EC [ 13.562030] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 13.562034] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm) [ 13.562037] cfg80211: (5170000 KHz - 5250000 KHz @ 20000 KHz), (N/A, 1700 mBm) [ 13.562040] cfg80211: (5250000 KHz - 5330000 KHz @ 20000 KHz), (N/A, 2400 mBm) [ 13.562043] cfg80211: (5490000 KHz - 5730000 KHz @ 20000 KHz), (N/A, 2400 mBm) [ 13.562046] cfg80211: (5735000 KHz - 5835000 KHz @ 20000 KHz), (N/A, 3000 mBm) [ 13.884097] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:05.0/input/input5 [ 14.676114] input: HDA NVidia Line as /devices/pci0000:00/0000:00:05.0/sound/card0/input6 [ 14.676223] input: HDA NVidia Rear Mic as /devices/pci0000:00/0000:00:05.0/sound/card0/input7 [ 14.676311] input: HDA NVidia Line Out Side as /devices/pci0000:00/0000:00:05.0/sound/card0/input8 [ 14.676400] input: HDA NVidia Line Out CLFE as /devices/pci0000:00/0000:00:05.0/sound/card0/input9 [ 14.676487] input: HDA NVidia Line Out Surround as /devices/pci0000:00/0000:00:05.0/sound/card0/input10 [ 14.676574] input: HDA NVidia Line Out Front as /devices/pci0000:00/0000:00:05.0/sound/card0/input11 [ 16.811012] EXT4-fs (dm-0): re-mounted. Opts: (null) [ 17.375284] EXT4-fs (dm-0): re-mounted. Opts: errors=remount-ro [ 17.533106] loop: module loaded [ 17.970054] Adding 3203068k swap on /dev/mapper/RS--CNC-swap_1. Priority:-1 extents:1 across:3203068k [ 19.310367] RPC: Registered named UNIX socket transport module. [ 19.310372] RPC: Registered udp transport module. [ 19.310374] RPC: Registered tcp transport module. [ 19.310377] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 19.358518] FS-Cache: Loaded [ 19.402979] NFS: Registering the id_resolver key type [ 19.403009] FS-Cache: Netfs 'nfs' registered for caching [ 19.422091] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 21.565322] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input12 [ 23.518611] Bluetooth: Core ver 2.16 [ 23.518648] NET: Registered protocol family 31 [ 23.518651] Bluetooth: HCI device and connection manager initialized [ 23.518655] Bluetooth: HCI socket layer initialized [ 23.518658] Bluetooth: L2CAP socket layer initialized [ 23.518665] Bluetooth: SCO socket layer initialized [ 23.554112] Bluetooth: RFCOMM TTY layer initialized [ 23.554121] Bluetooth: RFCOMM socket layer initialized [ 23.554124] Bluetooth: RFCOMM ver 1.11 [ 23.650978] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 23.650982] Bluetooth: BNEP filters: protocol multicast [ 24.128106] lp0: using parport0 (interrupt-driven). [ 25.051239] ppdev: user-space parallel port driver [ 26.133911] sky2 0000:03:00.0: eth0: enabling interface [ 26.134118] ADDRCONF(NETDEV_UP): eth0: link is not ready [ 26.484186] ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 29.872923] wlan0: authenticate with c8:0e:14:a2:28:b5 [ 29.893582] wlan0: send auth to c8:0e:14:a2:28:b5 (try 1/3) [ 29.900671] wlan0: authenticated [ 29.912028] wlan0: associate with c8:0e:14:a2:28:b5 (try 1/3) [ 29.917973] wlan0: RX AssocResp from c8:0e:14:a2:28:b5 (capab=0x1431 status=0 aid=6) [ 29.928283] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready [ 29.928386] wlan0: associated [ 29.928431] cfg80211: Calling CRDA for country: DE [ 29.934206] cfg80211: Regulatory domain changed to country: DE [ 29.934212] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 29.934216] cfg80211: (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm) [ 29.934219] cfg80211: (5150000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 29.934223] cfg80211: (5250000 KHz - 5350000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 29.934225] cfg80211: (5470000 KHz - 5725000 KHz @ 160000 KHz), (N/A, 2698 mBm) [ 29.934228] cfg80211: (5725000 KHz - 5875000 KHz @ 80000 KHz), (N/A, 1397 mBm) [ 29.934231] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm) [ 487.571002] I-pipe: head domain RTAI registered. [ 487.571011] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 487.571057] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 487.571061] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12555225, CLK_FREQ 2209691000, CPU_FREQ 2209691000 [ 487.571065] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 487.571069] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12555225, 12555225, 8500250 [ 487.630377] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 487.630442] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 487.630447] RTAI[sched]: hard timer type/freq = APIC/12555225(Hz); default timing: oneshot; linear timed lists. [ 487.630451] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2209691000 hz. [ 487.630454] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 487.653717] RTAI[math]: loaded. [ 487.944459] config string '0 out' [ 661.855865] RTAI[math]: unloaded. [ 661.861306] SCHED releases registered named ALIEN PEDV$D [ 661.868469] RTAI[malloc]: unloaded. [ 661.968037] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 661.972002] I-pipe: head domain RTAI unregistered. [ 661.972091] RTAI[hal]: unmounted. [ 793.278000] I-pipe: head domain RTAI registered. [ 793.278009] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 793.278058] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 793.278062] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12555225, CLK_FREQ 2209691000, CPU_FREQ 2209691000 [ 793.278066] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 793.278069] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12555225, 12555225, 12479500 [ 793.288123] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 793.288191] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 793.288196] RTAI[sched]: hard timer type/freq = APIC/12555225(Hz); default timing: oneshot; linear timed lists. [ 793.288200] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2209691000 hz. [ 793.288204] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 793.293887] RTAI[math]: loaded. [ 793.443065] config string '0 out' [ 1183.148739] RTAI[math]: unloaded. [ 1183.151131] SCHED releases registered named ALIEN PEDV$D [ 1183.157063] RTAI[malloc]: unloaded. [ 1183.256019] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 1183.258297] I-pipe: head domain RTAI unregistered. [ 1183.258356] RTAI[hal]: unmounted. [ 1242.233066] wlan0: deauthenticating from c8:0e:14:a2:28:b5 by local choice (reason=3) [ 1242.293061] cfg80211: Calling CRDA to update world regulatory domain [ 1242.307354] cfg80211: World regulatory domain updated: [ 1242.307359] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 1242.307363] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm) [ 1242.307366] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm) [ 1242.307369] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm) [ 1242.307372] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 1242.307375] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 1242.307378] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm) [ 1242.307381] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 1242.307383] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm) [ 1246.188654] wlan0: authenticate with c8:0e:14:a2:28:b5 [ 1246.208831] wlan0: send auth to c8:0e:14:a2:28:b5 (try 1/3) [ 1246.212848] wlan0: authenticated [ 1246.224033] wlan0: associate with c8:0e:14:a2:28:b5 (try 1/3) [ 1246.230047] wlan0: RX AssocResp from c8:0e:14:a2:28:b5 (capab=0x1431 status=0 aid=6) [ 1246.240453] wlan0: associated [ 1246.240912] cfg80211: Calling CRDA for country: DE [ 1246.246578] cfg80211: Regulatory domain changed to country: DE [ 1246.246583] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 1246.246587] cfg80211: (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm) [ 1246.246590] cfg80211: (5150000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 1246.246593] cfg80211: (5250000 KHz - 5350000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 1246.246596] cfg80211: (5470000 KHz - 5725000 KHz @ 160000 KHz), (N/A, 2698 mBm) [ 1246.246599] cfg80211: (5725000 KHz - 5875000 KHz @ 80000 KHz), (N/A, 1397 mBm) [ 1246.246602] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm) [ 1438.136096] wlan0: deauthenticated from c8:0e:14:a2:28:b5 (Reason: 6) [ 1438.188110] cfg80211: Calling CRDA to update world regulatory domain [ 1438.193972] cfg80211: World regulatory domain updated: [ 1438.193978] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 1438.193982] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm) [ 1438.193985] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm) [ 1438.193988] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm) [ 1438.193992] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 1438.193995] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 1438.193998] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm) [ 1438.194000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 1438.194003] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm) [ 1439.440538] wlan0: authenticate with c8:0e:14:a2:28:b5 [ 1439.460145] wlan0: send auth to c8:0e:14:a2:28:b5 (try 1/3) [ 1439.463636] wlan0: authenticated [ 1439.476034] wlan0: associate with c8:0e:14:a2:28:b5 (try 1/3) [ 1439.481858] wlan0: RX AssocResp from c8:0e:14:a2:28:b5 (capab=0x1431 status=0 aid=6) [ 1439.492277] wlan0: associated [ 1439.492428] cfg80211: Calling CRDA for country: DE [ 1439.498424] cfg80211: Regulatory domain changed to country: DE [ 1439.498431] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 1439.498434] cfg80211: (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm) [ 1439.498437] cfg80211: (5150000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 1439.498440] cfg80211: (5250000 KHz - 5350000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 1439.498443] cfg80211: (5470000 KHz - 5725000 KHz @ 160000 KHz), (N/A, 2698 mBm) [ 1439.498446] cfg80211: (5725000 KHz - 5875000 KHz @ 80000 KHz), (N/A, 1397 mBm) [ 1439.498449] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm) [ 1549.786234] I-pipe: head domain RTAI registered. [ 1549.786243] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 1549.786290] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 1549.786295] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12555225, CLK_FREQ 2209691000, CPU_FREQ 2209691000 [ 1549.786299] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 1549.786303] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12555225, 12555225, 12484750 [ 1549.796329] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 1549.796393] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 1549.796398] RTAI[sched]: hard timer type/freq = APIC/12555225(Hz); default timing: oneshot; linear timed lists. [ 1549.796402] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2209691000 hz. [ 1549.796405] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 1549.803293] RTAI[math]: loaded. [ 1549.959858] config string '0 out' [ 1552.411898] RTAI[math]: unloaded. [ 1552.414308] SCHED releases registered named ALIEN PEDV$D [ 1552.419636] RTAI[malloc]: unloaded. [ 1552.516033] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 1552.518534] I-pipe: head domain RTAI unregistered. [ 1552.518593] RTAI[hal]: unmounted. [ 1579.777612] I-pipe: head domain RTAI registered. [ 1579.777621] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 1579.777663] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 1579.777669] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12555225, CLK_FREQ 2209691000, CPU_FREQ 2209691000 [ 1579.777672] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 1579.777676] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12555225, 12555225, 12446500 [ 1579.790642] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 1579.790705] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 1579.790710] RTAI[sched]: hard timer type/freq = APIC/12555225(Hz); default timing: oneshot; linear timed lists. [ 1579.790714] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2209691000 hz. [ 1579.790717] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 1579.796711] RTAI[math]: loaded. [ 1579.946249] config string '0 out' [ 1582.401084] RTAI[math]: unloaded. [ 1582.403463] SCHED releases registered named ALIEN PEDV$D [ 1582.409196] RTAI[malloc]: unloaded. [ 1582.508021] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 1582.510318] I-pipe: head domain RTAI unregistered. [ 1582.510376] RTAI[hal]: unmounted. [ 1596.059404] I-pipe: head domain RTAI registered. [ 1596.059412] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 1596.059460] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 1596.059464] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12555225, CLK_FREQ 2209691000, CPU_FREQ 2209691000 [ 1596.059467] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 1596.059471] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12555225, 12555225, 12482750 [ 1596.069873] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 1596.069935] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 1596.069940] RTAI[sched]: hard timer type/freq = APIC/12555225(Hz); default timing: oneshot; linear timed lists. [ 1596.069944] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2209691000 hz. [ 1596.069947] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 1596.075675] RTAI[math]: loaded. [ 1596.225422] config string '0 out' [ 1604.601737] spurious APIC interrupt on CPU#0, should never happen. [ 1604.606408] RTAI[math]: unloaded. [ 1604.608701] SCHED releases registered named ALIEN PEDV$D [ 1604.615157] RTAI[malloc]: unloaded. [ 1604.712022] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 1604.715026] I-pipe: head domain RTAI unregistered. [ 1604.715078] RTAI[hal]: unmounted. [ 1771.716533] I-pipe: head domain RTAI registered. [ 1771.716542] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 1771.716585] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 1771.716589] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12555225, CLK_FREQ 2209691000, CPU_FREQ 2209691000 [ 1771.716592] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 1771.716596] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12555225, 12555225, 12475250 [ 1771.730211] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 1771.730273] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 1771.730278] RTAI[sched]: hard timer type/freq = APIC/12555225(Hz); default timing: oneshot; linear timed lists. [ 1771.730282] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2209691000 hz. [ 1771.730285] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 1771.737564] RTAI[math]: loaded. [ 1771.889380] config string '0 out' [ 1822.993349] RTAI[math]: unloaded. [ 1822.995723] SCHED releases registered named ALIEN PEDV$D [ 1823.000948] RTAI[malloc]: unloaded. [ 1823.100020] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 1823.102374] I-pipe: head domain RTAI unregistered. [ 1823.102436] RTAI[hal]: unmounted. [ 1863.581320] I-pipe: head domain RTAI registered. [ 1863.581328] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 1863.581371] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 1863.581375] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12555225, CLK_FREQ 2209691000, CPU_FREQ 2209691000 [ 1863.581379] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 1863.581383] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12555225, 12555225, 12455250 [ 1863.591459] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 1863.591517] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 1863.591522] RTAI[sched]: hard timer type/freq = APIC/12555225(Hz); default timing: oneshot; linear timed lists. [ 1863.591526] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2209691000 hz. [ 1863.591528] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 1863.601751] RTAI[math]: loaded. [ 1863.757092] config string '0 out' [ 1895.488364] RTAI[math]: unloaded. [ 1895.490936] SCHED releases registered named ALIEN PEDV$D [ 1895.497115] RTAI[malloc]: unloaded. [ 1895.596022] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 1895.598303] I-pipe: head domain RTAI unregistered. [ 1895.598363] RTAI[hal]: unmounted. [ 2046.010060] I-pipe: head domain RTAI registered. [ 2046.010069] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 2046.010116] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 2046.010121] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12555225, CLK_FREQ 2209691000, CPU_FREQ 2209691000 [ 2046.010124] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 2046.010128] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12555225, 12555225, 12471000 [ 2046.023158] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 2046.023217] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 2046.023222] RTAI[sched]: hard timer type/freq = APIC/12555225(Hz); default timing: oneshot; linear timed lists. [ 2046.023226] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2209691000 hz. [ 2046.023228] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 2046.029077] RTAI[math]: loaded. [ 2046.178579] config string '0 out' [ 2166.228690] RTAI[math]: unloaded. [ 2166.231045] SCHED releases registered named ALIEN PEDV$D [ 2166.234132] RTAI[malloc]: unloaded. [ 2166.332025] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 2166.334358] I-pipe: head domain RTAI unregistered. [ 2166.334417] RTAI[hal]: unmounted. [ 2504.547001] I-pipe: head domain RTAI registered. [ 2504.547009] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 2504.547057] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 2504.547061] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12555225, CLK_FREQ 2209691000, CPU_FREQ 2209691000 [ 2504.547065] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 2504.547068] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12555225, 12555225, 12489750 [ 2504.559929] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 2504.559991] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 2504.559998] RTAI[sched]: hard timer type/freq = APIC/12555225(Hz); default timing: oneshot; linear timed lists. [ 2504.560051] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2209691000 hz. [ 2504.560054] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 2504.587281] RTAI[math]: loaded. [ 2504.636476] config string '0 out' [ 2507.500131] uvcvideo: Failed to query (SET_CUR) UVC control 5 on unit 3: -110 (exp. 1). [ 2631.631841] wlan0: deauthenticated from c8:0e:14:a2:28:b5 (Reason: 6) [ 2631.656141] cfg80211: Calling CRDA to update world regulatory domain [ 2631.662997] cfg80211: World regulatory domain updated: [ 2631.663004] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 2631.663007] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm) [ 2631.663011] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm) [ 2631.663014] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm) [ 2631.663016] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 2631.663019] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 2631.663022] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm) [ 2631.663026] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 2631.663029] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm) [ 2632.083513] uvcvideo: Failed to resubmit video URB (-27). [ 2632.083523] uvcvideo: Failed to resubmit video URB (-27). [ 2632.083534] uvcvideo: Failed to resubmit video URB (-27). [ 2632.083539] uvcvideo: Failed to resubmit video URB (-27). [ 2632.083544] uvcvideo: Failed to resubmit video URB (-27). [ 2632.917063] wlan0: authenticate with c8:0e:14:a2:28:b5 [ 2632.936206] wlan0: send auth to c8:0e:14:a2:28:b5 (try 1/3) [ 2632.939911] wlan0: authenticated [ 2632.952050] wlan0: associate with c8:0e:14:a2:28:b5 (try 1/3) [ 2632.958248] wlan0: RX AssocResp from c8:0e:14:a2:28:b5 (capab=0x1431 status=0 aid=6) [ 2632.968796] wlan0: associated [ 2632.969567] cfg80211: Calling CRDA for country: DE [ 2632.979288] cfg80211: Regulatory domain changed to country: DE [ 2632.979294] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 2632.979298] cfg80211: (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm) [ 2632.979301] cfg80211: (5150000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 2632.979304] cfg80211: (5250000 KHz - 5350000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 2632.979307] cfg80211: (5470000 KHz - 5725000 KHz @ 160000 KHz), (N/A, 2698 mBm) [ 2632.979316] cfg80211: (5725000 KHz - 5875000 KHz @ 80000 KHz), (N/A, 1397 mBm) [ 2632.979319] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm) [ 2635.550858] RTAI[math]: unloaded. [ 2635.553977] SCHED releases registered named ALIEN PEDV$D [ 2635.557348] RTAI[malloc]: unloaded. [ 2635.656028] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 2635.658943] I-pipe: head domain RTAI unregistered. [ 2635.659003] RTAI[hal]: unmounted. [ 2643.038612] I-pipe: head domain RTAI registered. [ 2643.038619] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 2643.038665] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 2643.038669] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12555225, CLK_FREQ 2209691000, CPU_FREQ 2209691000 [ 2643.038673] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 2643.038677] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12555225, 12555225, 8014750 [ 2643.048864] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 2643.048924] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 2643.048929] RTAI[sched]: hard timer type/freq = APIC/12555225(Hz); default timing: oneshot; linear timed lists. [ 2643.048933] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2209691000 hz. [ 2643.048936] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 2643.062537] RTAI[math]: loaded. [ 2643.220807] config string '0 out' [ 2651.008146] usb 1-2.4: reset high-speed USB device number 5 using ehci_hcd [ 2666.080146] usb 1-2.4: device descriptor read/64, error -110 [ 2681.256142] usb 1-2.4: device descriptor read/64, error -110 [ 2681.432143] usb 1-2.4: reset high-speed USB device number 5 using ehci_hcd [ 2696.504142] usb 1-2.4: device descriptor read/64, error -110 [ 2711.680175] usb 1-2.4: device descriptor read/64, error -110 [ 2711.856176] usb 1-2.4: reset high-speed USB device number 5 using ehci_hcd [ 2722.264032] usb 1-2.4: device not accepting address 5, error -110 [ 2722.336141] usb 1-2.4: reset high-speed USB device number 5 using ehci_hcd [ 2732.744041] usb 1-2.4: device not accepting address 5, error -110 [ 2732.744375] usb 1-2.4: USB disconnect, device number 5 [ 2732.840143] usb 1-2.4: new high-speed USB device number 6 using ehci_hcd [ 2747.912140] usb 1-2.4: device descriptor read/64, error -110 [ 2763.088318] usb 1-2.4: device descriptor read/64, error -110 [ 2763.264156] usb 1-2.4: new high-speed USB device number 7 using ehci_hcd [ 2778.336121] usb 1-2.4: device descriptor read/64, error -110 [ 2793.512144] usb 1-2.4: device descriptor read/64, error -110 [ 2793.688146] usb 1-2.4: new high-speed USB device number 8 using ehci_hcd [ 2804.096140] usb 1-2.4: device not accepting address 8, error -110 [ 2804.168147] usb 1-2.4: new high-speed USB device number 9 using ehci_hcd [ 2814.576046] usb 1-2.4: device not accepting address 9, error -110 [ 2814.576126] hub 1-2:1.0: unable to enumerate USB device on port 4 [ 2819.986845] RTAI[math]: unloaded. [ 2819.989351] SCHED releases registered named ALIEN PEDV$D [ 2820.002018] RTAI[malloc]: unloaded. [ 2820.100038] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 2820.108965] I-pipe: head domain RTAI unregistered. [ 2820.109019] RTAI[hal]: unmounted. [ 2846.874565] I-pipe: head domain RTAI registered. [ 2846.874573] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 2846.874621] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 2846.874625] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12555225, CLK_FREQ 2209691000, CPU_FREQ 2209691000 [ 2846.874629] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 2846.874632] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12555225, 12555225, 12467250 [ 2846.884653] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 2846.884715] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 2846.884720] RTAI[sched]: hard timer type/freq = APIC/12555225(Hz); default timing: oneshot; linear timed lists. [ 2846.884724] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2209691000 hz. [ 2846.884727] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 2846.892360] RTAI[math]: loaded. [ 2847.043096] config string '0 out' [ 2865.231158] RTAI[math]: unloaded. [ 2865.233726] SCHED releases registered named ALIEN PEDV$D [ 2865.248342] RTAI[malloc]: unloaded. [ 2865.348050] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 2865.350264] I-pipe: head domain RTAI unregistered. [ 2865.350314] RTAI[hal]: unmounted. [ 3009.231058] wlan0: deauthenticating from c8:0e:14:a2:28:b5 by local choice (reason=3) [ 3009.263465] cfg80211: Calling CRDA to update world regulatory domain [ 3009.270536] cfg80211: World regulatory domain updated: [ 3009.270543] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 3009.270547] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm) [ 3009.270550] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm) [ 3009.270553] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm) [ 3009.270556] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 3009.270559] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 3009.270561] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm) [ 3009.270564] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 3009.270567] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm) [ 3013.188613] wlan0: authenticate with c8:0e:14:a2:28:b5 [ 3013.208184] wlan0: send auth to c8:0e:14:a2:28:b5 (try 1/3) [ 3013.212029] wlan0: authenticated [ 3013.224032] wlan0: associate with c8:0e:14:a2:28:b5 (try 1/3) [ 3013.229560] wlan0: RX AssocResp from c8:0e:14:a2:28:b5 (capab=0x1431 status=0 aid=6) [ 3013.239876] wlan0: associated [ 3013.239938] cfg80211: Calling CRDA for country: DE [ 3013.245528] cfg80211: Regulatory domain changed to country: DE [ 3013.245534] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 3013.245538] cfg80211: (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm) [ 3013.245541] cfg80211: (5150000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 3013.245544] cfg80211: (5250000 KHz - 5350000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 3013.245547] cfg80211: (5470000 KHz - 5725000 KHz @ 160000 KHz), (N/A, 2698 mBm) [ 3013.245549] cfg80211: (5725000 KHz - 5875000 KHz @ 80000 KHz), (N/A, 1397 mBm) [ 3013.245552] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm) [ 3281.866828] I-pipe: head domain RTAI registered. [ 3281.866837] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 3281.866884] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 3281.866888] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12555225, CLK_FREQ 2209691000, CPU_FREQ 2209691000 [ 3281.866891] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 3281.866895] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12555225, 12555225, 12481500 [ 3281.880456] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 3281.880513] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 3281.880518] RTAI[sched]: hard timer type/freq = APIC/12555225(Hz); default timing: oneshot; linear timed lists. [ 3281.880522] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2209691000 hz. [ 3281.880525] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 3281.889123] RTAI[math]: loaded. [ 3282.061449] config string '0 out' [ 3292.317925] RTAI[math]: unloaded. [ 3292.320332] SCHED releases registered named ALIEN PEDV$D [ 3292.325290] RTAI[malloc]: unloaded. [ 3292.424034] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 3292.426470] I-pipe: head domain RTAI unregistered. [ 3292.426530] RTAI[hal]: unmounted. [ 3298.714011] I-pipe: head domain RTAI registered. [ 3298.714020] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 3298.714069] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 3298.714073] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12555225, CLK_FREQ 2209691000, CPU_FREQ 2209691000 [ 3298.714076] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 3298.714080] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12555225, 12555225, 12459500 [ 3298.724125] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 3298.724195] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 3298.724199] RTAI[sched]: hard timer type/freq = APIC/12555225(Hz); default timing: oneshot; linear timed lists. [ 3298.724203] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2209691000 hz. [ 3298.724207] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 3298.731626] RTAI[math]: loaded. [ 3298.881285] config string '0 out' [ 3411.825500] RTAI[math]: unloaded. [ 3411.827722] SCHED releases registered named ALIEN PEDV$D [ 3411.832831] RTAI[malloc]: unloaded. [ 3411.932020] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 3411.934343] I-pipe: head domain RTAI unregistered. [ 3411.934401] RTAI[hal]: unmounted. [ 3725.253907] I-pipe: head domain RTAI registered. [ 3725.253915] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 3725.253963] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 3725.253967] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12555225, CLK_FREQ 2209691000, CPU_FREQ 2209691000 [ 3725.253971] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 3725.253975] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12555225, 12555225, 12455000 [ 3725.267094] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 3725.267157] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 3725.267162] RTAI[sched]: hard timer type/freq = APIC/12555225(Hz); default timing: oneshot; linear timed lists. [ 3725.267166] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2209691000 hz. [ 3725.267169] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 3725.273898] RTAI[math]: loaded. [ 3725.433498] config string '0 out' [ 3924.513777] RTAI[math]: unloaded. [ 3924.519097] SCHED releases registered named ALIEN PEDV$D [ 3924.525233] RTAI[malloc]: unloaded. [ 3924.624026] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 3924.626478] I-pipe: head domain RTAI unregistered. [ 3924.626538] RTAI[hal]: unmounted. [ 3934.354787] I-pipe: head domain RTAI registered. [ 3934.354796] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 3934.354837] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 3934.354842] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12555225, CLK_FREQ 2209691000, CPU_FREQ 2209691000 [ 3934.354845] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 3934.354849] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12555225, 12555225, 12475500 [ 3934.364889] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 3934.364951] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 3934.364956] RTAI[sched]: hard timer type/freq = APIC/12555225(Hz); default timing: oneshot; linear timed lists. [ 3934.364960] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2209691000 hz. [ 3934.364963] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 3934.379820] RTAI[math]: loaded. [ 3934.528025] RTAPI: ERROR: Unexpected realtime delay on task 1 [ 3934.528025] This Message will only display once per session. [ 3934.528025] Run the Latency Test and resolve before continuing. [ 3934.531631] config string '0 out' [ 4086.711942] RTAI[math]: unloaded. [ 4086.714270] SCHED releases registered named ALIEN PEDV$D [ 4086.717029] RTAI[malloc]: unloaded. [ 4086.816023] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 4086.818378] I-pipe: head domain RTAI unregistered. [ 4086.818437] RTAI[hal]: unmounted. [ 4225.240225] wlan0: deauthenticating from c8:0e:14:a2:28:b5 by local choice (reason=3) [ 4225.277880] cfg80211: Calling CRDA to update world regulatory domain [ 4225.284488] cfg80211: World regulatory domain updated: [ 4225.284494] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 4225.284498] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm) [ 4225.284501] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm) [ 4225.284504] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm) [ 4225.284507] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 4225.284510] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 4225.284513] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm) [ 4225.284516] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 4225.284519] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm) [ 4229.197126] wlan0: authenticate with c8:0e:14:a2:28:b5 [ 4229.216137] wlan0: send auth to c8:0e:14:a2:28:b5 (try 1/3) [ 4229.219841] wlan0: authenticated [ 4229.236053] wlan0: associate with c8:0e:14:a2:28:b5 (try 1/3) [ 4229.240895] wlan0: RX AssocResp from c8:0e:14:a2:28:b5 (capab=0x1431 status=0 aid=6) [ 4229.251460] wlan0: associated [ 4229.252146] cfg80211: Calling CRDA for country: DE [ 4229.259691] cfg80211: Regulatory domain changed to country: DE [ 4229.259698] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 4229.259702] cfg80211: (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm) [ 4229.259705] cfg80211: (5150000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 4229.259708] cfg80211: (5250000 KHz - 5350000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 4229.259711] cfg80211: (5470000 KHz - 5725000 KHz @ 160000 KHz), (N/A, 2698 mBm) [ 4229.259714] cfg80211: (5725000 KHz - 5875000 KHz @ 80000 KHz), (N/A, 1397 mBm) [ 4229.259717] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm) [ 4970.610081] I-pipe: head domain RTAI registered. [ 4970.610089] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 4970.610137] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 4970.610141] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12555225, CLK_FREQ 2209691000, CPU_FREQ 2209691000 [ 4970.610145] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 4970.610148] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12555225, 12555225, 12487250 [ 4970.620280] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 4970.620340] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 4970.620345] RTAI[sched]: hard timer type/freq = APIC/12555225(Hz); default timing: oneshot; linear timed lists. [ 4970.620349] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2209691000 hz. [ 4970.620352] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 4970.633233] RTAI[math]: loaded. [ 4970.794047] config string '0 out' [ 5098.608590] RTAI[math]: unloaded. [ 5098.610964] SCHED releases registered named ALIEN PEDV$D [ 5098.621144] RTAI[malloc]: unloaded. [ 5098.720022] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 5098.722304] I-pipe: head domain RTAI unregistered. [ 5098.722364] RTAI[hal]: unmounted.
I have completely set up linuxcnc two times now and I get the same error every time. can someone help me?
Thanks.
Moderators: HansU
Time to create page: 0.173 seconds
