start up Help
First I'm sorry to make silly questions, this is my very first experience with Linux.
Unless the computer shop fool me when I specifically asked one motherboard with it, I have it. Here is the motherboard that I have, at least the connector is there:
ASUS P5641T-M-LX2/BR
br.asus.com/Motherboards/Intel_Socket_77...X2BR/#specifications
As the result from the command you suggested...
pccabral@pccabral-desktop:~$ cat /proc/ioports
0000-001f : dma1
0020-0021 : pic1
0040-0043 : timer0
0050-0053 : timer1
0060-0060 : keyboard
0064-0064 : keyboard
0070-0071 : rtc0
0080-008f : dma page reg
00a0-00a1 : pic2
00c0-00df : dma2
00f0-00ff : fpu
0170-0177 : 0000:00:1f.1
0170-0177 : ata_piix
01f0-01f7 : 0000:00:1f.1
01f0-01f7 : ata_piix
0290-029f : pnp 00:08
0376-0376 : 0000:00:1f.1
0376-0376 : ata_piix
03c0-03df : vga+
03f2-03f2 : floppy
03f4-03f5 : floppy
03f6-03f6 : 0000:00:1f.1
03f6-03f6 : ata_piix
03f7-03f7 : floppy
03f8-03ff : serial
0400-041f : pnp 00:09
0480-04bf : 0000:00:1f.0
0480-04bf : pnp 00:09
04d0-04d1 : pnp 00:09
0800-087f : 0000:00:1f.0
0800-087f : pnp 00:09
0800-0803 : ACPI PM1a_EVT_BLK
0804-0805 : ACPI PM1a_CNT_BLK
0808-080b : ACPI PM_TMR
0828-082f : ACPI GPE0_BLK
0a20-0a2f : pnp 00:08
0a30-0a3f : pnp 00:08
0c00-0c0f : pnp 00:08
0cf8-0cff : PCI conf1
1000-1fff : PCI Bus 0000:03
2000-2fff : PCI Bus 0000:01
c800-c80f : 0000:00:1f.2
c800-c80f : ata_piix
c880-c883 : 0000:00:1f.2
c880-c883 : ata_piix
cc00-cc07 : 0000:00:1f.2
cc00-cc07 : ata_piix
d000-d003 : 0000:00:1f.2
d000-d003 : ata_piix
d080-d087 : 0000:00:1f.2
d080-d087 : ata_piix
d400-d41f : 0000:00:1d.0
d400-d41f : uhci_hcd
d480-d49f : 0000:00:1d.1
d480-d49f : uhci_hcd
d800-d81f : 0000:00:1d.2
d800-d81f : uhci_hcd
d880-d89f : 0000:00:1d.3
d880-d89f : uhci_hcd
dc00-dc07 : 0000:00:02.0
e000-efff : PCI Bus 0000:02
e800-e8ff : 0000:02:00.0
e800-e8ff : r8169
ffa0-ffaf : 0000:00:1f.1
ffa0-ffaf : ata_piix
I think that what I have is a serial port, not a parallel port. (I was fooled) if that is true, I have to claim that with the computer shop. How can I know that for sure? (I just want to play dumb once)
![:S :S](/media/kunena/emoticons/dizzy.png)
PC
What motherboard is it?
It might be that there is a header for a parallel port on the motherboard, but it needs an adapter and to be enabled in the BIOS.
This is the case with the Intel D510MO, for example.
From a terminal
dmesg|grep parport
lspci will show pci parallel ports but not motherboard parallel ports, which is why I suggested you try both earlier.
What parallel cable are you using? Is it plugged into a add in card or on the motherboard?
Rick G
I think that what I have is a serial port, not a parallel. I will contact the computer shop.
The picture shows a purple port, but in fact my one is blue. I think that I have a serial port not a parallel one. I will buy a parallel board, is a cheap board....
I tried dmesg|grep parport, but still doesn't work...
Thanks for the hint. I will try thru Bios...
Regards
Does it list anything?
Rick G
