Inaccurate Arcs and Circles at Higher Speeds
13 Feb 2013 11:08 - 14 Feb 2013 01:17 #30000
by Paul
Inaccurate Arcs and Circles at Higher Speeds was created by Paul
Hi - I'm looking for direction in addressing a problem I came across recently. I have a stepper table using #25 chains for both X and Y axis. I ran a plasma cut piece at a higher feed rate and straight lines were OK, but the arcs and circles were somewhat shifted. They were not oblong, but shifted over. If I ran the same piece at half the rate, the paths were proportionally correct. At first I thought I was loosing steps, but am now looking elsewhere because the machine returns to the correct spot when going back to X0Y0 after each cut. The one difference I am aware of is the velocity is a bit different when comparing the X and Y axis portion of the ini file. I am using G64 P0.005 on a metric setup.
Could the velocity difference (250 vs 275) be causing issues at higher feed rates or do I need to look elsewhere? Thank you...
PK
Also: Axis drive slip/slop has been checked and is tight.
PK
Last edit: 14 Feb 2013 01:17 by Paul. Reason: spelling
13 Feb 2013 18:13 #30012
by Rick G
Have you tried adding Q- to your G64 command?
By shifted do you mean the circle arcs are round but not in the correct location?
Sure there is not flex in the system, more so at higher speeds?
Have you tried adjusting your acceleration?
Rick G
Replied by Rick G on topic Inaccurate Arcs and Circles at Higher Speeds
In theory probable not, the fastest speed of a coordinated move is only as fast as the slowest axis can keep up with.Could the velocity difference (250 vs 275) be causing issues at higher feed rates or do I need to look elsewhere? Thank you...
Rick G
14 Feb 2013 01:26 #30031
by Paul
Replied by Paul on topic Inaccurate Arcs and Circles at Higher Speeds
Thanks for your time, Rick,
I did forget to update my gcode in adding the Q- part to the G64.
I will attempt to add a picture to help show what I'm experiencing. I don't believe there is flex at high speeds, but maybe sluggish axis as this table was built for a router CNC. I can run rapids over 15,000mm/min and this problem job was specified at 5000mm/min with some arcs running around 2500. When I ran it at a maximum 2500mm/min, all was well.
I have not tried adjusting the acceleration as I set it up to run as fast as possible with as quick acceleration so as to keep the torch moving as consistently as possible. At least that's what I think my goal should be. I am making a list to try each suggestion next time I "get" the garage. Probably next weekend...
Again - Thanks for your help, Rick.
Paul
Paul
14 Feb 2013 01:49 #30034
by BigJohnT
Replied by BigJohnT on topic Inaccurate Arcs and Circles at Higher Speeds
With G64 P0.0005 (metric) that is 0.00002" and a bit unreal for a path following tolerance for a plasma cutter. It should act like G61 (exact path mode). I would suggest one using G61 to determine if it is a machine issue then perhaps a more realistic G64 P 0.5 or 0.1 to see if it is a software problem which I doubt because my plasma runs at 500IPM with a G64 P0.005 (inches).
14 Feb 2013 03:26 #30042
by Paul
Thanks John,
I wondered how overboard that .005 was, but threw it in my code without thinking it through considering my machine is setup for metric. I will keep your information on my list, too.
Is it correct for me to think that your 500IPM might not be something I *should* expect due to probable computer latency differences? I believe (without checking my notes) that my maximum jitter was 13,000 using Keling KL-4030 drivers to 495oz motors as my setup.
I appreciate this!
Paul
I appreciate this!
Paul
14 Feb 2013 05:24 #30046
by BigJohnT
Your latency sounds good, the speed you can get depends on your power supply voltage, your gearing, your gantry mass, the drives and motors. Steppers have a RPM limit and loose torque at high RPM. Higher voltage means more torque and faster acceleration.
14 Feb 2013 20:01 #30054
by Rick G
John's info covers the bases great.
Take a look at your acceleration.
Also keep in mind that as you are not geeting any joint errors and the machine returns to the same postion each time it would seem you are not loosing steps.
I beleive you will find that a plasma gantry is lighter than a router gantry so it is easier to accelerate, and it does not need the strenght of a router table.
Rick G
Rick G
15 Feb 2013 19:31 #30099
by Paul
Thanks guys,
I have a part programmed a couple different ways: one with G61 and then G64. I will check my acceleration and see how things go next time I get a chance. I do have a 36v power supply, but can't seem to find motor specs.
A goal I have is to use the CNC router setup to plasma cut parts to build a plasma gantry/table for a setup better suited for plasma cutting.
Thanks again. Will post results here in case it may help someone in the future.
PK
PK
07 Mar 2013 00:48 #30980
by Paul
I ran those parts recently. First ran the one programmed with the G61 and the part was perfect. I next ran the same part using G64 P0.5 Q0.75 and, surprisingly, it too was perfect proportionally. ! I believe I didn't make any other changes, so I'm not sure what caused the problem.
Mostly unrelated, I noticed the post processor I am using was reducing the feed rate on smaller radii (smaller than 10mm). I see more dross on those smaller areas. Should I slow the torch down in these cases?
Thanks for your help....
PK
PK
07 Mar 2013 02:14 #30984
by BigJohnT
For a plasma the feed rate that the torch needs for that material is all you want. The control software will take care of the rest based on your acceleration settings. The CAM should not be calling out the speed shots because of arc size...
Time to create page: 0.083 seconds
