adding a pendant to the system
the device is an keyboard... i know it is quite a limiting factor but how can i link the buttons "*" and "/" to feed override more and feed over ride less? and got
"+" and "-" that need to do spindle override as my esc button on it seems to be taged as E-stop...
Take a look here...
wiki.linuxcnc.org/cgi-bin/wiki.pl?Halui
Here are some of the pins you may want to connect to..
So using halui you may be able to connect your buttons to the feed-override.increase / decrease to get the desired effect.halui.feed-override.value float //current FO value
halui.feed-override.scale float // pin for setting the scale on changing the FO
halui.feed-override.counts s43 //counts from an encoder for example to change FO
halui.feed-override.increase bit // pin for increasing the FO (+=scale)
halui.feed-override.decrease bit // pin for decreasing the FO (-=scale)
Same for spindle...
halui.spindle-override.value float //current SO value
halui.spindle-override.scale float // pin for setting the scale on changing the SO
halui.spindle-override.counts s43 //counts from an encoder for example to change SO
halui.spindle-override.increase bit // pin for increasing the SO (+=scale)
halui.spindle-override.decrease bit // pin for decreasing the SO (-=scale)
An example when using a joypad could be...
wiki.linuxcnc.org/cgi-bin/wiki.pl?Adding...imple_Remote_Pendant
Rick G
