That's what I am saying.BigJohnT wrote: Are you saying what I'm thinking your saying? In the case where the encoder is not attached to the spindle or geared 1:1 with the spindle don't use the encoder index but rather provide an index directly from the spindle?
fabworx wrote: to make things a little clearer the encoder is mounted directly on the back of the motor. the gear change decides which scale to use by invoking which ultimate gear ratio is being used
fabworx wrote: so what I have here with my gear change function in the hal wont work with rigid tapping?
