Button on Linuxcnc interface that switches an output on Mesa 7i76e on and off
12 Oct 2025 11:06 - 12 Oct 2025 11:36 #336317 by DerKlotz
My Ini already had the POSTGUI_HALFILE = custom_postgui.hal
In my Display Section ii this ->
GLADEVCP= -u ./hitcounter.py /home/cnc/linuxcnc/configs/Fräse/test.ui
BUT i receive the "hitcounter.py" error from my post before
Today i did a Sudo ... update and upgrade. During the upgrade i got these errors. Somewhere there the problem?
dpkg: error processing package linux-image-6.1.0-40-rt-amd64 (--configure):
 installed linux-image-6.1.0-40-rt-amd64 package post-installation script subpro
cess returned error exit status 1
Setting up libgs10-common (10.0.0~dfsg-11+deb12u8) ...
Setting up libtiff-dev:amd64 (4.5.0-6+deb12u3) ...
dpkg: dependency problems prevent configuration of linux-image-rt-amd64:
 linux-image-rt-amd64 depends on linux-image-6.1.0-40-rt-amd64 (= 6.1.153-1); ho
wever:
  Package linux-image-6.1.0-40-rt-amd64 is not configured yet.
dpkg: error processing package linux-image-rt-amd64 (--configure):
 dependency problems - leaving unconfigured
Setting up libgs10:amd64 (10.0.0~dfsg-11+deb12u8) ...
Setting up ghostscript (10.0.0~dfsg-11+deb12u8) ...
Processing triggers for libc-bin (2.36-9+deb12u13) ...
Processing triggers for man-db (2.11.2-2) ...
Processing triggers for initramfs-tools (0.142+deb12u3) ...
update-initramfs: Generating /boot/initrd.img-6.1.0-40-rt-amd64
raspi-firmware: missing /boot/firmware, did you forget to mount it?
run-parts: /etc/initramfs/post-update.d//z50-raspi-firmware exited with return c
ode 1
dpkg: error processing package initramfs-tools (--configure):
 installed initramfs-tools package post-installation script subprocess returned
error exit status 1
Errors were encountered while processing:
 initramfs-tools
E: Sub-process /usr/bin/dpkg returned an error code (1)
Error during glade install
~$ sudo apt install glade
[sudo] password for cnc:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
glade is already the newest version (3.40.0-3+b1).
The following packages were automatically installed and are no longer required:
  linux-headers-6.1.0-30-amd64 linux-headers-6.1.0-30-common
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
3 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up initramfs-tools (0.142+deb12u3) ...
update-initramfs: deferring update (trigger activated)
Setting up linux-image-6.1.0-40-rt-amd64 (6.1.153-1) ...
/etc/kernel/postinst.d/dkms:
dkms: running auto installation service for kernel 6.1.0-40-rt-amd64.
dkms: autoinstall for kernel: 6.1.0-40-rt-amd64.
/etc/kernel/postinst.d/initramfs-tools:
ode 1
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
wever:
ode 1
error exit status 1
 initramfs-tools
Last edit: 12 Oct 2025 11:36 by DerKlotz.
12 Oct 2025 11:54 #336319 by Aciera
Not sure why you keep hacking away at your setup.
Any particular reason for not trying the example.ui I have attached?
12 Oct 2025 14:04 - 12 Oct 2025 14:05 #336325 by DerKlotz
I used your example.ui and custom_postgui.hal now. Sorry for all... iḿ a total newbie
I used this command in the ini/Display for the ui... correct? Itś stored under that folder
GLADEVCP = /home/cnc/linuxcnc/configs/Fräse/example.ui
Still get errors
UN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.6
Machine configuration directory is '/home/cnc/linuxcnc/configs/Fräse'
Machine configuration file is 'Fräse.ini'
INIFILE=/home/cnc/linuxcnc/configs/Fräse/Fräse.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./Fräse.hal
Found file(REL): ./custom.hal
Starting DISPLAY program: axis
83886083
['halcmd', 'loadusr', '-Wn', 'gladevcp', 'gladevcp', '-c', 'gladevcp', '-d', '-x', '81789071', '/home/cnc/linuxcnc/configs/Fräse/example.ui']
Running HAL shutdown script
task: 315 cycles, min=0.000010, max=0.019215, avg=0.009510, 0 latency excursions (> 10x expected cycle time of 0.010000s)
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:10:4c:98
hm2_eth: discovered 7I76E-16
hm2/hm2_7i76e.0: Low Level init 0.15
hm2/hm2_7i76e.0: Smart Serial Firmware Version 43
Board hm2_7i76e.0.7i76.0.0 Hardware Mode 0 = standard
Board hm2_7i76e.0.7i76.0.0 Software Mode 0 = io_spin
Board hm2_7i76e.0.7i76.0.0 Software Mode 1 = io_ana_spin
Board hm2_7i76e.0.7i76.0.0 Software Mode 2 = io_enc_ana_spin_fv
hm2/hm2_7i76e.0: 51 I/O Pins used:
hm2/hm2_7i76e.0:     IO Pin 000 (P1-01): StepGen #0, pin Direction (Output)
hm2/hm2_7i76e.0:     IO Pin 001 (P1-14): StepGen #0, pin Step (Output)
hm2/hm2_7i76e.0:     IO Pin 002 (P1-02): StepGen #1, pin Direction (Output)
hm2/hm2_7i76e.0:     IO Pin 003 (P1-15): StepGen #1, pin Step (Output)
hm2/hm2_7i76e.0:     IO Pin 004 (P1-03): StepGen #2, pin Direction (Output)
hm2/hm2_7i76e.0:     IO Pin 005 (P1-16): StepGen #2, pin Step (Output)
hm2/hm2_7i76e.0:     IO Pin 006 (P1-04): IOPort
hm2/hm2_7i76e.0:     IO Pin 007 (P1-17): IOPort
hm2/hm2_7i76e.0:     IO Pin 008 (P1-05): IOPort
hm2/hm2_7i76e.0:     IO Pin 009 (P1-06): IOPort
hm2/hm2_7i76e.0:     IO Pin 010 (P1-07): Smart Serial Interface #0, pin tx0 (Output)
hm2/hm2_7i76e.0:     IO Pin 011 (P1-08): Smart Serial Interface #0, pin rx0 (Input)
hm2/hm2_7i76e.0:     IO Pin 012 (P1-09): IOPort
hm2/hm2_7i76e.0:     IO Pin 013 (P1-10): IOPort
hm2/hm2_7i76e.0:     IO Pin 014 (P1-11): Encoder #0, pin Index (Input)
hm2/hm2_7i76e.0:     IO Pin 015 (P1-12): Encoder #0, pin B (Input)
hm2/hm2_7i76e.0:     IO Pin 016 (P1-13): Encoder #0, pin A (Input)
hm2/hm2_7i76e.0:     IO Pin 017 (P2-01): IOPort
hm2/hm2_7i76e.0:     IO Pin 018 (P2-14): IOPort
hm2/hm2_7i76e.0:     IO Pin 019 (P2-02): IOPort
hm2/hm2_7i76e.0:     IO Pin 020 (P2-15): IOPort
hm2/hm2_7i76e.0:     IO Pin 021 (P2-03): IOPort
hm2/hm2_7i76e.0:     IO Pin 022 (P2-16): IOPort
hm2/hm2_7i76e.0:     IO Pin 023 (P2-04): IOPort
hm2/hm2_7i76e.0:     IO Pin 024 (P2-17): IOPort
hm2/hm2_7i76e.0:     IO Pin 025 (P2-05): IOPort
hm2/hm2_7i76e.0:     IO Pin 026 (P2-06): IOPort
hm2/hm2_7i76e.0:     IO Pin 027 (P2-07): IOPort
hm2/hm2_7i76e.0:     IO Pin 028 (P2-08): IOPort
hm2/hm2_7i76e.0:     IO Pin 029 (P2-09): IOPort
hm2/hm2_7i76e.0:     IO Pin 030 (P2-10): IOPort
hm2/hm2_7i76e.0:     IO Pin 031 (P2-11): IOPort
hm2/hm2_7i76e.0:     IO Pin 032 (P2-12): IOPort
hm2/hm2_7i76e.0:     IO Pin 033 (P2-13): IOPort
hm2/hm2_7i76e.0:     IO Pin 034 (P3-01): IOPort
hm2/hm2_7i76e.0:     IO Pin 035 (P3-14): IOPort
hm2/hm2_7i76e.0:     IO Pin 036 (P3-02): IOPort
hm2/hm2_7i76e.0:     IO Pin 037 (P3-15): IOPort
hm2/hm2_7i76e.0:     IO Pin 038 (P3-03): IOPort
hm2/hm2_7i76e.0:     IO Pin 039 (P3-16): IOPort
hm2/hm2_7i76e.0:     IO Pin 040 (P3-04): IOPort
hm2/hm2_7i76e.0:     IO Pin 041 (P3-17): IOPort
hm2/hm2_7i76e.0:     IO Pin 042 (P3-05): IOPort
hm2/hm2_7i76e.0:     IO Pin 043 (P3-06): IOPort
hm2/hm2_7i76e.0:     IO Pin 044 (P3-07): IOPort
hm2/hm2_7i76e.0:     IO Pin 045 (P3-08): IOPort
hm2/hm2_7i76e.0:     IO Pin 046 (P3-09): IOPort
hm2/hm2_7i76e.0:     IO Pin 047 (P3-10): IOPort
hm2/hm2_7i76e.0:     IO Pin 048 (P3-11): IOPort
hm2/hm2_7i76e.0:     IO Pin 049 (P3-12): IOPort
hm2/hm2_7i76e.0:     IO Pin 050 (P3-13): IOPort
hm2/hm2_7i76e.0: registered
hm2_eth: in hm2_eth_reset
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
note: MAXV     max: 25.000 units/sec 1500.000 units/min
note: LJOG     max: 25.000 units/sec 1500.000 units/min
note: LJOG default: 6.000 units/sec 360.000 units/min
note: jog_order='XYZ'
note: jog_invert=set()
[GladeVCP][[36mINFO[0m]  Logging to: [33m/home/cnc/gladevcp.log[0m (logger.py:106)
[GladeVCP.QTVCP.QT_ISTAT][[33mWARNING[0m]  INI Parsing Error, No DEFAULT_SPINDLE_0_SPEED Entry in DISPLAY, Using: 200 (qt_istat.py:532)
[GladeVCP.QTVCP.QT_ISTAT][[33mWARNING[0m]  INI Parsing Error, No MIN_SPINDLE_0_SPEED Entry in DISPLAY, Using: 100 (qt_istat.py:532)
[GladeVCP.QTVCP.QT_ISTAT][[33mWARNING[0m]  INI Parsing Error, No MAX_SPINDLE_0_SPEED Entry in DISPLAY, Using: 2500 (qt_istat.py:532)
[GladeVCP.QTVCP.QT_ISTAT][[33mWARNING[0m]  INI Parsing Error, No MAX_SPINDLE_0_OVERRIDE Entry in DISPLAY, Using: 1 (qt_istat.py:532)
[GladeVCP.QTVCP.QT_ISTAT][[33mWARNING[0m]  INI Parsing Error, No MIN_SPINDLE_0_OVERRIDE Entry in DISPLAY, Using: 0.5 (qt_istat.py:532)
custom_postgui.hal:4: setp requires 2 arguments, 1 given
(gladevcp:117656): Gdk-WARNING **: 16:03:36.296: GdkWindow 0x5000003 unexpectedly destroyed
/usr/lib/python3/dist-packages/gi/overrides/Gtk.py:1689: Warning: invalid (NULL) pointer instance
  return _Gtk_main(*args, **kwargs)
/usr/lib/python3/dist-packages/gi/overrides/Gtk.py:1689: Warning: g_signal_handler_disconnect: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(gladevcp:117656): Gdk-CRITICAL **: 16:03:36.296: gdk_frame_clock_end_updating: assertion 'GDK_IS_FRAME_CLOCK (frame_clock)' failed
**** GLADE VCP ERROR:    X Protocol Error: 3
117585
117633
Stopping realtime threads
Unloading hal components
Last edit: 12 Oct 2025 14:05 by DerKlotz.
12 Oct 2025 14:19 - 12 Oct 2025 14:19 #336326 by PCW
Not sure about the GUI errors, but this is a showstopper:
That means you have a very basic error in line 4 of custom_postgui.hal
Last edit: 12 Oct 2025 14:19 by PCW.
12 Oct 2025 14:42 #336327 by DerKlotz
There was an 1 missing... probably didn´t copy it.
But still many errors...
12 Oct 2025 14:51 - 12 Oct 2025 15:45 #336328 by DerKlotz
Strange... now the first two rows of the postgui work
ok now setp gladevcp.table1 1
ok now net button gladevcp.button1 halui.machine.on
not ok net led halui.machine.is-on gladevcp.led1
The last row still creates an error -> custom_postgui.hal:6: Pin 'halui.machine.is-on' was already linked to signal 'machine-is-on'
This is now correct
net button gladevcp.button1 halui.machine.on gladevcp.led1
Last edit: 12 Oct 2025 15:45 by DerKlotz.
12 Oct 2025 16:19 #336331 by andypugh
A bit of HAL backgroumd. A HAL "net" command is the word "net" followed by a "signal name" and one or more HAL pins.
The signal name can be chosen fairly freely, and serves as the reference for interconneting HAL pins. There can be may HAL pins in the same net, but only one of them can be a "writer" (This might typically be called an "output" but that gets a but confusing as physical inputs are "output" HAL pins (they output a value) and physical outputs are "inputs" as they accept a value from output HAL pin)
Back to your error. It means that the HAL pin "halui.machine.is-on" is already connected to a HAL "net" somewhere else in the HAL files, and that it is connected to the net "machine-is-on".
The fix for this is to just use "machine-is-on" as the net name for anything that you want to connect to "halui.machine.is-on"
I can't see your problem HAL line from inside this editor, but if, for example, the line causing the problem was:
net some-net-name mygladepanel.pin <= halui.machine.is-on"
Then you would need to change it to:
net machine-is-on => mygladevcp.pin
(Note that the => <= and <=> don't mean anything to the computer and can be left out, but can help readabilty for humans)
12 Oct 2025 17:36 #336339 by DerKlotz
Thank you so far. I continue tomorrow
12 Oct 2025 19:36 #336344 by rodw
Try repeating after typing
    sudo apt purge raspi-firmware
If you still gets errors, share the output of uname -r as it appears it is trying to install an incorrect kernel version.
13 Oct 2025 10:15 #336371 by DerKlotz
I got this message 6.1.0-30-rt-amd64
How do i do it?
Moderators: HansU
Time to create page: 0.190 seconds
