rigid tapping g33.1 isnt working spindle isnt sync
13 years 1 month ago #38386 by fabworx
Motion.spindle-at-speed is true pretty much all the time except below 250 rpm in high gear. I did check with halmeter while executing this gcode.
S500 m3
G33.1 z-0.065 k 0.08
13 years 1 month ago #38387 by fabworx
I just rewrote the hal leaving out the gear change to bring it back to basics still a no go here's what I have now.
# Spindle Control
setp hm2_5i20.0.pwmgen.04.output-type 2
setp hm2_5i20.0.pwmgen.04.scale 3530 # Set the spindle’s top speed in RPM
# Spindle Synchronized Motion
# add the encoder
setp hm2_5i20.0.encoder.04.counter-mode 0
setp hm2_5i20.0.encoder.04.filter 0
setp hm2_5i20.0.encoder.04.index-invert 0
setp hm2_5i20.0.encoder.04.index-mask 0
setp hm2_5i20.0.encoder.04.scale 8000
net spindle-position hm2_5i20.0.encoder.04.position => motion.spindle-revs
net spindle-velocity hm2_5i20.0.encoder.04.velocity => motion.spindle-speed-in
net spindle-index-enable hm2_5i20.0.encoder.04.index-enable <=> motion.spindle-index-enable
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-enable hm2_5i20.0.gpio.071.out <= motion.spindle-on hm2_5i20.0.gpio.045.out
net spindle-enable => hm2_5i20.0.pwmgen.04.enable
# Spindle At Speed
addf near.0 servo-thread
setp near.0.scale 1.01
net spindle-cmd => near.0.in1
net spindle-velocity => near.0.in2
net spindle-at-speed motion.spindle-at-speed <= near.0.out
#RPM Scale
setp rpm-scale scale.0.gain 60
net spindle-rps scale.0.in hm2_5i20.0.encoder.04.velocity
13 years 1 month ago #38388 by fabworx
im totally lost I believe I have everything needed for that gcode to execute but it isn't working and im getting frustrated. any other suggestions?
13 years 1 month ago #38391 by PCW
Dont know, maybe post the GCode here and the output of
"halcmd show pin"
when linuxcnc is hung at G33.1
The following user(s) said Thank You: fabworx
13 years 1 month ago #38392 by fabworx
here is the gcode
S500 m3
13 years 1 month ago #38393 by fabworx
what "halcmd show pin"?
Time to create page: 0.107 seconds
