First time EMC2 user need help
You should be able to change the extension to .txt. Alternatively put it at www.pastebin.com. Or look through it for the parallel port and paste the surrounding few lines into a message here.My friend tried the cat /proc/ioports and he sent me a .dat file of it but I cannot upload it. Any other way to give the info?
9400-9402 : parport1
9403-9407 : parport1
9c00-9c02 : parport0
9c03-9c07 : parport0
lspci says:
04:08.0 Parallel controller: Timedia Technology Co Ltd SUN1888 (Dual IEEE1284 parallel port) (rev 01) (prog-if 02)
Subsystem: Timedia Technology Co Ltd Device 0102
Flags: stepping, medium devsel, IRQ 16
I/O ports at 9c00
I/O ports at 9800
I/O ports at 9400
I/O ports at 9000
So, they even agree.
It looks like you have a dual parport card, and your base address probably needs to be set to 9c00
Try that. I am optimistic.
proc/ioports says
lspci says:
I/O ports at 9c00
I/O ports at 9800
I/O ports at 9400
I/O ports at 9000
Excellent,
So do I put "0" in the parport address in Stepconfig wizard? Also someone suggested to add two lines in the .hal is this still the case?
tks
No, you put "9c00" as the parport address in Stepconf Wizard. That should be all that has ever been missing.
If that doesn't work, you can try 9400 instead.
She moves left, right, front, back, up and down..........................what a feeling! Now we will experiment with the machine for a while and post back.
A humongous THANK YOU
Have a great week-end
I am just sorry it took us 2 weeks to think of the obvious :-/A humongous THANK YOU
Have fun with the machine.
